title: "Varnish Cache integration | Grafana Cloud documentation"
description: "Learn about Varnish Cache Grafana Cloud integration."
# Varnish Cache integration for Grafana Cloud
Varnish Cache is an open source web application accelerator, also called a caching HTTP reverse proxy. This integration for Grafana Cloud allows users to collect metrics and logs for their Varnish system.
Varnish Cache integration for Grafana cloud provides a streamlined way for users to easily monitor their Varnish system with little overhead while getting the crucial information they need.
This integration supports Varnish Cache 6.0 LTS.
This integration includes 6 useful alerts and 1 pre-built dashboard to help monitor and visualize Varnish Cache metrics and logs.
## Before you begin
In order for the integration to properly work, you must set up the [Varnish Cache exporter for Prometheus](https://github.com/jonnenauha/prometheus_varnish_exporter) to export metrics from Varnish.
#### Set up Varnish Cache exporter
Install the version of the exporter that corresponds to your operating system. The latest releases and installs can be found on [exporter installation](https://github.com/jonnenauha/prometheus_varnish_exporter/releases). To start the exporter first unzip the file that you downloaded above and traverse to the directory where the executable is. The executable will be named similar to `prometheus_varnish_exporter`. An example of the exporter being run is shown below:
Bash ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```bash
sudo ./prometheus_varnish_exporter
The above will run a
```bash
varnishstat -j
behind the scenes and open a port `9131` that can be accessed through `localhost:9131`. The exported Prometheus metrics can be seen at `localhost:9131/metrics`.
The exporter exposes port `9131` by default but you can change this using the `-web.listen-address` flag when running the exporter. The use of this flag would look like this:
```bash
sudo ./prometheus_varnish_exporter -web.listen-address localhost:9595
If you have multiple Varnish instances, you must specify which you are targeting with the exporter. This can be done by running the exporter with the flag `-n` and the name of your varnish instance. Example shown below:
```bash
sudo ./prometheus_varnish_exporter -n <instance_name>
This also means you would need one exporter for each instance of Varnish Cache, each with a unique port.
For more options and help with the exporter, you can run the below command:
```bash
sudo ./prometheus_varnish_exporter -h
Once deployed, Grafana Alloy should be able to reach the Varnish Cache exporter’s exposed endpoint in order to scrape metrics.
#### Set up Varnish Cache logging
This integration leverages the `varnishncsa` utility provided by Varnish in order to produce formatted logs. Any format of log collection with `varnishncsa` will be picked up by the integration.
In order to setup `varnishncsa`, the utility must be enabled by running:
```bash
sudo systemctl enable varnishncsa
sudo systemctl start varnishncsa
By default this integration provides two commands that enable frontend and backend logging capabilities. Since Varnish does not naturally record logs into a file, a log path must be specified for `varnishncsa` to write to. For darwin and linux systems respectively, the paths need to be `/opt/varnish/log` and `/var/log/varnish`. Note: replace `<instance_name>` and `<log_path>` with the respective names of the instance and log path. If there is only one instance, then the `-n <instance_name>` flag can be removed. The below commands must be re-run for each instance that log collection is required for.
```bash
sudo varnishncsa -n <instance_name> -F '{"Timestamp": "%t", "Varnish-Side": "%{Varnish:side}x", "Age": %{age}o, "Handling": "%{Varnish:handling}x", "Request": "%r", "Status": "%s", "Response-Reason": "%{VSL:RespReason}x", "Fetch-Error": "%{VSL:FetchError}x", "X-Forwarded-For": "%{x-forwarded-for}i", "Remote-User": "%u", "Bytes": "%b", "Time-To-Serve": %D, "User-Agent": "%{User-agent}i", "Referer": "%{Referer}i", "X-Varnish": "%{x-varnish}o", "X-Magento-Tags": "%{x-magento-tags}o"}}' -D -w <log_path>/varnishncsa-frontend.log
sudo varnishncsa -n <instance_name> -b -F '{"Timestamp": "%t", "Varnish-Side": "%{Varnish:side}x", "Handling": "%{Varnish:handling}x", "Request": "%r", "Status": "%s", "Response-Reason": "%{VSL:RespReason}x", "Fetch-Error": "%{VSL:FetchError}x", "Bytes": "%b", "Time-To-Serve": %D}' -D -w <log_path>/varnishncsa-backend.log
For multiple instances, configure the files where logs are written to follow the following naming convention: `varnishncsa-frontend-<instance_name>.log` `varnishncsa-backend-<instance_name>.log`
