Menu
Modify dashboard settings
The dashboard settings page allows you to:
  • Edit general dashboard properties, including time settings
  • Add annotation queries
  • Add dashboard variables
  • Add links
  • View the dashboard JSON model
To access the dashboard setting page:
  1. Click Edit in the top-right corner of the dashboard.
  2. Click Settings.
Modify dashboard time settings
Adjust dashboard time settings when you want to change the dashboard timezone, the local browser time, and specify auto-refresh time intervals.
  1. On the Settings page, scroll down to the Time Options section of the General tab.
  2. Specify time settings as follows.
    • Time zone: Specify the local time zone of the service or system that you are monitoring. This can be helpful when monitoring a system or service that operates across several time zones.
      • Default: Grafana uses the default selected time zone for the user profile, team, or organization. If no time zone is specified for the user profile, a team the user is a member of, or the organization, then Grafana uses the local browser time.
      • Browser time: The time zone configured for the viewing user browser is used. This is usually the same time zone as set on the computer.
      • Standard ISO 8601 time zones, including UTC.
    • Auto refresh: Customize the options displayed for relative time and the auto-refresh options Entries are comma separated and accept any valid time unit.
    • Now delay: Override the now time by entering a time delay. Use this option to accommodate known delays in data aggregation to avoid null values.
    • Hide time picker: Select this option if you do not want Grafana to display the time picker.
  3. Click Save dashboard.
  4. (Optional) Enter a description of the changes you’ve made.
  5. Click Save.
  6. Click Exit edit.
Add tags
You can add metadata to your dashboards using tags. Tags also give you the ability to filter the list of dashboards.
Tags can be up to 50 characters long, including spaces.
To add tags to a dashboard, follow these steps:
  1. On the Settings page, scroll down to the Tags section of the General tab.
  2. In the field, enter a new or existing tag.
    If you’re entering an existing tag, make sure that you spell it the same way or a new tag is created.
  3. Click Add or press the Enter key.
  4. Click Save dashboard.
  5. (Optional) Enter a description of the changes you’ve made.
  6. Click Save.
  7. Click Exit edit.
When you’re on the Dashboards page, any tags you’ve entered show up under the Tags column.
Add an annotation query
An annotation query is a query that queries for events. These events can be visualized in graphs across the dashboard as vertical lines along with a small icon you can hover over to see the event information.
  1. On the Settings page, go to the Annotations tab.
  2. Click Add annotation query.
  3. Enter a name and select a data source.
  4. Complete the rest of the form to build a query and annotation.
  5. Click Save dashboard.
  6. (Optional) Enter a description of the changes you’ve made.
  7. Click Save.
  8. Click Exit edit.
The query editor UI changes based on the data source you select. Refer to the Data source documentation for details on how to construct a query.
Add a variable
Variables enable you to create more interactive and dynamic dashboards. Instead of hard-coding things like server, application, and sensor names in your metric queries, you can use variables in their place. Variables are displayed as dropdown lists at the top of the dashboard. These dropdowns make it easy to change the data being displayed in your dashboard.
For more information about variables, refer to Variables.
  1. On the Settings page, go to the Variables tab.
  2. Click + New variable.
  3. In the Select variable type drop-down, choose an option.
    The variable type you select impacts which fields you populate on the page.
  4. In the General section, enter the name of the variable.
    This is the name that you’ll use later in queries.
  5. Set the rest of the variable options.
  6. Click Save dashboard.
  7. (Optional) Enter a description of the changes you’ve made.
  8. Click Save.
  9. Click Exit edit.
Dashboard links enable you to place links to other dashboards and web sites directly below the dashboard header. Links provide for easy navigation to other, related dashboards and content.
  1. On the Settings page, click the Links tab.
  2. Click + New link.
  3. Enter title for the link.
  4. In the Type drop-down, select Dashboards or Link.
  5. Set the rest of the link options.
    For more detailed directions on creating links, refer to Dashboard links
  8. Click Save.
  9. Click Exit edit.
View dashboard JSON model
A dashboard in Grafana is represented by a JSON object, which stores metadata of its dashboard. Dashboard metadata includes dashboard properties, metadata from panels, template variables, panel queries, and so on.
To view a dashboard JSON model, on the Settings page, click the JSON Model tab.
For more information about the JSON fields, refer to JSON fields.
