This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/database-observability/release-notes.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/observe-and-act/monitor-applications/database-observability/release-notes/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Release notes for Grafana Cloud Database Observability
Warning
This page is no longer maintained and will be retired on November 29, 2026. Refer to What’s New to learn about updates to Grafana Cloud Database Observability.
These release notes provide information about the features, enhancements, and fixes in each version of Grafana Cloud Database Observability.
Database Observability uses Grafana Alloy to send your database telemetry to Grafana Cloud. For information about changes to Alloy, refer to the Grafana Alloy release notes.
v2.35.0
09/21/26
| Type | Description |
| Feature | Telemetry status: Added a warning banner listing database instances that are sending query statistics but no connection info, including their region and provider when available. |
| Enhancement | Trace linkage: Improved MySQL query text matching to recognize named bind parameters (for example from the .NET MySQL driver), catching more trace matches. |
| Fix | Query details: Fixed the trace fallback alert banner not spanning the full width of the page. |
| Fix | Query details: The engine version is now shown on the badge in the Cloud Provider Observability drawer, matching the main page. |
| Fix | Trace linkage: Fixed MySQL query text matching failing when the traced query had a trailing semicolon. |
v2.34.0
09/14/26
| Feature | Query details: Added the cloud provider and region below the page title, with a tooltip showing instance details and a link to the Cloud Provider Observability drawer. |
| Feature | Queries overview: Hovering the database engine icon now shows the engine version, and Query details displays the version on the engine badge. |
| Enhancement | Engine support: Added a logo for SQL Server. |
| Enhancement | Trace linkage: When no trace match is found by query text and database name, linkage now falls back to matching on query text alone, catching traces where the database name differs (for example behind a connection pooler). |
| Enhancement | Security: The host info gate that can restrict access to query data now also applies to the Queries Overview component when embedded in other apps, closing a gap where it previously wasn’t enforced there. |
| Fix | Query details: Fixed the list of tables for a MySQL query sometimes showing entries that weren’t real tables. |
| Fix | Query samples: Fixed the View trace in Explore link sometimes using the wrong Tempo data source. |
| Fix | Security: Fixed the host info gate not re-evaluating access after its first check in a session, so it could show stale results if a time range or host status changed later. |
v2.33.0
09/09/26
| Enhancement | Query overview, Setup, table schema details: Aligned panel and table borders, corner radius, and title spacing with Grafana’s standard panel styling. |
| Fix | Trace linkage: Fixed query text matching for PostgreSQL queries using Npgsql’s parameterization syntax. |
v2.32.1
09/07/26
This release contains internal changes only. There are no user-facing changes.
v2.32.0
08/26/26
| Enhancement | Query samples: The query sample tooltip now shows the Span ID instead of the Trace ID. |
| Enhancement | Query overview: Replaced the pencil icon with a labeled Edit columns button on the Queries overview table. |
| Enhancement | Links: Resource attribute links in Trace and Logs views now group correctly. |
| Fix | Query samples: Fixed the View trace in Explore link to be available even without full query text. |
| Fix | Table schema: Fixed the Schema tab table name matching to work with case-insensitive MySQL configurations. |
| Fix | UI: Fixed background colors of tables and explain plans after the visual refresh. |
v2.31.0
08/19/26
| Enhancement | Database setup: Added guidance cards to the Setup tab and clarified its fleet-managed database empty states. |
| Enhancement | Assistant: Added cloud provider identity and host metrics for the selected database instance to the Query details Assistant context. |
| Fix | Query details: Fixed action buttons that all used primary styling after the visual refresh. |
| Fix | Telemetry status: Fixed missing spacing between status tile headings and badges. |
v2.30.0
08/13/26
| Fix | Overview: Fixed the query search, wait-event tooltip, and query text lookup silently using the default Loki datasource instead of the one you selected. |
v2.29.0
07/29/26
| Feature | PostgreSQL: Added per-query error rates to the Queries overview table and the query details page. |
| Enhancement | Query details: The instance name now shows its cloud provider and location. |
| Enhancement | Trace linkage: An exact trace match now shows a banner with the trace ID. |
| Enhancement | Query details: Removed the deprecated AI Helper tab. |
v2.28.0
07/23/26
| Enhancement | Query samples: The query sample tooltip now includes a View trace in Explore link. |
| Enhancement | Query samples: Added the error code, SQL state, and error message to MySQL query sample tooltips. |
| Enhancement | Landing page: Add a database now opens the setup wizard, and activating the product explains free tier billing. |
| Fix | Queries overview: Navigating to the knowledge graph now has a Back to Database Observability button. |
v2.27.0
07/09/26
| Enhancement | Query samples: The query sample tooltip now shows the Trace ID when Alloy detects one in the query’s SQL comment. |
