Configure the OpenTelemetry Collector to write metrics into Mimir
When using the OpenTelemetry Collector, you can write metrics into Mimir via two options: prometheusremotewrite and otlphttp.
We recommend using the prometheusremotewrite exporter when possible because the remote write ingest path is tested and proven at scale.
Remote Write
For the Remote Write, use the prometheusremotewrite exporter in the Collector:
In the exporters section add:
YAML
exporters:
  prometheusremotewrite:
    endpoint: http://<mimir-endpoint>/api/v1/push
And enable it in the service.pipelines:
YAML
service:
  pipelines:
    metrics:
      receivers: [...]
      processors: [...]
      exporters: [..., prometheusremotewrite]
If you want to authenticate using basic auth, we recommend the basicauth extension:
YAML
extensions:
  basicauth/prw:
    client_auth:
      username: username
      password: password
exporters:
    auth:
      authenticator: basicauth/prw
service:
  extensions: [basicauth/prw]
  pipelines:
    metrics:
      receivers: [...]
      processors: [...]
OTLP
Mimir supports native OTLP over HTTP. To configure the collector to use the OTLP interface, you use the otlphttp exporter:
YAML
exporters:
  otlphttp:
    endpoint: http://<mimir-endpoint>/otlp
And enable it in service.pipelines:
YAML
service:
  pipelines:
    metrics:
      receivers: [...]
      processors: [...]
      exporters: [..., otlphttp]
YAML
extensions:
  basicauth/otlp:
    client_auth:
      username: username
      password: password
exporters:
  otlphttp:
    auth:
      authenticator: basicauth/otlp
service:
  extensions: [basicauth/otlp]
  pipelines:
    metrics:
      receivers: [...]
      processors: [...]
Format considerations
We follow the official OTLP Metric points to Prometheus specification.
You might experience the following common issues:
  • Dots (.) are converted to _
    Prometheus metrics do not support . and - characters in metric or label names. Prometheus converts these characters to _.
    For example:
    requests.duration{http.status_code=500, cloud.region=us-central1} in OTLP
    requests_duration{http_status_code=”500”, cloud_region=”us-central1”} in Prometheus
  • Resource attributes are added to the target_info metric.
    However, <service.namespace>/<service.name> or <service.name> (if the namespace is empty), is added as the label job, and service.instance.id is added as the label instance to every metric.
    For details, see the OpenTelemetry Resource Attributes specification.
