Manage your configuration
Manage your Kubernetes Monitoring configuration
Kubernetes Monitoring gathers metrics, logs, and events, and calculates costs for your infrastructure. It also provides recording rules, alerting rules, and allowlists.
How Kubernetes Monitoring works
Kubernetes Monitoring uses the following to provide its data and visualizations.
cAdvisor
cAdvisor (one per Node) is present on each Node in your Cluster, and emits container resource usage metrics such as CPU usage, memory usage, and disk usage. Alloy collects these metrics and sends them to Grafana Cloud.
Cluster events
Kubernetes Cluster controllers emit information about events concerning the lifecycle of Pods, deployments, and Nodes within the Cluster. Alloy pulls these Cluster events using the Kubernetes API server and converts them into log lines, then sends them to Grafana Cloud logs.
Grafana Alloy
Grafana Alloy:
  • Collects all metrics, Cluster events, and Pod logs
  • Receives traces pushed from applications on Clusters
  • Sends the data to Grafana Cloud
kube-state-metrics
Kubernetes Monitoring uses kube-state-metrics service (one replica, by default) to enable you to see the links between Cluster, Node, Pod, and container. The kube-state-metrics service listens to Kubernetes API server events, and generates Prometheus metrics that document the state of your Cluster’s objects. Over a thousand different metrics provide the status, capacity, and health of individual containers, Pods, deployments, and other resources.
kube-state-metrics:
  • Generates metrics without modification
  • Is present on each Node
  • Emits metrics specific to the kubelet process, such as kubelet_running_pods and kubelet_running_container_count
  • Provides metrics on the state of objects in your Cluster (Pods, Deployments, DaemonSets)
The Kubernetes Monitoring Cluster navigation feature requires the following metrics:
  • kube_namespace_status_phase
  • container_cpu_usage_seconds_total
  • kube_pod_status_phase
  • kube_pod_start_time
  • kube_pod_container_status_restarts_total
  • kube_pod_container_info
  • kube_pod_container_status_waiting_reason
  • kube_daemonset.+
  • kube_replicaset.+
  • kube_statefulset.+
  • kube_job.+
  • kube_node.+
  • kube_cluster.+
  • node_cpu_seconds_total
  • node_memory_MemAvailable_bytes
  • node_filesystem_size_bytes
  • node_namespace_pod_container
  • container_memory_working_set_bytes
kubelet
kubelet (one per Node):
  • Is the primary “Node agent” present on each Node in the Cluster
  • Emits metrics specific to the kubelet process like kubelet_running_pods and kubelet_running_container_count
  • Ensures containers are running
  • Provides metrics on Pods and their containers
Grafana Alloy collects these metrics and sends them to Grafana Cloud.
Kubernetes mixins
Kubernetes Monitoring is heavily indebted to the open source kubernetes-mixin project, from which the recording and alerting rules are derived. Grafana Labs continue to contribute bug fixes and new features upstream.
Node Exporter
The Prometheus exporter node-exporter runs as a DaemonSet on the Cluster to:
  • Gather metrics on hardware and OS for Linux Nodes in the Cluster
  • Emit Prometheus metrics for the health and state of the Nodes in your Cluster
OpenCost
Kubernetes Monitoring uses the combination of OpenCost and Grafana to allow you to monitor and managing costs related to your Kubernetes Cluster. For more details, refer to Manage costs.
Pod logs
Alloy pulls Pod logs from the workloads running within containers, and sends them to Loki.
Note
Log entries must be sent to a Loki data source with cluster, namespace, and pod labels.
Traces
Traces generated by applications within the Cluster are pushed to Grafana Alloy. The address options listed during the process of configuring with the Helm chart contain the configuration endpoints where traces can be pushed.
Windows Exporter
When monitoring Windows Nodes, the configuration installs the windows-exporter DaemonSet to ensure metrics are available for scraping.
Recording rules
Recording rules calculate in advance any mathematical expressions that are frequently needed or take a lot of computation, and then save the result as a new set of time series. This decreases the time for query and calculation.
Note
Recording rules may emit time series with the same metric name, but different labels. To modify these programmatically, refer to Set up Alerting for Cloud.