| Fix | Queries overview: Fixed a bug where searching while filtered to a single database engine could ignore the search and show all queries for that engine. |
v2.26.0
07/01/26
| Enhancement | Explain plan: Single-node explain plans now show an info alert explaining they provide limited insight, and no longer flag the sole node with a “Slow operation” warning. |
| Fix | Setup: The Alloy config generated by the setup wizard now matches the documented templates for MySQL and PostgreSQL across AWS, Azure, and GCP, and the Go to Telemetry Status button opens in a new tab. |
v2.25.0
06/23/26
| Enhancement | Database setup: Added optional cloud provider metadata and custom labels to the Add database and Edit wizards. Alloy configuration now includes the matching provider metadata and labels. |
| Fix | Queries overview: Fixed Rate, Duration Avg, and Errors sparklines that could stay loading after selecting a non-default Prometheus datasource. |
| Fix | Assistant: Explain this plan and page context now use the selected time range, fixing cases where historical query investigations returned no data. |
v2.24.1
06/17/26
v2.24.0
06/10/26
| Enhancement | Fleet Management setup: The Add database and Edit wizard now uses standalone pages, alongside a layout and copy refresh across the wizard and the Setup tab. |
| Fix | Queries Overview: The Rate, Duration Avg, and Errors panels no longer drop Postgres data when both MySQL and Postgres instances are present and no group-by is selected. |
v2.23.1
06/04/26
| Fix | Privacy: Query text and other sensitive values from the page URL are no longer included in frontend error telemetry. |
v2.23.0
05/29/26
| Enhancement | Wait events: Added the Engine Wait and Replication Wait categories to the wait time breakdown. |
| Enhancement | Saved views: Added an info tooltip on the Queries Overview page that explains what Saved views does. |
| Enhancement | AI Helper: Updated the deprecated AI Helper tab notice to point to the AI assistant buttons on each tab. |
| Enhancement | Trace linkage: Trace links now resolve the destination before navigating, so an exact match jumps straight to the Query samples page instead of routing through the Queries Overview page first. |
| Fix | Assistant: The assistant now uses each panel’s display units instead of guessing, fixing cases where values like seconds were shown as percentages or microseconds. |
| Fix | Query samples: Fixed the filter row alignment on the Postgres Query samples page. |
| Fix | Query samples: Bookmarked filter URLs now restore correctly, and custom threshold values loaded from a URL show a saved label. |
v2.22.0
05/06/26
| Feature | Saved views: Save your current engine, filters, and group by as named views on the Queries overview page, and set one as your default. |
| Feature | Query samples: Added filters to Postgres query samples. |
| Enhancement | AI Helper: The AI Helper tab now shows a deprecation notice pointing users to the AI assistant. |
| Enhancement | Telemetry status: Status checks now flag when your Alloy version is too old to be compatible with Database Observability. |
| Enhancement | Knowledge graph: Added an RCA Workbench button across Database Observability pages. |
| Enhancement | Table schema: Schema details now load over short time ranges by using a minimum lookback window. |
| Enhancement | Wait events: Improved the accuracy of wait event data on the Queries overview table, and the sort now switches to duration automatically when the top series can’t be ranked by count. |
| Fix | Assistant: Fixed Prometheus metric queries returning no data on stacks with a non-default scrape interval. |
| Fix | Trace linkage: Updated the message shown when no exact query match is found when coming from a trace. |
v2.21.0
04/29/26
| Enhancement | Assistant: The assistant now receives Query details page context when opened from the general assistant button. |
| Enhancement | Query samples: Query sample trace markers now use Grafana’s standard exemplar interactions and styling. |
| Enhancement | Telemetry status: Status checks now flag metrics and logs relabeling mismatches. |
| Enhancement | Telemetry status: Status checks now use each database’s unique identity instead of only its instance name. |
| Enhancement | Telemetry status: Updated Alloy compatibility checks to require Alloy 1.16.0 or later. |
v2.20.1
04/23/26
v2.20.0
04/23/26
| Fix | Query samples: Updated the query samples panel legend from AVG to AVG Duration. |
v2.19.0
04/22/26
| Fix | Telemetry status: Fixed a duplicate Postgres status check so PG Stat Statements extension populated and Privileges Granted use separate checks. |
v2.18.0
04/16/26
| Feature | Configuration: Added the Setup tab and setup wizard for adding databases through Alloy collectors registered with Fleet Management, or generating Alloy configuration for manual setups. |
| Enhancement | Cloud provider links: Added support for opening GCP Cloud SQL instances. |
| Enhancement | MySQL setup: Added a telemetry check and setup guidance for the recommended MySQL exporter limit setting. |
| Enhancement | Telemetry status: Added filters and identifying labels to the Telemetry status page, and databases with the same instance name now appear as separate entries. |
| Fix | Explain plan: Long key names now stay inside explain plan cards, with tooltips for the full value. |
v2.17.0
04/01/26
| Release | Database Observability: Now generally available after public preview. |
Was this page helpful?
