Content wrapping
The Content > Wrap automatically in paragraphs option:
  • If enabled, every row of the content wraps in paragraph <p> tags.
  • If disabled, rows do not wrap in paragraph <p> tags.
The following example shows Content that does not contain any spaces. In this case, the Content > Wrap automatically in paragraphs parameter is irrelevant. Both Enabled and Disabled modes generate the same output.
No spaces in the Content, the wrap parameter is irrelevant. The dashboard looks as expected for both, Enabled and Disabled, modes.
The following example shows Content that contains one empty line and how the form is interpreted with Enabled and Disabled modes.
The wrap option effect on the Content with space in it.
The code used in the examples above:
HTML
<figure>
  <ul>
    <li>In Progress : 34</li>
    <li>Completed : 5</li>
  </ul>
</figure>
