Release notes for Grafana Kubernetes Monitoring
Grafana Kubernetes Monitoring includes these elements, which all have their own releases:
  • Frontend GUI of the app (also called plugin)
  • Backend mixin (also called integration), covering the alert and recording rules
  • Helm chart for the default and other configurations of Kubernetes Monitoring
Frontend release notes
The following are release notes for the Kubernetes Monitoring GUI.
2.28.2
03/25/26
TypeDescription
FixContinuous profiling: Fixed profiling time range to use the dashboard time range instead of a hardcoded 24-hour lookback, and disabled the “View profiles” button when the specific profile type doesn’t exist for a workload.
FixContinuous profiling: Fixed Pyroscope service name matching for namespace/workload format when multiple service names share the workload name as a substring.
FixConfiguration: Renamed configuration wizard step labels to match instructions (“Stack information” to “Stack and platform”, “Platform and features” to “Monitoring type”).
2.28.1
03/16/26
TypeDescription
EnhancementContinuous profiling: Added Pyroscope integration with embedded flame graphs on workload and Pod detail pages, and direct links to Profiles Drilldown from CPU and Memory tabs.
EnhancementConfiguration: Renamed and clarified all four configuration wizard step labels for consistency, and reworded the step two instructions to better match the workflow order.
FixSearch: Fixed search page not loading previous search terms when opened from a shared or bookmarked URL.
FixConfiguration: Fixed the Integration Hub onboarding flow where pasting an existing access token did not populate the token in the generated helm upgrade command.
FixConfiguration: Fixed the OpenCost documentation link not displaying as a clickable link in the cost metrics alert.
FixSecurity: Updated dependencies to address CVEs.
2.28.0
03/11/26
TypeDescription
FeatureConfiguration: Redesigned the configuration page into four steps for a clearer setup experience.
FeatureHealth: Added a new Health page showing a live snapshot of active issues across all Clusters.
EnhancementOpenTelemetry: As part of adding support for OpenTelemetry, added CPU metrics for OTel data sources in Node, Namespace, and Cluster views.
FixError messaging: Improved error messages for recording rule operations to show the actual error instead of a generic failure message.
FixMetrics accuracy: Panels now filter out internal bookkeeping metrics reported by the container runtime (cAdvisor), so CPU and memory values reflect only your actual application containers.
FixWorkload metrics: Used workload-level recording rules instead of Pod filtering for more accurate workload metrics.
FixPanel queries: Added unique query reference IDs to prevent data conflicts in panels with multiple queries sharing the same runner.
2.27.2
03/04/26
TypeDescription
FixPredictions: Dynamically load prediction modules to prevent page crashes if a prediction module fails to load.
2.27.1
03/03/26
TypeDescription
FeatureSearch: Redesigned the search page for better user experience.
EnhancementOpenTelemetry: As part of adding support for OpenTelemetry, added CPU limit metrics for OTel data sources in Namespace, Node, and Cluster views so you can compare CPU usage against configured limits.
EnhancementConfiguration: Added a disabled state to feature toggles that aren’t supported on the selected platform.
FixLogs: Fixed Loki data source picker to only show Grafana Cloud Loki data sources, which previously could show non-Grafana-Cloud data sources that wouldn’t work correctly.
FixEvents: Added a dedicated query for object_name and object_kind fields in event logs so that event details display correctly.
FixWorkload detail: Renamed “Pods” label to “Pods in time range” to more accurately reflect the metric.
2.27.0
02/23/26
TypeDescription
EnhancementOpenTelemetry: Added support for OpenTelemetry kubeletstatsreceiver CPU metrics.
FixIOPS by Pod: Fixed write IOPS to use correct container_fs_writes_total metric.
FixPod filtering: Fixed page breaks with many Pods by using recording rule instead of URL parameters.
FixOpenTelemetry events: Fixed events labels not displaying correctly for OpenTelemetry events.
FixConfiguration: Changed default Cluster name to ‘my-cluster’ in onboarding instructions.
2.26.0
02/10/26
TypeDescription
FeatureManage costs: Redesigned the costs and savings view.
EnhancementLogs: Use node filter (if available) for OTel logs in node logs view for more accurate filtering.
EnhancementConfiguration instructions: Added cluster name to the simplified Alloy Helm instructions for better clarity.
FixAlerts: Removed node filter in pods table alerts to prevent incorrect filtering.
2.25.3
02/03/26
TypeDescription
FeatureSearch: Added ability to search by container image name, making it easier to find all instances of a specific image.
EnhancementAlert detection: Enhanced alert detection to support both Prometheus Alertmanager-based alerts and Grafana-managed alerts during the alerting platform migration.
EnhancementKnowledge Graph integration: Added banner to enable and navigate to Knowledge Graph for root cause analysis when not enabled.
2.25.2
01/27/26
TypeDescription
FeaturePod count: Added Pod count panel to workload detail pages.
FixLogs: Fallback to default logs query if no data found in any of the queries.
2.25.1
01/27/26
TypeDescription
FixLogs: Fallback to OTel logs queries as expected.
FixSecurity: Updated dependencies to satisfy CVEs and updated eslint.
2.25.0
01/20/26
TypeDescription
FeatureLogs: Replaced logs with new drilldown logs extension for improved log exploration.
EnhancementNetwork metrics: Added network metrics for Windows nodes.
FixLogs: Use query runner as data provider to get the logs query.
FixSecurity: Updated @remix-run/router to v1.23.2 to fix vulnerability.
FixPod metrics: Removed by label filter in Pod level request and memory sets for more accurate metrics.
FixCronjob: Fixed cronjob filtering to properly filter by namespace.
2.24.3
12/11/25
TypeDescription
FeatureConfiguration: Added the capability to enable or disable forwarding traces to application receivers.
EnhancementChanged the default view in the Logs and Events tab from the table view to the logs list view.
FixJobs: Fixed Reason column in the Pods table under Jobs.
FixJobs: Fixed an issue where empty or missing schedules could cause errors when displaying Cronjob schedules.
FixWorkloads list: Fixed workload counts on the namespace list so that they now accurately reflect the number of workloads in each namespace.
2.24.2
11/20/25
TypeDescription
FeatureEC2 instances: Added links showing which EC2 instances correspond to which Cluster nodes.
EnhancementExplore link: The Explore link opens in a new browser tab, offering stability of the GUI with large datasets.
FixJobs: Fixed job URL creation to use the job name instead of owner kind, ensuring more accurate links for Kubernetes jobs.
2.24.1
11/20/25
TypeDescription
FixKnowledge graph: ObjectDetailExtension now uses the Kubernetes workload concept instead of entityName. This ensures displayed details are more accurate and terminology matches current Kubernetes standards.
