Unraid NUT UPS Dashboard TR
https://technicalramblings.com/blog/setting-grafana-influxdb-telegraf-ups-monitoring-unraid/
Grafana dashboard for displaying UPS stats using the NUT plugin and the maihai/nut-influxdb-exporter docker container. UPS Grafana Guide
Join the Unraid discord!
For support on the dashboard click: ![Discord]()
For the custom theme/skin check out: theme.park
Use the variables to set the UPS datasource ect.
Screenshot:
Updates:
25-05-20: Fixed fill none on graph panels, and relative time on ups load vs time left panel.
