Add Metrics Drilldown visualization to a dashboard
Dashboards help you create a curated set of visualizations that you can reference for ongoing monitoring.
To add a Metrics Drilldown visualization to a dashboard, complete the following steps:
- On the toolbar at the top of the Explore page, click Add > Add to dashboard, then click Open dashboard.
On the Add panel to dashboard dialog box, perform one of the following:
- To add the visualization to a new dashboard, click New dashboard.
- To add the visualization to an existing dashboard, click Existing dashboard and select a dashboard from the list.
The visualization appears in a dashboard.
- Click Save dashboard located in the upper-right of the page.
- Enter a title and description for your dashboard, select a folder if applicable, and click Save.