FixJobs: - Fixed job URL creation to use the job name instead of owner kind, ensuring more accurate links for Kubernetes jobs.
2.24.0
11/13/25
TypeDescription
FeatureAccess control: Added the ability to use RBAC roles.
FixJobs: Assigned a default owner if no owner type exists, to ensure job links work properly.
2.23.0
10/30/25
TypeDescription
FeatureGrafana Assistant: Added Grafana Assistant icons to most panels and added the Investigate with Assistant button to all detail pages.
2.22.0
10/22/25
TypeDescription
FeatureJobs: Added jobs and cron jobs monitoring.
EnhancementFiltering: Enabled column filtering on all tables.
EnhancementActivation: Changed name of activation tab to Manage app.
FixWorkbench: Removed filter from columns with a checkbox.
FixNode table queries: Used node filter for accuracy.
FixColumn headings: Removed incorrect units.
2.20.0
8/29/25
TypeDescription
EnhancementIntegrations: Added a Kubernetes filter to the Connections page.
EnhancementConfiguration: Added the ability to activate Kubernetes Monitoring.
2.19.8
8/21/25
TypeDescription
EnhancementIntegrations: Removed integrations from the Configuration page.
2.19.7
8/19/25
TypeDescription
EnhancementConfiguration: Removed the selection in configuration to switch on Application Observability now that users can activate it from the product.
8/5/25
TypeDescription
EnhancementAsserts: Added new term ‘insights’ instead of ‘assertions’.
FixOTel: Updated the cluster events query to improve support with OpenTelemetry Collectors.
FixScrape intervals: Removed hard-coded time interval so that panels reflect custom scrape interval.
2.19.5
7/25/25
TypeDescription
EnhancementAsserts: Added health indicator icons to lists of components.
FixPod CPU and memory: Reverted fix from 2.19.3 due to bugs it was causing.
FixContainer memory: Fixed container memory panels to aggregate correctly.
FixCluster list: Corrected the number of nodes for a cluster in the info section.
2.19.3
7/16/25
TypeDescription
EnhancementCost overview: Added ability to jump to list of Clusters from Cost Overview page.
EnhancementIntegrations: Added a message on the Integrations page that integrations will soon be accessible from the Connections page.
FixPods: Include all Pods if no pod value specified and use podName value if available on Pod CPU and Memory queries to prevent no data from showing.
2.19.2
7/3/25
TypeDescription
FeatureGPU: Added GPU tabs and panels to Cluster and Node pages.
FeatureEC2 link: Added link to navigate between EC2 instance in Cloud Provider Observability and Kubernetes Monitoring.
EnhancementCost: Added tooltips for cost panels to clarify underlying calculations and their time frame.
EnhancementUser experience: Streamlined descriptions of panels for clarity and brevity.
FixStorage: Changed inode values to percentages.
FixWorkloads: Fixed query to ensure all barepods workloads are listed, whether desired Pods or ready Pods.
FixCPU and memory tabs: Corrected the calculation for the Efficiency Usage/Requests panel on the CPU and Memory tabs of the Node detail page.
FixArgo Rollout Pods: Removed duplicate query to prevent incorrect count.
FixContainer page: Fixed tab links to navigate to appropriate pages.
2.19.1
6/11/25
TypeDescription
EnhancementServerless and Windows Nodes: Added support for showing Node memory usage on platforms that cannot use Node Exporter (such as GKE Autopilot and AWS EKS Fargate), and Windows.
EnhancementLogs table: Added the ability for a user to rollover a line in the logs table and click an icon to see the full log message.
FixQueries: Fixed queries for Cluster names with a ., which causes results to be empty.
FixNon-Kubernetes Nodes: Prevented the app from selecting Nodes that are not Kubernetes Nodes to be counted and displayed.
2.19.0
6/4/25
TypeDescription
EnhancementMemory: Added a memory tab and panels to Node, Namespace, Workload, Pod, and Cluster detail pages.
EnhancementWorkloads: Added the capability to view nonstandard workloads that contain cronjobs, bare pods, static pods, Argo Rollouts, Strimzi Pod sets, and others.
EnhancementLogs: Created a table format to display logs and events.
2.18.0
5/21/25
TypeDescription
EnhancementCPU tabs: Added CPU tabs to the Pod, Workload, and Namespace detail pages.
EnhancementGKE Autopilot and AWS EKS Fargate: Used kubelet Resource Metrics (node_cpu_usage_seconds_total) to show CPU usage for platforms that cannot use Node Exporter, including GKE Autopilot and AWS EKS Fargate.
FixLink to Pod: Fixed ability to go to a specific Pod from the Network Bandwidth by Pod panel on the Node details page on the Network tab.
FixURL: Fixed variables not synching with URL.
FixMetrics status page: Corrected spacing between panels.
FixDNS: Added a . to the end of hostnames to prevent DNS confusion.
FixOTLP: Included the OTLP Gateway destination in the Kubernetes Helm chart to route metrics, logs, and traces using the OTLP format.
FixOutlier detection: Changed Outlier detection to use podNames to prevent incorrect counts of outlier Pods.
2.17.0
5/6/25
TypeDescription
FeatureCPU details: Added CPU tab for Node details page and Cluster details page.
FixTable headers: Made table headers visible for light mode.
FixPods: Fixed Pods with the same name on different Clusters to be differentiated from each other.
FixTable columns: Make it more apparent table columns can be resized.
FixData accuracy: Ensure that CPU and memory requests only look at active pods, not completed or failed.
FixTerraform files: Ensure use of strings for usernames in Terraform files to ensure compatibility for Helm chart values.
2.16.0
4/23/25
TypeDescription
EnhancementStorage: Added IOPS and throughput panels on all Storage tabs.
FixCost: Prevented duplicate cAdvisor scrape jobs from affecting cost allocation.
FixAlerts: Fixed namespace drop-down menu on Alerts page from not being populated.
FixPod names: Corrected formatting of Pod names when using Explore from Pod lists.
FixMemory usage: Prevented completed and pending pods from affecting memory usage queries on the Pod details page.
2.15.1
4/17/25
TypeDescription
EnhancementAlerts: Added capability to filter alerts on Alert page by Node.
EnhancementOutlier detection: Outlier detection for memory automatically runs when you visit a workload details page for multi-Pod workloads, and links to Explore to show the outlier Pod(s) using more memory.
FixIntegration: Correct the configuration snippet for the Core DNS integration.
2.15.0
4/14/25
TypeDescription
FeatureOutlier detection: Outlier detection automatically runs when you visit a workload details page for multi-Pod workloads, and links to Explore to show the outlier Pod(s) using more CPU.
EnhancementDetail pages: CPU and memory columns and prediction buttons for each row have been added to the Cluster, workload, and namespace detail pages.