## Install Varnish Cache integration for Grafana Cloud
1. In your Grafana Cloud stack, click **Connections** in the left-hand menu.
2. Find **Varnish Cache** and click its tile to open the integration.
3. Review the prerequisites in the **Configuration Details** tab and set up Grafana Alloy to send Varnish Cache metrics and logs to your Grafana Cloud instance.
4. Click **Install** to add this integration’s pre-built dashboard and alerts to your Grafana Cloud instance, and you can start monitoring your Varnish Cache setup.
## Configuration snippets for Grafana Alloy
### Advanced mode
To instruct Grafana Alloy to scrape your Varnish Cache instances, **manually** copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
### Advanced metrics snippets
Alloy ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```alloy
discovery.relabel "metrics_integrations_integrations_varnish_cache" {
	targets = [{
		__address__ = "<exporter_host>:<exporter_port>",
	rule {
		target_label = "instance"
prometheus.scrape "metrics_integrations_integrations_varnish_cache" {
	targets    = discovery.relabel.metrics_integrations_integrations_varnish_cache.output
	job_name   = "integrations/varnish-cache"
To monitor your Varnish Cache instance, you must use a [discovery.relabel](/docs/alloy/latest/reference/components/discovery.relabel/) component to discover your Varnish Cache Prometheus endpoint and apply appropriate labels, followed by a [prometheus.scrape](/docs/alloy/latest/reference/components/prometheus.scrape) component to scrape it.
Configure the following properties within each `discovery.relabel` component:
- `__address__`: The address to your Varnish Cache Prometheus metrics endpoint.
- `instance` label: `constants.hostname` sets the `instance` label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Varnish Cache instance. Make sure this label value is the same for all telemetry data collected for this instance.
If you have multiple Varnish Cache servers to scrape, configure one `discovery.relabel` for each and scrape them by including each under `targets` within the `prometheus.scrape` component.
### Advanced logs snippets
#### darwin
```alloy
local.file_match "logs_integrations_integrations_varnish_cache" {
	path_targets = [{
		__address__ = "localhost",
		__path__    = "<log_path>/varnishncsa*.log",
		instance    = constants.hostname,
		job         = "integrations/varnish-cache",
loki.source.file "logs_integrations_integrations_varnish_cache" {
	targets    = local.file_match.logs_integrations_integrations_varnish_cache.targets
	forward_to = [loki.write.grafana_cloud_loki.receiver]
To monitor your Varnish Cache instance logs, you will use a combination of the following components:
- [local.file\_match](/docs/alloy/latest/reference/components/local.file_match) defines where to find the log file to be scraped. Change the following properties according to your environment:
  - `__address__`: The Varnish Cache instance address
  - `__path__`: The path to the log file.
- [loki.source.file](/docs/alloy/latest/reference/components/loki.source.file) sends logs to Loki.
#### Kubernetes log collection
> These instructions assume the use of the [official Varnish helm chart](https://artifacthub.io/packages/helm/varnish/varnish-cache).
In the [sample application](https://github.com/grafana/integration-sample-apps/tree/main/charts/varnish-cache), we generated YAML from the official helm chart and customized it in the following ways:
1. Add an initContainer that mounts the volume for logs and creates the log files to be written to.
2. Add two `varnishncsa` sidecars, one for frontend logs, the other for backend logs.
3. Add one Alloy sidecar with appropriate volumeMounts to the log files and the custom Alloy configuration
> The Varnish cache container, the initContainer, and the `varnishncsa` sidecars must be run as the `varnishlog` user. In the following YAML examples, you’ll notice `runAsUser` is set to the `varnishlog` user ID, **which may be different in your environment**.
##### Log file initContainer
> This example is for one instance, where only one log file exists per log type.
