HTTP Requests
When you create a new load test, one of the first steps is to define the HTTP requests that you would like to test.
Make HTTP Requests
A GET request looks like this:
import http from 'k6/http';
export default function () {
http.get('http://test.k6.io');
}For something slightly more complex, this example shows a POST request with an email/password authentication payload:
const url = 'http://test.k6.io/login';
const payload = JSON.stringify({
email: 'aaa',
password: 'bbb',
const params = {
headers: {
'Content-Type': 'application/json',
http.post(url, payload, params);
}Available methods
The http module handles all kinds of HTTP requests and methods.
Follow redirects
By default, k6 automatically follows a set number of redirects before stopping and returning the last response. You can customize this by using:
- The
maxRedirectsoption to customize the number of redirects globally. Refer to Max redirects for more details. - The
Params.redirectsproperty to customize the number of redirects for a specific request, which overrides themaxRedirectsoption. Refer to Params for more details.
HTTP Request Tags
k6 automatically applies tags to your HTTP requests. You can use these tags to filter your results and organize your analysis.
The following snippet shows a JSON example of how a test-result data point is logged. In this example, the metric is the duration of an HTTP request.
Note how the tags object groups data.
"type": "Point",
"metric": "http_req_duration",
"data": {
"time": "2017-06-02T23:10:29.52444541+02:00",
"value": 586.831127,
"tags": {
"expected_response": "true",
"group": "",
"method": "GET",
"name": "http://test.k6.io",
"scenario": "default",
"status": "200",
"url": "http://test.k6.io"
}Group URLs under one tag
By default, tags have a name field that holds the value of the request URL.
If your test has dynamic URL paths, you might not want this behavior, which could bring a large number of unique URLs into the metrics stream.
For example, the following code accesses 100 different URLs:
for (let id = 1; id <= 100; id++) {
http.get(`http://example.com/posts/${id}`);
// tags.name=\"http://example.com/posts/1\",
// tags.name=\"http://example.com/posts/2\",You might prefer to report this data in a single metric:
To aggregate data from dynamic URLs, explicitly set a name tag:
http.get(`http://example.com/posts/${id}`, {
tags: { name: 'PostsItemURL' },
// tags.name=\"PostsItemURL\",
// tags.name=\"PostsItemURL\",That code would produce JSON output like this:
// For http://example.com/1, note that the url is not present in the JSON.
"type":"Point",
"metric":"http_req_duration",
"data": {
"time":"2017-06-02T23:10:29.52444541+02:00",
"value":586.831127,
"tags": {
"method":"GET",
"name":"PostsItemURL",
"status":"200",
"url":"PostsItemURL"
// and for http://example.com/2
"type":"Point",
"data": {
"time":"2017-06-02T23:10:29.58582529+02:00",
"value":580.839273,
"tags": {
"method":"GET",
"status":"200",
}Note how these two objects have the same name, despite having different URLs.
If you filter the results for the tag name: PostsItemURL, the results include all data points from all 100 URLs.
As an alternative, you can also use the http.url wrapper to set the name tag with a string template value:
http.get(http.url`http://example.com/posts/${id}`);
// tags.name="http://example.com/posts/${}",