FixEvents and logs status check: Fixed status check and Explore links for events and logs on the Metrics status tab.
FixOverview page: Fixed the All alert links on the home page.
FixOverview page: Corrected the workload count on the overview page to more closely correlate to the workload count shown on the workloads list page.
FixFleet Management: Fixed reference to Fleet Management Terraform variables.
2.14.1
4/2/25
TypeDescription
EnhancementPerformance: Decreased the training and inference latency of the machine learning functionality to show results quicker.
EnhancementAlerts: Added filtering by alert name.
EnhancementOverview page: After filtering by Cluster or namespace, you can click on the count of Clusters, Nodes, namespaces, or workloads and show only those objects within the scope of the filter.
EnhancementUser experience: On Workload and Namespace list pages, made the Cluster names clickable and added graphs to the counts.
FixWorkload counts: Corrected calculations on workload counts on the Overview page.
FixList pages: Restored the alerts table column.
FixAlloy logs instance: Set the Pod security context for the Alloy logs instance on OpenShift.
FixOpenShift: Corrected the port names for OpenShift so that Alloy can discover targets to scrape.
FixEKS Fargate: Removed mounting of /var/log and /var/lib/docker/containers.
2.14.0
3/24/25
TypeDescription
FeatureTroubleshooting: Added a debug panel showing the source of a panel’s metrics, available from the panel menu.
EnhancementPerformance: Added a view for each list page when queries extend beyond performance capabilities which degrade page loading. This view includes a message to search or filter for specific components.
FixPerformance: Stopped unrelated panels from reloading when the logs data source is changed.
FixAccuracy: Stopped counting containers that are not running, which caused CPU limits and requests to appear higher than they should.
FixPlatforms: Disabled unnecessary components for specific platforms: nodelogs on Fargate, and profiling, Beyla, and Windows Exporter on Autopilot.
2.13.2
3/18/25
TypeDescription
FixFleet Management: Fixed interaction with Fleet Management so that Alloy installation shows positive on Metrics Status page.
FixFleet Management: Changed configuration to store secret for Fleet Management in secret instead of environmental variable.
2.13.1
3/13/25
TypeDescription
FixRemoved stabilityLevel: public-preview in relation to Alloy from the code generated on the Configuration page.
FixPrevented a race condition causing HTML error messages to appear.
FixAsserts: Restored RCA workbench linking.
2.13.0
3/9/25
TypeDescription
FeatureConfiguration: Added toggle in easy deploy for users to add Fleet Management for management of Alloy deployments.
EnhancementCluster detail page: Added buttons to allow users to navigate to workloads and namespaces within the cluster.
FixMemory queries: Switched to Working Set Size (WSS) instead of Resident Set Size (RSS) to increase accuracy of memory statistics and match kubectl and Linux Out-of-Memory behavior.
2.12.3
2/20/25
TypeDescription
FixConfiguration and status tabs: Fixed issue of configuration state not persisting when user switches between the tabs.
FixURL stability: Maintain URL on refresh of page.
FixIntegrations: Updated integrations to work with Kubernetes Monitoring Helm chart version 2.
2.12.2
2/6/25
TypeDescription
FixWorkload details page: Fixed TypeError to prevent unsafe access to data source.
2.12.1
2/6/25
TypeDescription
FixReceiver URLs: Updated URLs to match the version 2 Alloy deployment.
FixTempo and Logs: Updated configuration to fix Tempo protocol and autopilot for logs.
2.12.0
2/5/25
TypeDescription
FeatureStorage: Added storage tabs and graphs to Cluster, Node, workload, namespace, and Pod detail pages.
EnhancementConfiguration: Updated the easy deployment configuration page to use Helm chart v2.
EnhancementRecording rules: Added the install/uninstall button to the Workload Recording Rule status for the cloud-provisioned hosted metrics data source.
FixPrediction button: Disabled if the time range selected is less than two hours.
FixData source drop-down: Removed machine learning metrics data source from the drop-down menu.
FixData source drop-down: Added verification that the data source is valid prior to displaying in the drop-down menu.
FixWorkload list page: Fixed to not display all columns if filters result in more than 1,000 results.
2.11.2
1/15/25
TypeDescription
FixTime range: Ensured the time range selected in Kubernetes Monitoring is transferred to Application Observability when the View application layer button is clicked.
FixPerformance loading: Resolved issues related to rerendering of pages.
FixFilters: Ensured when time range is changed that all filters are not returned to the default.
2.11.1
1/9/25
TypeDescription
EnhancementUser experience: Added the tool tip to the Copy icon.
FixNode count: Fixed incorrect Node count on Kubernetes Overview page due to empty node labels.
FixPerformance loading: Improve loading performance of tables in detail pages.
FixMemory data: Rollback to the original recommendation for memory requests to equal memory limits.
2.11.0
1/6/25
TypeDescription
EnhancementPerformance: If Workload list page result is over 1,000 workloads, the page will load quickly but no usage or cost data will show. A message will display suggesting the list be filtered, and include a link to search.
FixMetrics status: Detect duplicate container metrics.
FixData source: Filter the data source drop-down menu to be limited to Grafana Cloud data sources.
2.10.0
12/9/24
TypeDescription
FeaturePerformance: Improve performance by performing a code split.
FixLoop error: Fixed a history loop error and page breaking.
2.9.0
11/25/24
TypeDescription
FeatureSearch: Added the ability to search for any Kubernetes object.
FixMetrics status: Show the status checks even if no clusters were detected.
2.8.8
11/12/24
TypeDescription
FixErroneous no data error: Added a null check to prevent the no data message from displaying due to UID not found for a database.
2.8.7
11/6/24
TypeDescription
FixAsserts: Fix to ensure Kubernetes Monitoring is aware Asserts is enabled.
2.8.6
11/5/24
TypeDescription
FixAsserts: Fix the time range so that it is synchronized between Kubernetes Monitoring and Asserts.
2.8.5
10/30/24
TypeDescription
FixUpdated link to the Application Observability GUI.
FixProperly align Cluster columns.
2.8.4
10/17/24
TypeDescription
EnhancementUser experience: Created Cluster, namespace, and Pod columns for alerts on home page.
EnhancementUser experience: On the Metrics status tab, added the ability to select the status of all or many Clusters.
FixInstead of displaying no data on the home page should an outage occur, the home page will show historical data prior to the outage and current data post-outage.
FixGUI: Fixed various anomolies with the GUI, including the location of the navigation drop-down menu and the width of certain columns.
2.8.3
9/23/24
TypeDescription
FixAlerts: Hide panel menu item for creating alerts if a user is not an administrator.
2.8.2
9/12/24
TypeDescription
EnhancementUser experience: Restricted the namespace field for the quick configuration process to only valid characters.
