This dashboard is templated by consumer group and topic. It will show you a high level of data for the group as a whole, such as the status, the total lag, and the max lagging partition. Then as you scroll down it breaks the status and lag out by every partition for the topic
Collector Configuration Details
This dashboard depends on the burrow input plugin. Details of that plugin can be found in the telegraf docs https://github.com/influxdata/telegraf/blob/master/plugins/inputs/burrow/README.md
Get this dashboard:
10207