Kubernetes Monitoring includes the following recording rules to speed up queries and the evaluation of alerting rules.
apiserver_request:availability30d
apiserver_request:burnrate1d
apiserver_request:burnrate1h
apiserver_request:burnrate2h
apiserver_request:burnrate30m
apiserver_request:burnrate3d
apiserver_request:burnrate5m
apiserver_request:burnrate6h
cluster:namespace:pod_cpu:active:kube_pod_container_resource_limits cluster:namespace:pod_cpu:active:kube_pod_container_resource_requests cluster:namespace:pod_memory:active:kube_pod_container_resource_limits cluster:namespace:pod_memory:active:kube_pod_container_resource_requests
cluster_quantile:apiserver_request_sli_duration_seconds:histogram_quantile cluster_quantile:apiserver_request_sli_duration_seconds:histogram_quantile cluster_quantile:scheduler_binding_duration_seconds:histogram_quantile cluster_quantile:scheduler_binding_duration_seconds:histogram_quantile cluster_quantile:scheduler_binding_duration_seconds:histogram_quantile cluster_quantile:scheduler_e2e_scheduling_duration_seconds:histogram_quantile cluster_quantile:scheduler_e2e_scheduling_duration_seconds:histogram_quantile cluster_quantile:scheduler_e2e_scheduling_duration_seconds:histogram_quantile cluster_quantile:scheduler_scheduling_algorithm_duration_seconds:histogram_quantile cluster_quantile:scheduler_scheduling_algorithm_duration_seconds:histogram_quantile cluster_quantile:scheduler_scheduling_algorithm_duration_seconds:histogram_quantile
cluster_verb_scope:apiserver_request_sli_duration_seconds_count:increase1h cluster_verb_scope:apiserver_request_sli_duration_seconds_count:increase30d cluster_verb_scope_le:apiserver_request_sli_duration_seconds_bucket:increase1h cluster_verb_scope_le:apiserver_request_sli_duration_seconds_bucket:increase30d
code:apiserver_request_total:increase30d
code_resource:apiserver_request_total:rate5m
code_verb:apiserver_request_total:increase1h
code_verb:apiserver_request_total:increase30d
container_memory_rss
namespace_cpu:kube_pod_container_resource_limits:sum namespace_cpu:kube_pod_container_resource_requests:sum namespace_memory:kube_pod_container_resource_limits:sum namespace_memory:kube_pod_container_resource_requests:sum namespace_workload_pod:kube_pod_owner:relabel
node_namespace_pod_container:container_cpu_usage_seconds_total:sum_irate node_namespace_pod_container:container_memory_cache node_namespace_pod_container:container_memory_rss node_namespace_pod_container:container_memory_swap node_namespace_pod_container:container_memory_working_set_bytes
node_quantile:kubelet_pleg_relist_duration_seconds:histogram_quantile node_quantile:kubelet_pleg_relist_duration_seconds:histogram_quantile node_quantile:kubelet_pleg_relist_duration_seconds:histogram_quantile
Alerting rules
Kubernetes Monitoring comes with preconfigured alerting rules to alert on conditions such as “Pods crash looping” and “Pods getting stuck in not ready”. The following alerting rules create alerts to notify you when issues arise with your Clusters and their workloads.
To learn more, refer to the upstream Kubernetes-Mixin’s Kubernetes Alert Runbooks page. To update programmatically the alerting rule links to point your own runbooks in these preconfigured alerts, use a tool like cortex-tools or grizzly.