EnhancementUser experience: Added the link to the Cluster below the title on detail pages.
EnhancementTroubleshooting: Added the Helm chart to the Metrics status page.
EnhancementUser experience: Added waiting reasons and colors for Pods that are either waiting due to startup or due to a problem.
EnhancementTroubleshooting: Added the waiting reason for Pods that are waiting instead of running.
EnhancementAlerts: Added the ability to create an alert item from a panel.
FixesFixed the container memory limit on Container detail pages to be accurate. Ensured logs and events are not listed when there are no Pods. Fixed ability to remove a ’no data’ filter when a time range is changed.
2.8.1
8/25/24
TypeDescription
FeatureNew platform: Added Azure AKS as a separate platform for configuration.
EnhancementMetrics status: Added statuses for recording rules and KSM job label.
EnhancementsUser experience: Moved up the required backend installations step to prevent misconfigurations. Restricted integrations view to administrators only and improved message to non-administrative user. Added links to documentation on Overview, Cost, Alerts, and Configuration pages. Adjusted the width of filters and moved copy button closer to item for ease of use. Refresh home page when data starts being sent.
EnhancementCode snippets for integrations: Added configuration code snippets for Apache CouchDB, Apache Hadoop, Apache Tomcat, and IBM DB2.
FixCPU statistics: Fixed issue that was causing the memory legend to show in relation to CPU stats.
2.8.0
8/6/24
TypeDescription
FeatureEnergy use: Added energy metrics by using third-party Kepler open source software.
FixDuplicates: Deduplication of Pods and containers.
2.7.0
7/29/24
TypeDescription
EnhancementUser experience: Added a tab for logs and events on every detail page, including the Cluster detail page.
EnhancementIntegrations: Added snippets for the Alloy and Varnish integrations.
EnhancementLogs: Made log queries work with OTel-style labels.
FixesCorrect time range format on home page. Ensured Kubernetes Monitoring opens in correct time range from Asserts.
2.6.1
7/16/24
TypeDescription
EnhancementAlerts: Added the ability to click on the alert name from the Kubernetes Overview page.
EnhancementIntegrations: Added configuration snippets for Squid and Apache Mesos.
FixPrevented continuous rendering of data in the Safari browser.
2.6.0
7/10/24
TypeDescription
FeatureHome page: Upgraded the home page to better show the status of healthy Kubernetes objects as well as any potential issues.
FeatureAsserts button: Added Assertions button to details pages.
EnhancementUser experience enhancements: Added quick ways to navigate within the app, including the drop-down menu for all main pages, the overview and network tabs, deep linking from the home page CPU and memory graphs to the Cluster, improved Helm chart configuration process, and visual tags to indicate the type of Kubernetes object for each view.
2.5.0
6/25/24
TypeDescription
FeatureNetwork panels: Added Network Bandwidth and Network Saturation data.
FeatureCost overview panels: Added a 90-day view of total compute cost, average cost per Pod, and average Pod count on the Cost Overview page.
EnhancementOpenTelemetry: Added support for displaying events coming from the OpenTelemetry Kubernetes Events Receiver.
FixWorkloads with same name: Corrected CPU and memory usage data for workloads with the same name but in different Clusters.
2.4.0
6/18/24
TypeDescription
FeatureDeleted objects: Added the ability to find deleted Clusters, Nodes, Pods, containers, workloads, and namespaces.
EnhancementUser experience: Improved “no data” messages on home page.
EnhancementMetrics: Host metrics generation.
FixError messages: Fixed query to prevent an invalid error message.
FixUpdate host metrics switch language and disable CRDs on OpenShift.
2.3.5
6/12/24
TypeDescription
EnhancementIntegration: Added Apache Airflow configuration snippets for integration.
FixDuplicates: Removed duplicate data showing on home page.
FixAlerts: Improved alert count accuracy for certain kinds of Pod types.
2.3.4
6/7/24
TypeDescription
EnhancementAdded time range selector to home snapshot page.
2.3.3
6/3/24
TypeDescription
EnhancementIntegrations: Added configuration snippets for the integrations Wildfly and OpenSearch.
EnhancementPerformance: Improved load time for queries spanning longer time ranges.
FixRefresh and Cluster filters: Fixed so refresh does not cause filters to be removed.
FixCardinality page: Ensured the Series per namespace column data link is accurate.
FixDocumentation links: Updated and corrected documentation links on Kubernetes Monitoring main page (that is shown prior to configuring).
FixWorkload type: Ensured different workloads that are similarly named accurately show the type of workload and the data for the workload.
2.3.2
5/21/24
TypeDescription
EnhancementPerformance: Improved loading performance of CPU and memory usage tables.
FixAdded a null check for provider to avoid errors on Cluster list page.
2.3.1
5/16/24
TypeDescription
EnhancementIntegration: Added configuration snippets for the Apache Solr integration.
FixFixed Helm chart integration snippets to be compatible with Alloy.
FixFixed recording rule to include ReplicaSets, static Pods, and bare Pods so that missing workloads now show and incorrectly labeled workloads are now labeled correctly. This also fixes workload usage and cost data.
2.2.5
4/25/24
TypeDescription
EnhancementStatic Pod and Pod type: Added the static Pod label to all static Pods and the Pod label to bare/unmanaged Pods .
EnhancementIntegrations: Added flow configuration snippets for Velero and MS SQL Server integrations.
FixFixed link to alert rule after automatic refresh.
2.2.4
4/22/24
TypeDescription
EnhancementData source persistence in URL: Persisted the Loki data source in the URL so that accurate links can be shared.
FixAdded check to prevent query errors.
2.2.3
4/18/24
TypeDescription
FeatureRefresh control: Added refresh and auto-refresh choices to all pages.
2.2.2
4/17/24
TypeDescription
FeatureAlerts: Added the Alerts column to the Nodes and Cluster list pages.
EnhancementURL data source persistence: Persisted Prometheus data source in the URL so that accurate links can be shared.
EnhancementIntegration: Added configuration snippets for OracleDB integration.
2.2.1
4/15/24
TypeDescription
FeatureAlloy update: Replace Grafana Agent with Grafana Alloy.
FeatureCardinality: Added the Cardinality page to replace the Kubernetes Cardinality dashboard.
FeatureAlerts: Added the Alerts column to these pages: Pod detail, Pod list, and Workloads list.
EnhancementIntegration: Added configuration snippets for TensorFlow Serving integration.
EnhancementUser experience: Added the ability to select multiple clusters for filtering.
FixRemoved logs panel from Node detail page for future refactoring.
FixCorrected improper indent in configuration snippet of IBM MQ integration.
FixAdded kube_deployment as well as kube_replicaset to ensure all workload types are collected.
