📢 Registration + agenda now live
Explore the latest Grafana Cloud and AI solutions, learn tips & tricks from demos and hands-on workshops, and get actionable advice to advance your observability strategy. Register now and get 50% off - limited tickets available (while they last!).
As of 2025-03-11, Grafana OnCall OSS has entered maintenance mode,
and will be archived on 2026-03-24. No further feature development will occur;
however, we will still provide fixes for critical bugs and for valid CVEs with a CVSS
score of 7.0 or higher. For more information, refer to our blog post.
curl"{{API_URL}}/api/v1/shift_swaps/"\--request POST \--header"Authorization: meowmeowmeow"\--header"Content-Type: application/json"\--data'{
"schedule": "SRJWJCMKD68AL",
"swap_start": "2026-06-11T00:00:00Z",
"swap_end": "2026-07-19T22:00:00Z",
"description": "Anyone to cover my shifts?",
"beneficiary": "UWJWIN8MQ1GYL"
The above command returns JSON structured in the following way:
JSON
{"benefactor":null,"beneficiary":"UWJWIN8MQ1GYL","created_at":"2023-08-11T19:20:17.064677Z","description":"Anyone to cover my shifts?","id":"SSRG1TDNBMJQ1NC","schedule":"SRJWJCMKD68AL","shifts":[{"all_day":false,"calendar_type":0,"end":"2026-06-11T03:00:00Z","is_empty":false,"is_gap":false,"is_override":false,"missing_users":[],"priority_level":2,"shift":{"pk":"OTI13GNNE5V1L"},"source":"web","start":"2026-06-11T00:00:00Z","users":[{"avatar_full":"http://avatar.url","display_name":"testing","email":"testing","pk":"UWJWIN8MQ1GYL","swap_request":{"pk":"SSRG1TDNBMJQ1NC"}}]}],"status":"open","swap_end":"2026-07-19T22:00:00.000000Z","swap_start":"2026-06-11T00:00:00.000000Z","updated_at":"2023-08-11T19:20:17.064922Z"}
Parameter
Unique
Required
Description
schedule
No
Yes
ID of the schedule.
swap_start
No
Yes
Start date/time for the swap request. Must be a ISO 8601 formatted datetime string.
swap_end
No
No
End date/time for the swap request. Must be a ISO 8601 formatted datetime string.
description
No
Optional
A description message to be displayed along the request.
beneficiary
No
Yes
ID of the user requesting the swap.
HTTP request
POST {{API_URL}}/api/v1/shift_swaps/
Get a shift swap request
shell
curl"{{API_URL}}/api/v1/shift_swaps/SSRG1TDNBMJQ1NC/"\--request GET \--header"Authorization: meowmeowmeow"\--header"Content-Type: application/json"
JSON
HTTP request
GET {{API_URL}}/api/v1/shift_swaps/<SHIFT_SWAP_REQUEST_ID>/
List shift swap requests
shell
curl"{{API_URL}}/api/v1/shift_swaps/"\--request GET \--header"Authorization: meowmeowmeow"\--header"Content-Type: application/json"
JSON
{"count":2,"current_page_number":1,"next":null,"page_size":50,"previous":null,"results":[{"benefactor":"UWJWIN8MQ1GYL","beneficiary":"UCGEIXI1MR1NZ","created_at":"2023-08-07T18:44:15.249679Z","description":"Taking a few days off.","id":"SSRK2EH2TR6E4F9","schedule":"SRZZFY1QI9FLL","status":"taken","swap_end":"2024-09-29T03:00:18.000000Z","swap_start":"2024-09-26T03:00:18.000000Z","updated_at":"2024-08-07T18:44:15.249960Z"},{"benefactor":null,"beneficiary":"UWJWIN8MQ1GYL","created_at":"2023-08-11T19:20:17.064677Z","description":"Anyone to cover my shifts?","id":"SSRG1TDNBMJQ1NC","schedule":"SRJWJCMKD68AL","status":"open","swap_end":"2026-07-19T22:00:00.000000Z","swap_start":"2026-06-11T00:00:00.000000Z","updated_at":"2023-08-11T19:20:17.064922Z"}],"total_pages":1}
Note: The response is
paginated. You may need to make multiple requests to get all records.
The following available filter parameters may be provided as a GET arguments:
starting_after (an ISO 8601 timestamp string, filter requests starting after the specified datetime)
schedule_id (Exact match, schedule ID)
beneficiary (Exact match, user ID)
benefactor (Exact match, user ID)
open_only (set to true to filter active untaken requests only)
JSON
{"benefactor":null,"beneficiary":"UWJWIN8MQ1GYL","created_at":"2023-08-11T19:20:17.064677Z","description":"Anyone to cover my shifts?","id":"SSRG1TDNBMJQ1NC","schedule":"SRJWJCMKD68AL","shifts":[{"all_day":false,"calendar_type":0,"end":"2026-06-11T03:00:00Z","is_empty":false,"is_gap":false,"is_override":false,"missing_users":[],"priority_level":2,"shift":{"pk":"OTI13GNNE5V1L"},"source":"web","start":"2026-06-11T00:00:00Z","users":[{"avatar_full":"http://avatar.url","display_name":"testing","email":"testing","pk":"UWJWIN8MQ1GYL","swap_request":{"pk":"SSRG1TDNBMJQ1NC"}}]}],"status":"open","swap_end":"2026-07-20T22:00:00.000000Z","swap_start":"2026-06-11T00:00:00.000000Z","updated_at":"2023-08-11T19:45:53.096811Z"}
HTTP request
PUT {{API_URL}}/api/v1/shift_swaps/<SHIFT_SWAP_REQUEST_ID>/
curl"{{API_URL}}/api/v1/shift_swaps/SSRG1TDNBMJQ1NC/take"\--request POST \--header"Authorization: meowmeowmeow"\--header"Content-Type: application/json"\--data'{
"benefactor": "UCGEIXI1MR1NZ"
JSON
{"benefactor":"UCGEIXI1MR1NZ","beneficiary":"UWJWIN8MQ1GYL","created_at":"2023-08-11T19:20:17.064677Z","description":"Anyone to cover my shifts?","id":"SSRG1TDNBMJQ1NC","schedule":"SRJWJCMKD68AL","shifts":[{"all_day":false,"calendar_type":0,"end":"2026-06-11T03:00:00Z","is_empty":false,"is_gap":false,"is_override":false,"missing_users":[],"priority_level":2,"shift":{"pk":"OTI13GNNE5V1L"},"source":"web","start":"2026-06-11T00:00:00Z","users":[{"avatar_full":"http://avatar.url","display_name":"anotherone","email":"anotherone","pk":"UCGEIXI1MR1NZ","swap_request":{"pk":"SSRG1TDNBMJQ1NC","user":{"avatar_full":"http://avatar.url","display_name":"testing","email":"testing","pk":"UWJWIN8MQ1GYL"}}}]}],"status":"taken","swap_end":"2026-07-20T22:00:00.000000Z","swap_start":"2026-06-11T00:00:00.000000Z","updated_at":"2023-08-11T19:51:38.622037Z"}
Parameter
Unique
Required
Description
benefactor
No
Yes
ID of the user taking the swap.
HTTP request
POST {{API_URL}}/api/v1/shift_swaps/<SHIFT_SWAP_REQUEST_ID>/take
