Docker monitoring with select muti node
A simple overview of the most important Docker host and container metrics. (cAdvisor/Prometheus)
The Docker monitoring with select muti node dashboard uses the prometheus data source to create a Grafana dashboard with the graph, singlestat and table panels.
RevisionDescriptionCreated
Docker
Docker
by Grafana Labs
Grafana Labs solution
Easily monitor Docker with Grafana Cloud's out-of-the-box monitoring solution.
Sign up for Grafana Cloud
Create free account
2
Import the dashboard template
Datasource
Dependencies