Kubelet alerting rules
  • KubeNodeNotReady
  • KubeNodeReadinessFlapping
  • KubeNodeUnreachable
  • KubeletClientCertificateExpiration - 7 day expiration
  • KubeletClientCertificateExpiration - 1 day expiration
  • KubeletDown
  • KubeletPlegDurationHigh
  • KubeletPodStartUpLatencyHigh
  • KubeletServerCertificateExpiration - 7 day expiration
  • KubeletServerCertificateExpiration- 1 day expiration
  • KubeletClientCertificateRenewalErrors
  • KubeletServerCertificateRenewalErrors
  • KubeletTooManyPods
Kubernetes alerting rules
  • KubeContainerWaiting
  • KubeDaemonSetMisScheduled
  • KubeDaemonSetNotScheduled
  • KubeDaemonSetRolloutStuck
  • KubeDeploymentGenerationMismatch
  • KubeDeploymentReplicasMismatch
  • KubeDeploymentRolloutStuck
  • KubeHpaMaxedOut
  • KubeHpaReplicasMismatch
  • KubeJobFailed
  • KubeJobNotCompleted
  • KubePodCrashLooping
  • KubePodNotReady
  • KubeStatefulSetGenerationMismatch
  • KubeStatefulSetReplicasMismatch
  • KubeStatefulSetUpdateNotRolledOut
Kubernetes API alerting rules
  • KubeAggregatedAPIDown
  • KubeAggregatedAPIErrors
  • KubeAPIDown
  • KubeAPIErrorBudgetBurn
  • KubeAPITerminatedRequests
  • KubeClientCertificateExpiration - less than 7 days
  • KubeClientCertificateExpiration - less than 1 day
Kubernetes resource usage alerting rules
  • CPUThrottlingHigh
  • KubeCPUOvercommit
  • KubeCPUQuotaOvercommit
  • KubeMemoryOvercommit
  • KubeMemoryQuotaOvercommit
  • KubeQuotaAlmostFull
  • KubeQuotaExceeded
  • KubeQuotaFullyUsed
Kubernetes storage alerting rules
  • KubePersistentVolumeErrors
  • KubePersistentVolumeFillingUp - 1 hour
  • KubePersistentVolumeFillingUp - 1 minute
  • KubePersistentVolumeInodesFillingUp - 1 hour
  • KubePersistentVolumeInodesFillingUp - 1 minute
Kubernetes system alerting rules
  • KubeClientErrors
  • KubeVersionMismatch
Metrics management and control
If your account is based on billable series, there are ways to control and manage metrics.
Identify unnecessary or duplicate metrics
To identify unnecessary or duplicate metrics generated from a Cluster, you can:
  • Use the Cardinality page to discover on a Cluster-by-Cluster basis where all your active series are coming from. From the main menu, click Configuration and then the Cardinality tab.
    Cardinality page within the app
  • Analyze current metrics usage and associated costs from the billing and usage dashboard located in your Grafana instance.
Analyze usage
For techniques to analyze usage, refer to Analyze Prometheus metrics costs.
Reduce usage
Use and refine an allowlist to reduce metrics to only those you want to receive. An allowlist is a set of metrics and labels that you want to gather while all others are dropped. Out of the box, Kubernetes Monitoring has allowlists configured with Prometheus metric_relabel_configs blocks.
For more about Prometheus drop and keep relabeling options, refer to Relabeling rule fields.
You can remove or modify allowlists by editing the corresponding metric_relabel_configs blocks in your Alloy configuration. To learn more about relabeling to control the metrics you want, refer to Relabel Prometheus metrics to reduce usage.
You can also tune and refine the metrics of an existing allowlist or create a custom allowlist.
Billable series
If your account does not use host-hours pricing, pricing is based on billable series. To learn more about this pricing model, refer to Active series and DPM.
Default telemetry data collection (also called active series) varies depending on your Kubernetes Cluster size (number of Nodes) and running workloads (number of Pods, containers, Deployments, etc.).
When testing on a Cloud provider’s Kubernetes offering, the following active series usage was observed:
  • 3-Node Cluster, 17 running Pods, 31 running containers: 3.8k active series
    • The only Pods deployed into the Cluster were Grafana Agent and kube-state-metrics. The rest were running in the kube-system Namespace and managed by the cloud provider
  • From this baseline, active series usage roughly increased by:
    • 1000 active series per additional Node
    • 75 active series per additional Pod (vanilla Nginx Pods were deployed into the Cluster)
These are very rough guidelines and results may vary depending on your Cloud provider or Kubernetes version. Note also that these figures are based on the scrape targets configured above, and not additional targets such as application metrics, API server metrics, and scheduler metrics.
Logs management
Control and manage logs by:
  • Only collecting logs from Pods in certain namespaces
  • Dropping logs based on content
For more on analyzing, customizing, and de-duplicating logs, refer to Logs in Explore.
Limit logs to only Pods from certain namespaces
By default, Kubernetes Monitoring gathers logs from Pods in every namespace. However, you may only want or need logs from Pods in certain namespaces.
In the Grafana Alloy configuration, you can add a relabel_configs block that either keeps Pods or drops Pods.
For example, the following gathers logs only from the production and staging namespaces:
txt
rule {
  source_labels = ["namespace"]
  regex = "production|staging"
  action = "keep"
Drop logs based on content
Similarly to filtering to specific namespaces, you can use Loki processing rules to further process and optionally drop log lines.
For example, this processing stage drops any log lines that contain the word debug:
txt
stage.drop {
  expression  = ".*(debug|DEBUG).*"
Get support
To open a support ticket, navigate to your Grafana Cloud Portal, and click Open a Support Ticket.
