Slide 9 of 10
Operations at Level 1
You don’t wait for Level 4 to use these
From day one with infrastructure monitoring, you have access to powerful operational tools. The same tools work at every level; only the scope changes.
Operations grow with you showing how alerting, dashboards, and SLOs apply at each level with expanding scope
Here’s what they look like at Level 1
Alerting
What to alert onExample
Host healthCPU > 90%, memory > 85%, disk > 80%
Integration statusMySQL connection failed, NGINX not responding
Basic availabilityHost unreachable, service down
Dashboards
Dashboard typeWhat you see
Pre-built integration dashboardsComes with every integration for instant visibility
Infrastructure overviewAll hosts, key metrics at a glance
Custom dashboardsCombine metrics from multiple integrations
Investigation
ToolHow you use it at Level 1
ExploreAd-hoc queries on metrics and logs
Drilldown appsClick from dashboard → detailed investigation
Logs → Metrics correlation“What was happening on this host when CPU spiked?”
SLOs
SLO ExampleTarget
Host uptime99.9% of hosts healthy
Database availability99.5% connection success rate
These same tools grow with you. At Level 2, you’ll alert on services. At Level 3, on transactions. At Level 4, on custom metrics. The concepts stay the same; only the scope changes.
Script
Here’s something important: you don’t have to wait until Level 4 to use operational tools like alerting and dashboards. They’re available from day one.
At Level 1, your alerts are infrastructure-focused. CPU over 90 percent? Alert. Disk filling up past 80 percent? Alert. Database connection failed? Alert. These are the basics, and they’re incredibly valuable.
Your dashboards come largely for free. Every integration includes pre-built visualizations. And when you need to dig deeper, Explore lets you run ad-hoc queries against your metrics and logs.
You can even set up SLOs at this level, like targeting 99.9 percent host uptime. It’s more advanced, but it’s available when you’re ready.
The beautiful thing is that these same operational tools grow with you. At Level 2, you’ll alert on service health. At Level 3, on transaction patterns. At Level 4, on custom metrics. The concepts stay the same; only the scope changes.
