Workaround to calculate iteration_duration
A common requested case is to track the iteration_duration metric without including time spent for setup and teardown functions.
This feature is not yet available but a threshold on iteration_duration or any pre-existing metrics can be used as a workaround.
It’s based on the concept of creating thresholds for sub-metrics created by tags for the required scope and setting the criteria that always pass. It works with any enabled tags that already works with threshold, for example:
iteration_duration{scenario:default}generates a sub-metric collecting samples only for the default scenario’s iteration.scenario:defaultis used because that’s the internal k6 scenario name when we haven’t specifiedoptions.scenarios` explicitly and are just using the execution shortcuts instead.iteration_duration{group:::setup}oriteration_duration{group:::teardown}create sub-metrics collecting the duration only forsetupandteardown.k6implicitly creates groups forsetupandteardown, and::is the group separator.http_req_duration{scenario:default}can be useful as well for isolating executed long-running requests.
import { sleep } from 'k6';
import http from 'k6/http';
export const options = {
vus: 1,
iterations: 1,
thresholds: {
'iteration_duration{scenario:default}': [`max>=0`],
'iteration_duration{group:::setup}': [`max>=0`],
'iteration_duration{group:::teardown}': [`max>=0`],
'http_req_duration{scenario:default}': [`max>=0`],
export function setup() {
http.get('https://httpbin.test.k6.io/delay/5');
export default function () {
http.get('http://test.k6.io/?where=default');
sleep(0.5);
export function teardown() {
http.get('https://httpbin.test.k6.io/delay/3');
sleep(5);
}Dedicated sub-metrics have been generated collecting samples only for the scope defined by thresholds:
http_req_duration..............: avg=1.48s min=101.95ms med=148.4ms max=5.22s p(90)=4.21s p(95)=4.71s
{ expected_response:true }...: avg=1.48s min=101.95ms med=148.4ms max=5.22s p(90)=4.21s p(95)=4.71s
✓ { scenario:default }.........: avg=148.4ms min=103.1ms med=148.4ms max=193.7ms p(90)=184.64ms p(95)=189.17ms
iteration_duration.............: avg=5.51s min=1.61s med=6.13s max=8.81s p(90)=8.27s p(95)=8.54s
✓ { group:::setup }............: avg=6.13s min=6.13s med=6.13s max=6.13s p(90)=6.13s p(95)=6.13s
✓ { group:::teardown }.........: avg=8.81s min=8.81s med=8.81s max=8.81s p(90)=8.81s p(95)=8.81s
✓ { scenario:default }.........: avg=1.61s min=1.61s med=1.61s max=1.61s p(90)=1.61s p(95)=1.61s