2.2.0
4/8/24
TypeDescription
FixRefactored workloads to use more efficient queries.
2.1.3
4/4/24
TypeDescription
EnhancementAdded the workload type when available to filter the list of Pods to improve search performance.
FixEnhanced the multi-line regular expression to support a broader collection of logs.
2.1.2
4/2/24
TypeDescription
FixReverted from support for OTel log labels.
2.1.1
4/2/24
TypeDescription
FeatureAdded interactivity with Sift automated machine learning investigation tool.
EnhancementAdded configuration snippets for the Couchbase and IBM MQ integrations.
EnhancementAdded support for OTel log labels.
FixCombined target_info with traces_target_info metrics to ensure all applications are found.
2.1.0
3/25/24
TypeDescription
EnhancementConfiguration: Added configuration snippets for the PgBouncer integration. Added link to extraConfig information in the Helm documents from the code snippet areas of an integration.
EnhancementDashboards: Removed dashboards due to Angular deprecation.
EnhancementMessaging: Improve wording of default messages when a data source is updated for a view.
FixPersist Cluster URL values to correct broken links.
2.0.4
3/13/24
TypeDescription
FeatureAsserts workbench: Added RCA Workbench button to allow navigating to Asserts.
EnhancementExplore: Expanded the explore feature to the list of all Pods. Improved the user experience for exploring data.
FixRemoved inaccurate timestamp for namespace creation on Namespace details page.
FixCorrected the query for phase state, which is shown by expanding a list item on the Namespaces page.
FixAdd the http prefix to OTLP endpoints on the Cluster configuration tab when OTel receivers are selected.
FixPersisted the data source between views.
2.0.3
3/6/24
TypeDescription
FeatureAdded the capability to navigate to Application Observability.
FeatureOn the Cluster list page, you can click the Explore button to view the queries used in each column of the usage and cost data. This enables you not only to understand the data, but debug any issues or create your own queries or dashboards
FeatureAdded support for the Istio integration.
FeatureAdded a warning icon and tooltip on column headers of lists to indicate error detection and query failure.
FeatureWith the easy configuration using the Helm chart, added the capability to enable OTel and Zipkin receivers.
EnhancementAdded the filter toolbar to list tables for better user experience.
EnhancementAdded duplicate metrics detection to Node Exporter, Windows Exporter, OpenCost, cAdvisor, and kubelet. When there is an error, a yellow warning icon appears next to the item on the Metrics status page.
EnhancementRefined queries for “OOMKilled” containers to prevent counting of duplicate containers, specifically when a container is being killed and another is being created in its place.
EnhancementThe link to examine an alert opens in a new tab so that context within Kubernetes Monitoring is not lost.
EnhancementUpdated URL so that any shared URL includes any variables and the time range selected.
EnhancementRelease note text in the app links to the release notes in documentation.
EnhancementBreadcrumbs now include page tab names.
EnhancementCorrected the query for unallocated resources (PV) panel.
FixCreated an additional check for deep links related to breadcrumbs display.
FixRefined queries to ensure deduplication of metrics, including removing reliance of uid label and having node/instance joins also use the Cluster label.
FixCorrected queries for the Explore button on the Workloads page.
FixFixed CPU usage prediction graph to display correctly within window.
2.0.2
2/15/24
TypeDescription
EnhancementRefined deduplication of KSM kube_node_status_capacity, and added support for node with or without trailing port numbers.
FixCreated more accurate cost calculations in the case of mixed node and instance labels.
2.0.1
2/15/24
TypeDescription
EnhancementAdded the workloads column to the list of namespaces.
FixCorrected the calculation for CPU average queries.
2.0.0
2/6/24
TypeDescription
FeatureThe Alerts page provides a centralized location to view all alerts related to your infrastructure and the applications running within it. Graphs show alerts firing by Cluster and namespace, as well as by alert severity. The alert name and severity also display on the home page in the list of Pods in trouble. On the Namespaces and Workloads tabs, a column for each item shows the amount of firing alerts.
FeatureThe ClickHouse integration is available for use with Kubernetes Monitoring.
EnhancementOn the home page, you can click the Cluster count to navigate directly to the list of Clusters on the Clusters tab, and click the Node count to navigate directly to the list of Nodes on the Nodes tab.
EnhancementOn usage cost/efficiency tables, the tables are sorted by default alphabetically by the name of the item (Cluster, namespace, and so on).
EnhancementTo improve loading performance, the namespaces, workloads, and Nodes lists are filtered by default by the first Cluster in the filter list.
EnhancementYou can click the Explore button on any item on the Metrics status tab to troubleshoot configuration issues and customize queries for status.
EnhancementTo prevent deployment failure due to timeout, increased the timeout for the Helm chart to five minutes.
EnhancementAn informational banner displays on the Dashboards page to indicate the prebuilt dashboards are being deprecated and removed, with the exception of the Cardinality dashboard.
FixResolved a duplicate series error on the container details page.
FixImproved the status panel failure detection for kube-state-metrics.
FixWhen you click Start Sending Data, the Configuration page displays.
1.7.0
1/22/24
TypeDescription
FeatureYou can view usage and cost graphs and data on the Pod details page.
FeatureWhen using EKS on Fargate, Pod logs are made available by using the Kubernetes API to gather them.
FeatureAdded or updated support for these integrations: Aerospike, ActiveMQ, Cassandra, Apache HTTP Server Project, cert-manager, ClickHouse, CoreDNS, GitLab, Kafka, MongoDB, NGINX, and PrestoDB .
EnhancementOn the Configuration page, you can add an expiration date to the token and view the scope of the token.
FixCorrected the following broken links: workload links on the Pod list of the Node details page, Cluster status link on the Configuration page, and links when Cluster name contains a slash character.
1.6.2
1/10/24
TypeDescription
EnhancementUser experience enhancements: The home page displays the home page name on the breadcrumbs, and filter options display alphabetically.
EnhancementYou can copy any object in the table lists by clicking the copy button within the row.
1.6.1
12/19/23
TypeDescription
FeatureIBM Cloud is available as a platform that you can select when using the configuration wizard.
EnhancementYou can choose Loki from the data source selector in all detailed views.
EnhancementA link to documentation for understanding CPU limits is available on detail pages showing CPU limits set.
EnhancementAll IEC units show in standard form.
EnhancementThroughout Kubernetes Monitoring, you have the copy icon available to copy any text so that you can use it in your own query, use it in the command line, send it to others, and so on.
FixFixed empty Cost panels for customers who use forward slashes in Cluster names by changing to pipe formatter.
FixCorrected inconsistencies in the number of Nodes displayed by using an instant query for any single value result instead of using a range query. This improves app performance and data accuracy.
FixFixed accuracy of CPU usage data on the Node details page.
