Data sources
The Business Charts panel supports various data sources that you can use to query data for building charts.
The following code snippet demonstrates how you can retrieve data from your data source to use in the Business Charts panel.
JavaScript
context.panel.data.series.map((s) => {
  if (s.refId === "logo") {
    images = s.fields.find((f) => f.name === "body").values;
  } else if (s.refId === "connections") {
    sources = s.fields.find((f) => f.name === "source").values;
    targets = s.fields.find((f) => f.name === "target").values;
  } else if (s.refId === "nodes") {
    titles = s.fields.find((f) => f.name === "title").values;
    descriptions = s.fields.find((f) => f.name === "description").values;
  • You can use the .map() and .find() JavaScript functions.
  • The refId query retrieves data from a data source. By default, the assigned names look like A, B, and so on. The code above works with the three queries logo, connections, and nodes.
  • name is the name of the data frame column. The code above references the body, source, target, title, and description columns.
  • To work with Grafana 9 and its older versions, you need to use the values.buffer instead of values.
Array of arrays
You can convert one-dimensional arrays with data into multi-dimensional arrays if needed.
  • Fetch values for each field.
  • Combine an array into an array of arrays.
  • Use as series[0] to access the first query, series[1] to access the second query, etc.
JavaScript
const series = context.panel.data.series.map((s) => {
  const rates = s.fields.find((f) => f.name === "Rate").values;
  const calls = s.fields.find((f) => f.name === "Calls").values;
  const names = s.fields.find((f) => f.name === "Name").values;
  return rates.map((d, i) => [d, calls[i], names[i]]);
})[0];
Pie chart using visual mode
We use the Business Input data source for this example.
Build a Pie Chart using a data source.
Example
js
return {
  dataset: {
    source: context.editor.dataset.source,
  tooltip: {
    trigger: "item",
  series: [
      type: "pie",
      radius: "80%",
      emphasis: {
        itemStyle: {
          shadowBlur: 10,
          shadowOffsetX: 0,
          shadowColor: "rgba(0, 0, 0, 0.5)",
Wind speed
The wind speed visualization is one of the advanced examples of what the Business Charts panel can do.
  • Every data point is displayed with a custom arrow.
  • The arrow color indicates the speed.
  • The direction where the arrow points indicates the wind direction.
Building a wind speed chart with custom arrows on the Grafana dashboard
Example
js
let wind;
  const time = s.fields.find((f) => f.name === "Time").values;
  const value = s.fields.find((f) => f.name === "Speed").values;
  const rotate = s.fields.find((f) => f.name === "Direction").values;
  Set Wind from 3 arrays
  wind = time.map((id, index) => {
    return { symbolRotate: rotate[index], value: [time[index], value[index]] };
return {
  xAxis: {
    type: "time",
  yAxis: {
    type: "value",
  visualMap: {
    orient: "horizontal",
    left: "center",
    min: 0,
    max: 10,
    text: ["High", "Low"],
    dimension: 1,
    inRange: {
      color: ["#65B581", "#FFCE34", "#FD665F"],
  series: [
      data: wind,
      type: "line",
      symbol:
        "path://M31 24.7343L21.7917 24.7343V0L9.20826 0L9.20826 24.7343H0L15.5 45L31 24.7343Z",
      symbolSize: 20,
      lineStyle: {
        width: 0.3,
Circular graph
Visualize a circular graph using a data source.
Example
js
let nodes, links;
 * Data Source data
    var titles = s.fields.find((f) => f.name === "sIp").values;
    var symbolSizes = s.fields.find((f) => f.name === "bytes").values;
    var categories = s.fields.find((f) => f.name === "Count").values;
    nodes = titles.map((title, i) => ({
      symbolSize: symbolSizes[i],
      value: symbolSizes[i],
      category: categories[i],
      label: {
        show: symbolSizes[i] > 1,
  if (s.refId === "links") {
    var sources =
      s.fields.find((f) => f.name === "sIp").values.buffer ||
    var targets =
      s.fields.find((f) => f.name === "dIp").values.buffer ||
      s.fields.find((f) => f.name === "dIp").values;
    links = sources.map((source, i) => ({
      source: source,
      target: targets[i],
 * Categories
const categories = [{ name: "1" }, { name: "2" }, { name: "3" }];
return {
  tooltip: {},
  legend: [
      data: categories.map((a) => a.name),
  animationDurationUpdate: 1500,
  animationEasingUpdate: "quinticInOut",
  series: [
      type: "graph",
      layout: "circular",
      circular: {
        rotateLabel: true,
      data: nodes,
      links: links,
      categories: categories,
      roam: true,
      label: {
        position: "right",
        formatter: "{b}",
      lineStyle: {
        color: "source",
        curveness: 0.3,
