Extended result
Note
The Business Charts panel supports the extended result object starting from version 5.0.0.
The extended result object allows you to return:
- Configuration
- Options
- Unsubscribe function
return {
version: 2,
config: { notMerge: true },
option: {
tooltip: {
formatter: '{a} <br/>{b} : {c}%'
series: [
type: 'gauge',
detail: {
formatter: '{value}'
data: [
value: 50,
unsubscribe: () => {
console.log('unsubscribeFunction')
};Version
The version is reserved for future improvements. The only supported version is 2.
Configuration
Note
To find more details on configuration options, please see the Apache ECharts library documentation.
Option
The option is the chart configuration in the JSON format described in the Charts Functions.
Unsubscribe
The unsubscribe section allows the addition of JavaScript code which is executed before the object is destroyed.
One of the use cases relates to unsubscription from Grafana events using an event bus.