Here’s an example snippet for creating an initContainer that mounts the log file location and creates the necessary log files:
YAML ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```yaml
initContainers:
- name: init-script
  image: alpine:latest
  securityContext:
    runAsNonRoot: true
    runAsUser: 103
  command: ['sh', '-c', 'touch /var/log/varnish/varnishncsa-frontend.log /var/log/varnish/varnishncsa-backend.log && chmod 666 /var/log/varnish/*.log']
  volumeMounts:
  - name: varnish-log
    mountPath: /var/log/varnish
##### Varnish log sidecars
The `varnishncsa` sidecars for logging need to be deployed with the appropriate arguments and volume mounts. Refer to the [this example deployment](https://github.com/grafana/integration-sample-apps/blob/main/charts/varnish-cache/templates/deployment.yaml) for details on the `varnishncsa` arguments.
Here is an example snippet for the frontend logs sidecar:
```yaml
- name: varnish-cache-ncsa-frontend
  securityContext:
    runAsNonRoot: true
    runAsUser: 103
  image: {{ .Values.varnishImage }}
  imagePullPolicy: IfNotPresent
  command: ["/bin/sh", "-c"]
  args: ["varnishncsa -n /var/lib/varnish -F '{\"Timestamp\": \"%t\", \"Varnish-Side\": \"%{Varnish:side}x\", \"Age\": %{age}o, \"Handling\": \"%{Varnish:handling}x\", \"Request\": \"%r\", \"Status\": \"%s\", \"Response-Reason\": \"%{VSL:RespReason}x\", \"Fetch-Error\": \"%{VSL:FetchError}x\", \"X-Forwarded-For\": \"%{x-forwarded-for}i\", \"Remote-User\": \"%u\", \"Bytes\": \"%b\", \"Time-To-Serve\": %D, \"User-Agent\": \"%{User-agent}i\", \"Referer\": \"%{Referer}i\", \"X-Varnish\": \"%{x-varnish}o\", \"X-Magento-Tags\": \"%{x-magento-tags}o\"}' -w /var/log/varnish/varnishncsa-frontend.log"]
  volumeMounts:
  - name: custom-varnish-vsm
    mountPath: /var/lib/varnish
    readOnly: true
  - name: varnish-secret
    mountPath: /etc/varnish/secret
    subPath: secret
  - name: varnish-log
##### Alloy sidecar
The Alloy sidecar is configured to collect logs from each file. Here’s an example snippet:
```yaml
apiVersion: v1
kind: ConfigMap
metadata:
  labels:
    alloy-config: varnish-logs
data:
  config.alloy: |
    logging {
      level  = "info"
      format = "logfmt"
    loki.write "logs_integrations" {
      endpoint {
        url = "http://loki.default.svc.cluster.local:3100/loki/api/v1/push"
      external_labels = {"cluster" = "my-cluster"}
      path_targets = [{
        __path__    = "/var/log/varnish/varnishncsa-*.log",
        instance    = "custom-varnish-cache.sample-apps.svc:9131",
    loki.source.file "logs_integrations_integrations_apache_airflow" {
      forward_to = [loki.write.logs_integrations.receiver]
#### linux
```alloy
	path_targets = [{
```yaml
initContainers:
- name: init-script
  securityContext:
    runAsNonRoot: true
    runAsUser: 103
  volumeMounts:
  - name: varnish-log
```yaml
  securityContext:
    runAsNonRoot: true
    runAsUser: 103
  volumeMounts:
    readOnly: true
    subPath: secret
  - name: varnish-log
##### Alloy sidecar
```yaml
apiVersion: v1
kind: ConfigMap
metadata:
  labels:
data:
  config.alloy: |
    logging {
      level  = "info"
      format = "logfmt"
      endpoint {
      path_targets = [{
## Kubernetes instructions
Instructions for Kubernetes
### Before you begin with Kubernetes
**Please note**: These instructions assume the use of the [Kubernetes Monitoring Helm chart](https://github.com/grafana/k8s-monitoring-helm)
```bash
```bash
varnishstat -j
```bash
```bash
```bash
### Configuration snippets for Kubernetes Helm chart
To scrape your Varnish Cache instances, **manually** modify your Kubernetes Monitoring Helm chart with these configuration snippets.
