Grafana Mimir query engine
The Mimir Query Engine (MQE) is an alternative to Prometheus’ query engine. You can use it in queriers to evaluate PromQL queries.
MQE produces equivalent results to Prometheus’ engine, generally uses less memory and CPU than Prometheus’ engine, and evaluates queries at least as fast, if not faster. It supports all stable PromQL features and transparently falls back to Prometheus' engine for queries that use unsupported features.
How to enable MQE
MQE is enabled by default. To disable it, either set the
-querier.query-engine=prometheus CLI flag on queriers or set the equivalent YAML
configuration file option.
Fallback to Prometheus’ engine
By default, MQE falls back to Prometheus’ engine for any queries that use unsupported features.
To disable this behaviour, either set the -querier.enable-query-engine-fallback=false
CLI flag on queriers, or set the equivalent YAML configuration file option. If fallback
is disabled and MQE receives a query it does not support, then the query fails.
To force a query supported by MQE to use Prometheus’ engine, add the
X-Mimir-Force-Prometheus-Engine: true HTTP header to the query request. This header only
has an effect if fallback is enabled.
Query memory consumption limit
MQE supports enforcing a per-query memory consumption limit. This allows you to ensure that a single memory-hungry query cannot monopolize a large proportion of available memory in a querier, or cause it to exhaust all available memory and crash.
While evaluating a query, MQE estimates the memory consumed by the query, such as memory used
for the final result and any intermediate calculations, and stops the query with an
err-mimir-max-estimated-memory-consumption-per-query
error if the estimate exceeds the configured limit.
The estimate is based on the memory consumed by samples currently held in memory for query evaluation. This includes both raw samples decoded from chunks, and samples held in memory as intermediate results of calculations or as the final result. It also includes some other large sources of memory consumption for intermediate results.
This estimate has the following limitations:
- It doesn’t consider the memory consumed by series labels.
- It doesn’t consider the memory consumed by chunks that are currently in memory. However, the maximum chunks and maximum chunks bytes limits continue to be enforced.
- It makes an assumption about the memory consumed by each native histogram, rather than accurately calculating the memory consumed by each histogram.
By default, no limit is enforced. To configure the default limit for all tenants, set either
the -querier.max-estimated-memory-consumption-per-query CLI flag, or set the
equivalent YAML configuration file option. You can override this default limit on a per-tenant
basis by setting max_estimated_memory_consumption_per_query for that tenant. Setting the
limit to 0 disables it.
The limit is not enforced for queries that run through Prometheus’ engine, and setting the limit has no impact if MQE is disabled or if the query falls back to Prometheus’ engine.
Known differences compared to Prometheus’ engine
The following are known differences between MQE and Prometheus’ engine:
Binary operations that produce no series
If MQE can determine that a binary operation such as +, -, / or and produce no series
based on the series labels on both sides, it skips evaluating both sides.
For example, if the query is foo / bar, and foo selects a single series foo{env="test"}, and
bar selects a single series bar{env="prod"}, then the query cannot produce any series and so the
data for each side is not evaluated.
This has some noticeable side effects, including:
aborted stream because query was cancelled: context canceled: query execution finishedmight be logged by the querier, as streaming data from ingesters and store-gateways is aborted without reading all the data, as it isn’t needed.Some annotations aren’t emitted. For example, if the query above was
rate(foo[1m]) / sum(rate(bar[1m])), Prometheus’ engine emits annotations such asmetric might not be a counter, name does not end in _total/_sum/_count/_bucket: "foo"andmetric might not be a counter, name does not end in _total/_sum/_count/_bucket: "bar". In contrast, MQE doesn’t emit these annotations, as they are only emitted during the evaluation of the series data, and not during the evaluation of the series labels.found duplicate series for the match grouperrors aren’t returned by MQE if a match group has no series on one side but multiple series on the other side and those series have samples that conflict with each other.
topk and bottomk
MQE and Prometheus’ engine produce different results for queries that use topk
and bottomk if different series have samples with the same values. Prometheus’ engine does not
have deterministic behavior in this case and selects different series on each evaluation of the
query. MQE’s implementation differs from Prometheus’ engine, which can also lead to different results.
