Monitor and validate results
After reviewing and applying recommendations — or using other customization options — you can now verify that your setup is delivering the results you expect.
Use the overview dashboard for a quick, visual summary of how your applied rules are reducing time series volume.
To validate results, complete the following steps:
After reviewing and applying recommendations, or using other customization options, you can now verify that your setup is delivering the results you expect.
Use the Overview dashboard for a quick, visual summary of how your applied rules are reducing time series volume.
- Navigate to Adaptive Telemetry > Adaptive Metrics.
- From the Overview tab, select the segment you want to review (for example, alerting, frontend, backend) from the Segment dropdown.
- Use the time range picker to include when you first applied rules, and the period after the changes.
- Check the graph to confirm that there was a reduction after applying the rules.
- Click Explore to view more detail on the underlying metric or query.
In the next milestone, you’ll reach your journey conclusion.
At this point in your journey, you can explore the following paths:
