This is documentation for the next version of Grafana k6 documentation. For the latest stable release, go to the latest version.
Documentationbreadcrumb arrow Grafana k6breadcrumb arrow Using k6breadcrumb arrow Analyze script dependencies
k6 deps command
The k6 deps command analyzes your k6 test script and outputs information about the dependencies your script uses.
Usage
Bash
k6 deps [options] <script>
Description
When you run k6 deps, k6 analyzes your test script and its imports to identify k6 extensions (such as k6/x/faker, k6/x/redis) and k6 itself that your script uses.
The command outputs dependency information in human-readable format by default, or JSON format with the --json flag. You can use this information to:
  • Understand what k6 extensions your script uses
  • Share dependency information with your team
  • Use it to know if you need a custom binary or if the current one can run the script
The command, like automatic extension resolution, is only able to find dependencies using import/export syntax and “use” directives in already found files. It doesn’t follow potential require calls.
The command also takes into account any provided dependency manifest and applies it during k6 run.
Options
OptionDescription
--jsonOutput dependency information in JSON format. Without this flag, the output is human-readable.
Examples
Generate dependency information
Analyze your test script and output dependency information:
Bash
k6 deps script.js
This outputs dependency information in human-readable format to stdout.
Generate JSON output
Output the dependency information in JSON format:
Bash
k6 deps --json script.js
Output format
The k6 deps command outputs dependency information in human-readable format by default. When using the --json flag, the output is a JSON object.
Human-readable output
The default human-readable output shows:
  • Build Dependencies: Lists k6 extensions and k6 itself with version constraints (or (none) if there are no build dependencies)
  • Imports: Lists all imports including file paths and module names
  • Custom Build Required: Indicates yes or no whether a custom build is required
Example:
Build Dependencies:
  k6: >1.2.0
  k6/x/faker: *
Imports:
  file:///path/to/script.js
  k6/execution
  k6/x/faker
Custom Build Required: yes
JSON output
When using the --json flag, the output is a JSON object with three fields:
  • buildDependencies: An object mapping k6 extension names (or k6 itself) to version constraints
  • imports: An array of strings listing all imports
  • customBuildRequired: A boolean indicating whether a custom build is required
Example:
JSON
  "buildDependencies": {
    "k6": ">1.2.0",
    "k6/x/faker": "*"
  "imports": [
    "file:///path/to/script.js",
    "k6/execution",
    "k6/x/faker"
  "customBuildRequired": true