FixImproved accuracy of machine learning prediction by using query variables to dynamically set parameters for calculation.
1.6.0
12/10/23
TypeDescription
FeatureCluster detail page: Added optimization panel showing CPU and memory utilization, and cost information for the time range selected.
FeatureNode detail page: Added optimization panel showing CPU and memory utilization, and cost information for the time range selected.
EnhancementCost page: All panels on the Cost page provide the Explore button so you can view the query, debug issues, or create your own dashboard.
FixStorage savings: Fixed storage results, which displayed multiple series errors in cases where a PersistentVolumeClaim was present on more than one node within the selected time range.
FixContainer details page: Fixed events, which weren’t displaying.
1.5.0
11/29/23
TypeDescription
FeatureContainer detail page: Added page. This page includes CPU and memory utilization, and cost information. The restart and termination panels are adjacent to each other to allow quicker correlation of restart and termination events.
FeatureNamespace detail page: Added optimization panel showing CPU and memory utilization, and cost information.
EnhancementWorkloads detail page: Added optimization panel showing CPU and memory utilization, and cost information. Updated the feature for detecting outlier CPU usage in the Pods to uses the time range selected in the time selector instead the latest/current time.
FixPod detail page: Updated the CPU and memory queries for accuracy. Removed duplicate containers that were sometimes listing.
FixHome page: Decreased load time for the Pods in trouble panel, and filtered only for issues that are currently active.
FixAdded Zipkin port configuration to ensure traces work properly.
FixUpdated internal release process and documents.
1.4.1
11/10/23
TypeDescription
FeatureConfiguration wizard: Added a selector for the platform.
FeaturePod detail page: Added an optimization panel containing CPU and memory utilization and cost.
FixTime range selector: Changed to use the time zone of the user, to ensure accuracy of time range data.
FixUse new metrics receiver flow component in the integration code snippets.
FixFixed missing data source for k3d environment.
1.4.0
11/3/23
TypeDescription
EnhancementTime range selector: Added to all appropriate pages to allow a specific time range for data to be displayed.
EnhancementMetrics status page: Improved for better user experience.
EnhancementConfiguration wizard: Improved visibility of OpenCost configuration information.
EnhancementPod details page: Used Scenes to build panels on this page.
FixDefault instructions in Github for integration: Fixed the appropriate name for Prometheus component.
FixError message for testing integration: Revised for validity and comprehension.
FixWorkload key and data list fixes: Revised to use correct key on workloads list.
FixKafka integration: Revised job name to kafka for integration to work properly.
FixStatus queries: Adjusted to show consistent results.
Backend release notes
The following are release notes for the Kubernetes Monitoring backend.
2.2.4
February 2026
TypeDescription
EnhancementAlert detection: Re-enabled support for Grafana-managed alerts. Alert queries now check both Prometheus Alertmanager (ALERTS metric) and Grafana-managed alerts (GRAFANA_ALERTS metric) to ensure all alerts are detected. During the transition period, you may temporarily see duplicate alerts for the same condition.
2.2.3
January 2026
TypeDescription
EnhancementUpdated kubernetes-mixin integration to 1.4.2.
2.2.2
December 2025
TypeDescription
EnhancementAlert rules: Updated KubePodNotReady to remove Failed from phase label filter; updated KubeContainerWaiting from aggregated metrics using sum to using raw metrics; updated KubeCPUOverCommit and KubeMemoryOvercommit to differentiate between Non-HA and HA clusters; updated KubeQuotaAlmostFull, KubeQuotaFullyUsed, KubeQuotaExceeded to do explicit join instead of ignore; updated CPUThrottlingHigh to deduplicate with topk; updated KubeletPodStartUpLatencyHigh with topk for deduplication.
EnhancementRecording rules: Updated scheduler_e2e_scheduling_duration_seconds bucket to scheduler_scheduling_attempt_duration_seconds_bucket (recording rule name also updated); updated scheduler_binding_duration_seconds_bucket to scheduler_pod_scheduling_sli_duration_seconds_bucket (recording rule name also updated); updated the kubelet PLEG node_quantile:kubelet_pleg_relist_duration_seconds:histogram_quantile recording rule to deduplicate with max by.
2.2.1
December 2025
TypeDescription
FixTemporarily disabled Grafana-managed alerts.
2.2.0
June 2025
TypeDescription
EnhancementAlert rules: Added the cluster label to any alert description where it was missing. Added KubePdbNotEnoughHealthyPods, KubeNodePressure, and KubeNodeEviction. Updated KubeletTooManyPods to deduplicate Pod counts and improve evaluation performance. Updated KubeStatefulSetReplicasMismatch to also fire when Pods cannot be created. Updated KubeNodeNotReady and KubeNodeReadinessFlapping to filter out cordoned Nodes. Removed KubeAPIDown and KubeletDown alerts as they are misleading.
EnhancementRecording rules: Added node_namespace_pod_container:container_cpu_usage_seconds_total:sum_rate5m. Updated namespace_workload_pod:kube_pod_owner:relabel to support more workloads. Updated all apiserver rules to support both Prometheus v2 and v3 histogram bucket formats. Updated apiserver_request:availability30d to prevent null values. Deprecated node_namespace_pod_container:container_cpu_usage_seconds_total:sum_irate.
2.1.2
December 2024
TypeDescription
EnhancementAlert rules: Made the KubeDaemonSetRolloutStuck alert configurable. Added instance label to KubeAggregatedAPIErrors. Added cluster label to KubeClientCertificateExpiration description.
EnhancementBuild process/tooling: Introduced automated Go dependency updates. Security updates CVE-2024-45337 and GO-2024-3333.
FixRecording rules: Corrected a data calculation in cluster_verb_scope:apiserver_request_sli_duration_seconds_count:increase.*.
2.1.1
November 2024
TypeDescription
EnhancementAlert rules: To better support multi-cluster environments, added cluster label to KubeAPIErrorBudgetBurn, KubeAPITerminatedRequests, and KubeClientCertificateExpiration.
EnhancementRecording rules: Improved data consistency for cluster_verb_scope_le:apiserver_request_sli_duration_seconds_bucket:increase1h, cluster_verb_scope_le:apiserver_request_sli_duration_seconds_bucket:increase30d, cluster_verb_scope:apiserver_request_sli_duration_seconds_count:increase1h, and cluster_verb_scope:apiserver_request_sli_duration_seconds_count:increase30d.
EnhancementBuild/process tooling: Updated dependencies to address vulnerabilities.
2.1.0
September 2024
TypeDescription
EnhancementAdded alert groups:
- kubernetes-storage (five KubePersistent.* alert rules)
- kube-apiserver-slos (four KubeAPIErrorBudgetBurn alert rules)
- kubernetes-system-apiserver (six system API Server alert rules, including KubeAggregatedAPIDown).
