Library imports
Note
The Business Charts panel supports the npm library imports since version 6.0.0.
Since version 6.4.0 you can return import with options instead use setOption(options) method.
Additional NPM libraries can be imported to be used in Business Charts panel using import statement.
ecStat library
Additional libraries like ecStat can be loaded dynamically to provide additional functionality. In this example we use setOption(options) method in then method.
js
const options = {};
 * echarts-stat import
import("https://esm.sh/echarts-stat@1.2.0").then(
  ({ default: ecStatImport }) => {
    context.echarts.registerTransform(ecStatImport.transform.regression);
     * setOption method use
    context.panel.chart.setOption(options);
Scatter type graph with imported ecStat library.
ecSimpleTransform library
For next example we use JSON API data source and data example from Apache ECharts website.
Code example for version 6.4.0 and above:
js
 * echarts-simple-transform import
return import("https://esm.sh/@manufac/echarts-simple-transform@2.0.11").then(
  ({ default: ecSimpleTransform }) => {
    context.echarts.registerTransform(ecSimpleTransform.aggregate);
     * return options
    return options;
Boxplot type graph with imported ecSimpleTransform library.
