Event handling
You can handle specific events while viewing charts, for example, handle mouse events or any other event with the context.panel.chart ( early echartsInstance ) instance.
For more examples and detailed descriptions, please check the Apache ECharts documentation about Events and Actions.
Mouse click
To prevent the event handling multiple times, all previous event handlers may be disabled.
js
 * On Mouse Click
context.panel.chart.off("click");
context.panel.chart.on("click", (params) => {
  context.grafana.notifySuccess(["Event", "On Click"]);
  context.panel.chart.resize(); // to redraw visualization
js
 * On Double Click
context.panel.chart.off("dblclick");
context.panel.chart.on("dblclick", (params) => {
Update of time range
The Data Zoom feature allows you to select a time period on the chart for zooming in.
Once the time range is selected, the event can trigger the update of the dashboard’s time range using the context.grafana.locationService parameter similar to the functionality in native Time Series panel.
Data Zoom feature for Random Walk.
Example
js
const series = context.panel.data.series.map((s) => {
  const sData = s.fields.find((f) => f.type === "number").values;
  const sTime = s.fields.find((f) => f.type === "time").values;
  return {
    type: "line",
    showSymbol: false,
    areaStyle: {
      opacity: 0.1,
    lineStyle: {
      width: 1,
    data: sData.map((d, i) => [sTime[i], d.toFixed(2)]),
 * Enable Data Zoom by default
setTimeout(
    context.panel.chart.dispatchAction({
      type: "takeGlobalCursor",
      key: "dataZoomSelect",
      dataZoomSelectActive: true,
  500
 * Update Time Range on Zoom
context.panel.chart.on("datazoom", function (params) {
  const startValue = params.batch[0]?.startValue;
  const endValue = params.batch[0]?.endValue;
  context.grafana.locationService.partial({ from: startValue, to: endValue });
return {
  backgroundColor: "transparent",
  tooltip: {
    trigger: "axis",
  legend: {
    left: "0",
    bottom: "0",
    data: context.panel.data.series.map((s) => s.refId),
    textStyle: {
      color: "rgba(128, 128, 128, .9)",
  toolbox: {
    feature: {
      dataZoom: {
        yAxisIndex: "none",
        icon: {
          zoom: "path://",
          back: "path://",
      saveAsImage: {},
  xAxis: {
    type: "time",
  yAxis: {
    type: "value",
    min: "dataMin",
  grid: {
    left: "2%",
    right: "2%",
    top: "2%",
    bottom: 24,
    containLabel: true,
  series,
