About Grafana panel libraries
A library panel is a reusable panel that you can use in any dashboard. When you make a change to a library panel, that change propegates to all instances of where the panel is used. Library panels streamline reuse of panels across multiple dashboards.
You can save a library panel in a folder alongside saved dashboards.
