Developing Backend Plugins
Enterprise Open source
Backend Plugins
Grafana added support for plugins in Grafana 3.0 and this enabled the Grafana community to create panel plugins and data source plugins. It was wildly successful and has made Grafana much more useful as you can integrate it with anything and do any type of custom visualization that you want. However, these plugin hooks are on the frontend only and we also want to provide hooks into the Grafana backend to allow the community to extend and improve Grafana in new ways.
Once Grafana introduced the alerting feature, external data source plugins needed a backend component for the Grafana server to execute queries for evaluating alert rules (as the alerting engine cannot call frontend JavaScript code). So the the obvious first backend plugin type is the Datasource backend plugin and it is a new component for an existing data source plugin. This new plugin type will enable alerting for external data source plugins but can also be used for achieving different goals such as query caching, request proxying, custom authentication methods, and more.
Grafana’s Backend Plugin System
The backend plugin feature is implemented with the HashiCorp plugin system which is a Go plugin system over RPC. Grafana server launches each plugin as a subprocess and communicates with it over RPC. This approach has a number of benefits:
  • Plugins can’t crash your grafana process: a panic in a plugin doesn’t panic the server.
  • Plugins are easy to develop: just write a Go application and go build (or use any other language which supports gRPC).
  • Plugins can be relatively secure: The plugin only has access to the interfaces and args given to it, not to the entire memory space of the process.
Data source plugin interface
The plugin interface is very simple and described as a Go interface type in Grafana and as a general RPC service in the corresponding .proto (protocol buffer file):
Go
type TsdbQueryEndpoint interface {
  Query(ctx context.Context, ds *models.DataSource, query *TsdbQuery) (*Response, error)
protobuf
service DatasourcePlugin {
  rpc Query(DatasourceRequest) returns (DatasourceResponse);
Thus, a datasource plugin should only implement the Query() method.
Introduction to building a backend component for a plugin
The Simple JSON backend data source is a good example of writing a simple backend plugin in Go. Let’s take a look at some key points.
Metadata
The plugin needs to know it has a backend component, this is done in the plugin.json file by setting two fields: backend and executable. If you want to enable alerting for your data source, set the alerting field to true as well.
JSON
  "id": "grafana-simple-json-backend-datasource",
  "name": "Simple Json backend",
  "type": "datasource",
  "metrics": true,
  "annotations": true,
  "backend": true,
  "alerting": true,
  "executable": "simple-json-plugin",
executable should be the the the first part of the binary filename. The actual binary filename has 3 possible endings:
  • _linux_amd64
  • _darwin_amd64
  • _windows_amd64.exe
When Grafana loads the plugin binary, it uses the executable field plus the current OS (Grafana knows which OS it is running on) to load in the correct version of the plugin. So in Simple JSON the executable field is simple-json-plugin and the 3 binaries are named:
  • simple-json-plugin_darwin_amd64
  • simple-json-plugin_linux_amd64
  • simple-json-plugin_windows_amd64.exe
The resulting plugin directory will look like this:
text
simple-json-backend-datasource/
|-- dist/
|   |-- partials/
|   |-- module.js
|   |-- plugin.json
|   |-- simple-json-plugin_linux_amd64
|   |-- simple-json-plugin_darwin_amd64
|   |-- simple-json-plugin_windows_amd64.exe
Plugin code
A pkg/ directory contains three .go files:
  • plugin.go - an entry point of the plugin. This file would be very similar for your data source - you just need to change some details like the plugin name etc.
  • datasource.go - contains Query() method implementation and other plugin logic.
  • models.go - types for request and response specific to your data source.
The data source type is declared in datasource.go:
Go
package main
import (
  plugin "github.com/hashicorp/go-plugin"
type JsonDatasource struct {
  plugin.NetRPCUnsupportedPlugin
The only requirement for the plugin type is that it should extend plugin.NetRPCUnsupportedPlugin. You can include more fields into your struct if you want to add some data source-specific features, like logging, cache etc:
Go
  logger hclog.Logger
The main method you should implement is the Query():
Go
func (t *JsonDatasource) Query(ctx context.Context, tsdbReq *datasource.DatasourceRequest) (*datasource.DatasourceResponse, error) {
Request format
In order to call this method from the frontend part of your data source, use the /api/tsdb/query endpoint:
js
class SimpleJSONDatasource {
  doTsdbRequest(options) {
    const tsdbRequest = {
      to: options.range.to.valueOf().toString(),
      queries: options.targets,
    return this.backendSrv.datasourceRequest({
      url: '/api/tsdb/query',
      method: 'POST',
      data: tsdbRequest
This endpoint gets data in the following format (see pkg/api/metrics.go and pkg/api/dtos/models.go):
js
  from: "1555324640782",  // Optional, time range from
  to: "1555328240782",    // Optional, time range to
  queries: [
      datasourceId: 42,   // Required
      refId: "A",         // Optional, default is "A"
      maxDataPoints: 100, // Optional, default is 100
      intervalMs: 1000,   // Optional, default is 1000
      myFieldFoo: "bar",  // Any other fields,
      myFieldBar: "baz",  // defined by user
There is only one query function but it is possible to move all your queries to the backend. In order to achieve this, you could add a kind of queryType field to your query model and check this type in the backend code. The Stackdriver and Cloudwatch core plugins have examples of supporting multiple types of queries if you need/want to do this:
Response format
Go types for the query response can be found in Grafana tsdb models (pkg/tsdb/models.go) or in the corresponding protocol buffer file (datasource.proto)
protobuf
// datasource.proto
message DatasourceResponse {
  repeated QueryResult results = 1;
message QueryResult {
  string error = 1;
  string refId = 2;
  string metaJson = 3;
  repeated TimeSeries series = 4;
  repeated Table tables = 5;
Go
// pkg/tsdb/models.go
type Response struct {
  Results map[string]*QueryResult `json:"results"`
  Message string                  `json:"message,omitempty"`
type QueryResult struct {
  Error       error            `json:"-"`
  ErrorString string           `json:"error,omitempty"`
  RefId       string           `json:"refId"`
  Meta        *simplejson.Json `json:"meta,omitempty"`
  Series      TimeSeriesSlice  `json:"series"`
  Tables      []*Table         `json:"tables"`
The resulting JSON response which the frontend will receive looks like this:
js
results: {
  A: {
    refId: "A",
    series: [
      { name: "series_1", points: [...] },
      { name: "series_2", points: [...] },
    tables: null,
    // Request metadata (any arbitrary JSON).
    // Optional, empty field will be omitted.
    meta: {},
    // Error message. Optional, empty field will be omitted.
    error: "Request failed",
Logging
Logs from the plugin will be automatically sent to the Grafana server and will appear in its log flow. Grafana server reads logs from the plugin’s stderr stream, so with the standard log package you have to set output to os.Stderr first:
Go
func main() {
  log.SetOutput(os.Stderr)
  log.Println("from plugin!")
Another option for logging - using go-hclog package:
Go
package main
import (
  hclog "github.com/hashicorp/go-hclog"
var pluginLogger = hclog.New(&hclog.LoggerOptions{
  Level: hclog.LevelFromString("DEBUG"),
func main() {
  pluginLogger.Debug("Running Simple JSON backend datasource")
Building the backend binary
Building the binary depends on which OS you are using.
For a Linux distro, the build command would be:
sh
go build -o ./dist/simple-json-plugin_linux_amd64 ./pkg
On Windows, the command would be:
sh
go build -o ./dist/simple-json-plugin_windows_amd64.exe ./pkg
Restart your Grafana server and then check the Grafana logs to make sure your plugin is loaded properly.
