Caution
As of 2025-03-11, Grafana OnCall OSS has entered maintenance mode, and will be archived on 2026-03-24. No further feature development will occur; however, we will still provide fixes for critical bugs and for valid CVEs with a CVSS score of 7.0 or higher. For more information, refer to our blog post.
Shift swap requests HTTP API
Create a shift swap request
Required permission: grafana-oncall-app.schedules:write
curl "{{API_URL}}/api/v1/shift_swaps/" \
--request POST \
--header "Authorization: meowmeowmeow" \
--header "Content-Type: application/json" \
--data '{
"schedule": "SRJWJCMKD68AL",
"swap_start": "2026-06-11T00:00:00Z",
"swap_end": "2026-07-19T22:00:00Z",
"description": "Anyone to cover my shifts?",
"beneficiary": "UWJWIN8MQ1GYL"
}'The above command returns JSON structured in the following way:
"benefactor" : null,
"beneficiary" : "UWJWIN8MQ1GYL",
"created_at" : "2023-08-11T19:20:17.064677Z",
"description" : "Anyone to cover my shifts?",
"id" : "SSRG1TDNBMJQ1NC",
"schedule" : "SRJWJCMKD68AL",
"shifts" : [
"all_day" : false,
"calendar_type" : 0,
"end" : "2026-06-11T03:00:00Z",
"is_empty" : false,
"is_gap" : false,
"is_override" : false,
"missing_users" : [],
"priority_level" : 2,
"shift" : {
"pk" : "OTI13GNNE5V1L"
"source" : "web",
"start" : "2026-06-11T00:00:00Z",
"users" : [
"avatar_full" : "http://avatar.url",
"display_name" : "testing",
"email" : "testing",
"pk" : "UWJWIN8MQ1GYL",
"swap_request" : {
"pk" : "SSRG1TDNBMJQ1NC"
"status" : "open",
"swap_end" : "2026-07-19T22:00:00.000000Z",
"swap_start" : "2026-06-11T00:00:00.000000Z",
"updated_at" : "2023-08-11T19:20:17.064922Z"
}HTTP request
POST {{API_URL}}/api/v1/shift_swaps/
Get a shift swap request
Required permission: grafana-oncall-app.schedules:read
curl "{{API_URL}}/api/v1/shift_swaps/SSRG1TDNBMJQ1NC/" \
--request GET \
--header "Content-Type: application/json"The above command returns JSON structured in the following way:
"shifts" : [
"all_day" : false,
"is_empty" : false,
"is_gap" : false,
"shift" : {
"source" : "web",
"users" : [
"swap_request" : {
"status" : "open",
}HTTP request
GET {{API_URL}}/api/v1/shift_swaps/<SHIFT_SWAP_REQUEST_ID>/
List shift swap requests
--request GET \
"count" : 2,
"current_page_number" : 1,
"next" : null,
"page_size" : 50,
"previous" : null,
"results" : [
"benefactor" : "UWJWIN8MQ1GYL",
"beneficiary" : "UCGEIXI1MR1NZ",
"created_at" : "2023-08-07T18:44:15.249679Z",
"description" : "Taking a few days off.",
"id" : "SSRK2EH2TR6E4F9",
"schedule" : "SRZZFY1QI9FLL",
"status" : "taken",
"swap_end" : "2024-09-29T03:00:18.000000Z",
"swap_start" : "2024-09-26T03:00:18.000000Z",
"updated_at" : "2024-08-07T18:44:15.249960Z"
"status" : "open",
"total_pages" : 1
}Note: The response is paginated. You may need to make multiple requests to get all records.
The following available filter parameters may be provided as a GET arguments:
starting_after(an ISO 8601 timestamp string, filter requests starting after the specified datetime)schedule_id(Exact match, schedule ID)beneficiary(Exact match, user ID)benefactor(Exact match, user ID)open_only(set totrueto filter active untaken requests only)
HTTP request
Update a shift swap request
--request PUT \
--data '{
"swap_end": "2026-07-20T22:00:00Z"
"shifts" : [
"all_day" : false,
"is_empty" : false,
"is_gap" : false,
"shift" : {
"source" : "web",
"users" : [
"swap_request" : {
"status" : "open",
"swap_end" : "2026-07-20T22:00:00.000000Z",
"updated_at" : "2023-08-11T19:45:53.096811Z"
}HTTP request
PUT {{API_URL}}/api/v1/shift_swaps/<SHIFT_SWAP_REQUEST_ID>/
Delete a shift swap request
--request DELETE \
--header "Content-Type: application/json"HTTP request
DELETE {{API_URL}}/api/v1/shift_swaps/<SHIFT_SWAP_REQUEST_ID>/
Take a shift swap request
curl "{{API_URL}}/api/v1/shift_swaps/SSRG1TDNBMJQ1NC/take" \
--request POST \
--data '{
"benefactor": "UCGEIXI1MR1NZ"
"benefactor" : "UCGEIXI1MR1NZ",
"shifts" : [
"all_day" : false,
"is_empty" : false,
"is_gap" : false,
"shift" : {
"source" : "web",
"users" : [
"display_name" : "anotherone",
"email" : "anotherone",
"pk" : "UCGEIXI1MR1NZ",
"swap_request" : {
"pk" : "SSRG1TDNBMJQ1NC",
"user" : {
"status" : "taken",
"updated_at" : "2023-08-11T19:51:38.622037Z"
}HTTP request
POST {{API_URL}}/api/v1/shift_swaps/<SHIFT_SWAP_REQUEST_ID>/take
