Enterprise Open source
Choose a RED metric
Traces Drilldown uses RED metrics generated from your tracing data to guide your investigation. In this context, RED metrics mean:
  • Rates show the rate of incoming spans per second.
  • Errors show spans that are failing.
  • Duration displays the amount of time those spans take; represented as a heat map that shows response time and latency.
When you select a RED metric, the tabs underneath the metrics selection changes match the context. For example, selecting Duration displays Root cause latency and Slow traces tabs. Choosing Errors changes the tabs to Root cause errors and Errored traces. Rate provides Service structure, and Traces tabs. These tabs are used when you analyze tracing data.
To choose a RED metric:
  1. Select a graph to select a Spans (rate), Errors, or Duration metric type. Notice that your selection changes the first drop-down list on the filter bar.
  2. Optional: Select the signal you want to observe. Root spans is the default selection.
  3. Look for spikes or trends in the data to help identify issues.
Tip
If no data or limited data appears, refresh the page. Verify that you have selected the correct data source in the Data source drop-down as well as a valid time range.