Replace any values between the angle brackets `<>` in the provided snippets with your desired configuration values.
#### Metrics snippets
```alloy
alloy-metrics:
    extraConfig: |-
        discovery.kubernetes "varnish" {
            role = "service"
            selectors {
                role = "service"
                field = "metadata.name=<varnish-cache-service>"
            namespaces {
                names = ["<varnish-cache-namespace>"]
        discovery.relabel "varnish" {
            targets = discovery.kubernetes.varnish.targets
            rule {
                source_labels = ["__meta_kubernetes_pod_container_port_number"]
                regex = "<varnish-cache-exporter-port>"
                action = "keep"
        prometheus.scrape "varnish" {
            targets      = discovery.relabel.varnish.output
            forward_to   = [prometheus.remote_write.grafana_cloud_metrics.receiver]
#### Logs snippets
```alloy
<p>
To collect logs from Varnish Cache, <code>varnishncsa</code> and Alloy sidecars must be added to the deployment configuration.
Additional ConfigMaps for custom Alloy configurations must be created. The deployment will need an additional volume for logs and all sidecars will need <code>volumeMounts</code> for that volume.
</p>
<p>
For additional guidance, refer to <a href="https://grafana.com/docs/grafana-cloud/monitor-infrastructure/integrations/integration-reference/integration-varnish-cache/#kubernetes-log-collection">this documentation</a>
</p>
## Dashboards
The Varnish Cache integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Varnish overview
**Varnish Cache overview (overview)**
**Varnish Cache overview (logs)**
## Alerts
The Varnish Cache integration includes the following useful alerts:
Expand table
| Alert                             | Description        |
| VarnishCacheLowCacheHitRate       | Warning: Cache is not answering a sufficient percentage of read requests.                    |
| VarnishCacheHighMemoryUsage       | Warning: Varnish Cache is running low on available memory.                                   |
| VarnishCacheHighCacheEvictionRate | Critical: The cache is evicting too many objects.                                            |
| VarnishCacheHighSaturation        | Warning: There are too many threads in queue, Varnish is saturated and responses are slowed. |
| VarnishCacheSessionsDropping      | Critical: Incoming requests are being dropped due to a lack of free worker threads.          |
| VarnishCacheBackendUnhealthy      | Critical: Backend has been marked as unhealthy due to slow 200 responses.                    |
## Metrics
The most important metrics provided by the Varnish Cache integration, which are used on the pre-built dashboard and Prometheus alerts, are as follows:
- up
- varnish\_backend\_beresp\_bodybytes
- varnish\_backend\_beresp\_hdrbytes
- varnish\_main\_backend\_busy
- varnish\_main\_backend\_conn
- varnish\_main\_backend\_recycle
- varnish\_main\_backend\_req
- varnish\_main\_backend\_reuse
- varnish\_main\_backend\_unhealthy
- varnish\_main\_cache\_hit
- varnish\_main\_cache\_hitpass
- varnish\_main\_cache\_miss
- varnish\_main\_client\_req
- varnish\_main\_n\_expired
- varnish\_main\_n\_lru\_nuked
- varnish\_main\_pools
- varnish\_main\_s\_resp\_bodybytes
- varnish\_main\_s\_resp\_hdrbytes
- varnish\_main\_sessions
- varnish\_main\_sessions\_total
- varnish\_main\_thread\_queue\_len
- varnish\_main\_threads
- varnish\_main\_threads\_created
- varnish\_main\_threads\_failed
- varnish\_main\_threads\_limited
- varnish\_sma\_g\_bytes
- varnish\_sma\_g\_space
## Changelog
md ![Copy code to clipboard](/media/images/icons/icon-copy-small-2.svg) Copy
```md
# 1.0.0 - August 2024
* Add Kubernetes as a supported platform using Grafana Alloy
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - July 2023
* Initial release
## Cost
By connecting your Varnish Cache instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see [Active series and dpm usage](/docs/grafana-cloud/fundamentals/active-series-and-dpm/) and [Cloud tier pricing](/products/cloud/pricing/).
