Span metrics
The span metrics processor generates metrics from ingested tracing data, including request, error, and duration (RED) metrics.
Span metrics generate two metrics:
  • A counter that computes requests
  • A histogram that tracks the distribution of durations of all requests
Span metrics are of particular interest if your system is not monitored with metrics, but it has distributed tracing implemented. You get out-of-the-box metrics from your tracing pipeline.
Even if you already have metrics, span metrics can provide in-depth monitoring of your system. The generated metrics will show application level insight into your monitoring, as far as tracing gets propagated through your applications.
Last but not least, span metrics lower the entry barrier for using exemplars. An exemplar is a specific trace representative of measurement taken in a given time interval. Since traces and metrics co-exist in the metrics-generator, exemplars can be automatically added, providing additional value to these metrics.
How to run
To enable service graphs in Tempo/GET, enable the metrics generator and add an overrides section which enables the span-metrics generator. See here for configuration details.
How it works
The span metrics processor works by inspecting every received span and computing the total count and the duration of spans for every unique combination of dimensions. Dimensions can be the service name, the operation, the span kind, the status code and any attribute present in the span.
This processor is designed with the goal to mirror the implementation from the OpenTelemetry Collector of the processor with the same name.
Note
To learn more about cardinality and how to perform a dry run of the metrics generator, see the Cardinality documentation.
Metrics
The following metrics are exported:
MetricTypeLabelsDescription
traces_spanmetrics_latencyHistogramDimensionsDuration of the span
traces_spanmetrics_calls_totalCounterDimensionsTotal count of the span
traces_spanmetrics_size_totalCounterDimensionsTotal size of spans ingested
Note
In Tempo 1.4 and 1.4.1, the histogram metric was called traces_spanmetrics_duration_seconds. This was changed later to be consistent with the metrics generated by the Grafana Agent and the OpenTelemetry Collector.
By default, the metrics processor adds the following labels to each metric: service, span_name, span_kind, status_code, status_message, job, and instance.
  • service - The name of the service that generated the span
  • span_name - The unique name of the span
  • span_kind - The type of span, this can be one of five values:
    • SPAN_KIND_SERVER - The span was generated by a call from another service
    • SPAN_KIND_CLIENT - The span made a call to another service
    • SPAN_KIND_INTERNAL - The span does not have interaction outside of the service it was generated in
    • SPAN_KIND_PUBLISHER - The span created data that was pushed onto a bus or message broker
    • SPAN_KIND_CONSUMER - The span consumed data that was on a bus or messaging system
  • status_code - The result of the span, this can be one of three values:
    • STATUS_CODE_UNSET - Result of the span was unset/unknown
    • STATUS_CODE_OK - The span operation completed successfully
    • STATUS_CODE_ERROR - The span operation completed with an error
  • status_message (optionally enabled) - The message that details the reason for the status_code label
  • job - The name of the job, a combination of namespace and service; only added if metrics_generator_processor_span_metrics_enable_target_info: true
  • instance - The instance ID; only added if metrics_generator_processor_span_metrics_enable_target_info: true
Additional user defined labels can be created using the dimensions configuration option. When a configured dimension collides with one of the default labels (e.g. status_code), the label for the respective dimension is prefixed with double underscore (i.e. __status_code).
Custom labeling of dimensions is also supported using the dimension_mapping configuration option.
An optional metric called traces_target_info using all resource level attributes as dimensions can be enabled in the enable_target_info configuration option.
If you use a ratio-based sampler, you can use the custom sampler below to not lose metric information. However, you also need to set metrics_generator.processor.span_metrics.span_multiplier_key to "X-SampleRatio".
Go
package tracer
import (
	"go.opentelemetry.io/otel/attribute"
	tracesdk "go.opentelemetry.io/otel/sdk/trace"
type RatioBasedSampler struct {
	innerSampler        tracesdk.Sampler
	sampleRateAttribute attribute.KeyValue
func NewRatioBasedSampler(fraction float64) RatioBasedSampler {
	innerSampler := tracesdk.TraceIDRatioBased(fraction)
	return RatioBasedSampler{
		innerSampler:        innerSampler,
		sampleRateAttribute: attribute.Float64("X-SampleRatio", fraction),
func (ds RatioBasedSampler) ShouldSample(parameters tracesdk.SamplingParameters) tracesdk.SamplingResult {
	sampler := ds.innerSampler
	result := sampler.ShouldSample(parameters)
	if result.Decision == tracesdk.RecordAndSample {
		result.Attributes = append(result.Attributes, ds.sampleRateAttribute)
	return result
func (ds RatioBasedSampler) Description() string {
	return "Ratio Based Sampler which gives information about sampling ratio"
Example
Span metrics overview
