Web dashboard
k6 provides a built-in web dashboard that you can enable to visualize and monitor your tests results in real-time.
The dashboard provides a real-time overview of the performance observed by k6 while a test is running, and can help you identify potential reliability issues as they occur.
How to use
The web dashboard is a built-in feature of k6. You can enable it by setting the K6_WEB_DASHBOARD
environment variable to true
when running your test script, for example:
K6_WEB_DASHBOARD=true k6 run script.js
K6_WEB_DASHBOARD=true ./k6 run script.js
/ __________ \ |__| \__\ \_____/ .io
execution: local
script: ../extensions/xk6-dashboard/script.js
web dashboard: http://127.0.0.1:5665
output: -
By default, the web dashboard is available on localhost port 5665
. You can change the host and port by using the dashboard options.
Note
The k6 process waits to exit as long as there is at least one open browser window for the dashboard extension. In this way, the report can be downloaded, for example, even after the test has been completed.
In certain environments, it is not allowed that the k6 process does not exit after the test run (e.g CI/CD pipeline). In this case, it is advisable to disable the HTTP port (with the
-1
value of port parameter).
Generate HTML test reports
You can generate detailed, downloadable HTML reports directly from the web dashboard or the command line. These reports are self-contained, making them ideal for sharing with your team.
Generate report from web dashboard
To generate a report from the web dashboard, click Report on the dashboard’s menu.
Generate report from the command line
To automatically generate a report from the command line once the test finishes running, use the K6_WEB_DASHBOARD_EXPORT
option. For example:
K6_WEB_DASHBOARD=true K6_WEB_DASHBOARD_EXPORT=html-report.html k6 run script.js
Dashboard options
The web dashboard can be configured using environment variables:
Environment variable | Description | Default value |
K6_WEB_DASHBOARD | Enable the web dashboard | false |
K6_WEB_DASHBOARD_HOST | Host to bind the web dashboard to | localhost |
K6_WEB_DASHBOARD_PORT | Port to bind the web dashboard to | 5665 |
K6_WEB_DASHBOARD_PERIOD | Period in seconds to update the web dashboard | 10s |
K6_WEB_DASHBOARD_OPEN | Open the web dashboard in the default browser | false |
K6_WEB_DASHBOARD_EXPORT | Filename to automatically export the HTML test report to at the end of the test run. By default, the value is empty and the report isn’t exported. | `` |