EnhancementAdded recording rule groups:
- kube-apiserver-.*.rules (32 *apiserver.* recording rules)
- kubelet.rules (including node_quantile:kubelet_pleg_relist_duration_seconds:histogram_quantile)
- kube-scheduler.rules (nine cluster_quantile:scheduler_.*:histogram_quantile recording rules).
EnhancementUpdated upstream Kubernetes mixin: Split k8s.rules.container_resource group into four groups to improve performance.
2.0.0
March 2024
TypeDescription
EnhancementRemoved dashboards from Kubernetes Monitoring now that all views are available in the application.
1.1.2
January 2023
TypeDescription
FixRemoved duplicate recording rule group.
FixCorrected broken links on Home dashboard.
1.1.1
November 2023
TypeDescription
FixDisabled “all” and multi-select on Events Data Source variable.
EnhancementSplit k8s.rules group into seven groups to improve evaluation performance.
1.1.0
October 2023
TypeDescription
FeatureYou can focus on cardinality exclusively related to Kubernetes by using the prebuilt Kubernetes Monitoring Cardinality dashboard.
1.0.0
October 2023
TypeDescription
EnhancementAdded job label to KubePodNotReady alert to be compatible with new Grafana Alerting structure.
0.0.14
July 2023
TypeDescription
FeatureAdded recording rules for Windows Exporter, for compatibility with node-exporter queries.
EnhancementRestored events selector to prevent logs from being returned as events.
EnhancementUpdated upstream Kubernetes mixin.
0.0.13
May 2023
TypeDescription
EnhancementAdded ability to use any (non-empty) job label on dashboards panels and rules.
EnhancementAdded Node Exporter to configuration status panel.
EnhancementAdded duplicate installation detection to configuration status panel.
EnhancementAdded informational tooltip to configuration status panel.
0.0.12
April 2023
TypeDescription
FixUpdated upstream agent-operator jsonnet-libs to inherit a fix for relabeling related to hitting a labeling limit with Loki.
0.0.11
March 2023
TypeDescription
FixCorrected template variables on Efficiency dashboard.
0.0.10
February 2023
TypeDescription
FixRemoved the beta tag from the Events panel on the homepage dashboard.
0.0.9
February 2023
TypeDescription
FixCorrected Cluster aggregation for some recording rules.
Helm chart release notes
The following are release notes for the Kubernetes Monitoring Helm chart.
For the full list of historical releases, refer to Grafana Kubernetes Monitoring Helm chart releases.
4.0.0
TypeDescription
BreakingRebuilt log features to remove labelsToKeep and split Loki and OpenTelemetry log gathering.
BreakingIntroduced collectors as a map and removed named Alloy instances.
BreakingConverted destinations into a map.
BreakingRemoved Prometheus Operator Object CRDs.
BreakingExtracted supplemental telemetry services from config features into their own subchart.
3.8.5
TypeDescription
EnhancementUpdated Beyla, Node Exporter, OpenCost, and Prometheus Operator CRDs.
FixFixed Application Observability failing to start when only traces are enabled and metrics are disabled.
3.8.4
TypeDescription
EnhancementUpdated Alloy Operator to 1.5.2.
EnhancementUpdated options for secretFilters in Pod logs features to match changes in Alloy.
FixFixed tls_config block name to tls in otelcol.auth.oauth2 for OTLP destinations.
3.8.3
TypeDescription
FeaturePostgreSQL: Added stat_statements exclude_databases, exclude_users, and limit options.
EnhancementDisabled the OpenCost MCP server.
EnhancementUpdated Alloy Operator to 1.5.1.
EnhancementAdded more settings for profiling features.
3.8.2
TypeDescription
FeatureAdded TLS configuration support for OAuth2 token endpoints across all destinations.
EnhancementAdded label selectors and a completed Job filter to the Istio integration sidecar scraper and wired namespace/label selectors for Istiod discovery.
EnhancementUpdated Beyla auto-instrumentation config to use instrument/exclude_instrument, replacing deprecated services/exclude_services.
EnhancementUpdated Beyla to 1.13.0.
EnhancementMySQL: Added perf_schema.eventsstatements collector options.
EnhancementUpdated Node Exporter, OpenCost, and Alloy Operator.
EnhancementUpdated database_observability setup for Alloy 1.13.x features.
FixFixed finding Pod logs for static pods using the config.mirror annotation.
FixFixed cAdvisor includeNamespaces filter dropping non-namespaced metrics like machine_*.
FixFixed preserving user extraEnv in service graph collector.
3.8.1
TypeDescription
FeatureAdded an option to set the semantic convention version for Application Observability span names.
FixFixed Java profiling so annotation targeting no longer scrapes unannotated pods.
FixFixed PostgreSQL integration includeQuery config camelCase issue.
3.8.0
TypeDescription
FeatureAdded the ability to enrich metrics with pod or namespace labels.
FeatureAdded the ability to set protobufMessage and a shortcut for the remote_write protocol.
FeatureAdded a feature for gathering logs using PodLogs objects.
EnhancementSet CRI as default logs processor if runtime is unset.
EnhancementAutomatically set required environment variables when enabling remote config.
EnhancementUpdated Windows Exporter to 0.12.3, Beyla to 1.11.0, and Prometheus Operator Object CRDs to 26.0.1.
3.7.5
TypeDescription
FeatureAdded configuration to specify the overrides section of the Span Logs Connector component for the Application Observability chart.
EnhancementUpdated Alloy Operator to 0.4.1.
3.7.4
TypeDescription
EnhancementImproved OTLP destination protocol validation.
EnhancementUpdated Prometheus Operator Object CRDs.
FixFixed indentation issues for Beyla relabel.
FixAdded erofs to node-exporter filesystem exclusions.
3.7.3
TypeDescription
FeatureAdded eBPF sample rate for profiling.
FeatureAdded the ability to skip cluster metrics ServiceMonitor checks.
EnhancementUpdated Node Exporter.
EnhancementMade the loki.process CRI stage maxPartialLines configurable.
3.7.2
TypeDescription
FeatureAdded cloudProvider configuration support to MySQL and PostgreSQL databaseObservability.
EnhancementUpdated Node Exporter and Alloy Operator.
3.7.1
TypeDescription
EnhancementUpdated Node Exporter and kube-state-metrics.
FixFixed MySQL and PostgreSQL integrations for missing log destinations and secrets.
3.7.0
TypeDescription
FeatureAdded an integration for Istio sidecar and service metrics.
FeatureAdded an integration for PostgreSQL, including support for Database Observability.
FeatureAdded the ability to set otel_annotations flag for the k8sattributes processor.
FeatureAdded more options to the secretFilter component in the pod logs features.
EnhancementDeployed beyla-k8s-cache with 1 replica by default in auto-instrumentation feature chart.
EnhancementUpdated Alloy Operator and Beyla.
EnhancementAdded check for the presence of kube-state-metrics or Node Exporter ServiceMonitors if clusterMetrics and prometheusOperatorObjects features are enabled.
3.6.2
TypeDescription
EnhancementUpdated Alloy Operator to 0.3.14.
FixFixed extra quotes for the sending queue storage in OTLP destinations.
FixFixed the inclusion of the destination secret for Service Graph instance.
3.6.1
TypeDescription
FeatureAdded the ability to override the security context for the waitForAlloyRemoval Helm Hook.
FeatureAdded the ability to define the sending queue for OTLP destinations.
FeatureAdded the ability to define the remote timeout for Loki destinations.
3.6.0
TypeDescription
FeatureAdded Pod Init container metrics to the kube-state-metrics allow list.
FeatureAdded Database Observability to the MySQL integration.
FeatureAdded the ability to disable sending traces from Beyla to the Application Observability feature.
FeatureAdded the ability to use ScrapeConfig objects with the Prometheus Operator Objects feature.
FixUpdated OpenCost to include an emptydir volume mount for its config path.
3.5.7
TypeDescription
FeatureAdded the ability to set scrape_native_histograms for Prometheus scrape configs.
EnhancementUpdated kube-state-metrics and Prometheus Operator CRDs.
FixFixed port assignment on the etcd integration and several cluster metrics control plane services.
FixFixed MySQL integration.
3.5.6
TypeDescription
FeatureAdded the ability to set resources for the Helm hooks.
FeatureAdded the ability to set K8s Attributes Processor filters.
EnhancementUpdated Alloy Operator and Node Exporter.
3.5.5
TypeDescription
EnhancementUpdated Beyla chart to 1.9.9.
FixSet node label for Tempo service integration.
3.5.4
TypeDescription
EnhancementUpdated Alloy Operator, Prometheus Operator CRDs, Beyla, and OpenCost.
EnhancementUpdated default Service Graph dimensions.
FixEnsured Jaeger Compact and Jaeger Thrift protocols use UDP.
FixEnsured Service Graph utilizes destination defaults.
FixFixed integration scrape intervals and timeouts to check properly inside the metrics object.
FixSet node label for certain service integrations.
3.5.3
TypeDescription
FeatureMade Alloy Profiles deployable on all nodes.
FeatureAdded label selectors for the Pod Logs feature.
FeatureAdded labels and annotations to Alloy CR instances.
EnhancementUpdated Alloy Operator, Beyla, OpenCost, and Prometheus Operator CRDs.
3.5.2
TypeDescription
FeatureAdded the ability to change pod associations.
3.5.1
TypeDescription
FeatureAdded the ability to set the MySQL protocol.
EnhancementUpdated prometheus-node-exporter from 4.47.3 to 4.48.0.
FixFixed OpenCost validation when using destinationsMap.
3.5.0
TypeDescription
FeatureCreated a separate feature for Pod Logs via Kubernetes API.
FeatureAdded Custom type destinations.
FeatureAdded the ability to set scrape timeout everywhere.
EnhancementUpdated default resource attributes remove list and labels set for profiling feature.
EnhancementSpan metrics: Added spans prefilter for internal.
3.4.1
TypeDescription
FeatureAdded the ability to set labels and annotations on the hook pod.
EnhancementUpdated kube-state-metrics and OpenCost.
EnhancementUpdated Node Exporter filesystem exclusion list.
FixFixed the excludeNamespaces option in the Prometheus Operator Object feature.
3.4.0
TypeDescription
FeatureAdded default attribute remove list support for OTLP destinations.
FeatureAdded the ability to override attributes and set TLS settings for remote config.
FixProperly truncated tail sampling and service grapher Alloy instances.
FixRemoved the “wait for Alloy operator” hook.
3.3.2
TypeDescription
FeatureAdded the ability to set the default scrape timeout for Prometheus Operator Objects feature.
FeatureAdded sys.env functions to remoteConfig collector.
EnhancementUpdated OpenCost to 2.2.2 and Prometheus Operator CRDs to 23.0.0.
3.3.1
TypeDescription
FeatureAdded image pull secrets and pull policy to Helm hooks.
EnhancementAdded transform support for span metrics.
FixFixed scrapeProtocols typo.
FixFixed hook arm64 compatibility and prevented failure if Alloy instance already deleted.
3.3.0
TypeDescription
FeatureAdded passthrough for k8sattributes processor.
FeatureAdded hooks to add finalizers and Alloy instance cleanup to prevent orphaned resources.
FeatureAdded pre-install hook to wait for Alloy Operator readiness before creating Alloy resources.
FeatureAdded alloy-operator.waitForReadiness configuration option to control the timing behavior.
FeatureAllowed passing destinations as a map.
FeatureAllowed modifying Alloy settings in one place.
FeatureAdded span attribute support for skip metrics generation.
EnhancementImproved Windows Exporter discovery rules.
EnhancementAdded kube_cronjob.* to kube-state-metrics default allow list.
3.2.6
TypeDescription
FeatureAdded the ability to set error mode for filter and transform processors.
EnhancementUpdated Beyla Helm chart to 1.9.2 in auto-instrumentation feature chart.
FixSkipped Beyla-generated traces in span metrics.
3.2.5
TypeDescription
EnhancementUpdated kube-state-metrics to 6.1.4.
FixAllowed destination and remote config usernames to be numbers.
3.2.4
TypeDescription
EnhancementUpdated Beyla, Alloy, Alloy Operator, kube-state-metrics, and Prometheus Operator CRDs.
3.2.3
TypeDescription
EnhancementUpdated Windows Exporter to 0.12.1.
EnhancementUpdated annotation handling for profiling targets.
EnhancementIncluded collector.id in span metrics transform.
FixFixed bad double quote in CRD validation.
3.2.2
TypeDescription
EnhancementUpdated Alloy Operator to 0.3.7.
EnhancementImproved how integration logs and metrics are enabled so they can be properly disabled.
3.2.1
TypeDescription
EnhancementUpdated Node Exporter to 4.47.3.
FixFixed newline handling at the end of the Prometheus file.
FixRemoved check preventing deploying if /var/log or /var/lib/docker/containers are set when they may not be needed.
3.2.0
TypeDescription
FeatureNew feature: Profiles Receiver.
EnhancementPrevented Node Exporter from generating metrics about ramfs and tmpfs.
EnhancementSet the job label on sources from the Annotation Autodiscovery feature to more reasonable values.
EnhancementSet service.namespace and service.instance.id labels from typical sources when using the Pod Logs feature.
