Couchbase integration for Grafana Cloud
Couchbase is a distributed NoSQL database which provides high availability, scalability, and performance for large sets of data. This integration for Grafana Cloud allows users to collect metrics and logs from the cluster, node, and bucket levels of a Couchbase clustered deployment.
This integration supports Couchbase 7.0+
This integration includes 4 useful alerts and 3 pre-built dashboards to help monitor and visualize Couchbase metrics and logs.
Before you begin
Couchbase exposes a Prometheus metrics endpoint that is enabled by default.
In order to access this endpoint, configure basic authentication with the credentials of a user with an admin role. For more information on roles in Couchbase, see these docs
Install Couchbase integration for Grafana Cloud
  1. In your Grafana Cloud stack, click Connections in the left-hand menu.
  2. Find Couchbase and click its tile to open the integration.
  3. Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Couchbase metrics and logs to your Grafana Cloud instance.
  4. Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Couchbase setup.
Advanced mode
To instruct Grafana Alloy to scrape your Couchbase instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
Advanced metrics snippets
Alloy
discovery.relabel "metrics_integrations_integrations_couchbase" {
	targets = [{
		__address__ = "<node-hostname>:8091",
	rule {
		target_label = "instance"
	rule {
		target_label = "couchbase_cluster"
		replacement  = "<your-cluster-name>"
prometheus.scrape "metrics_integrations_integrations_couchbase" {
	targets    = discovery.relabel.metrics_integrations_integrations_couchbase.output
	job_name   = "integrations/couchbase"
	basic_auth {
		username = "<cb-cluster-username>"
		password = "<cb-cluster-password>"
To monitor your Couchbase instance, you must use a discovery.relabel component to discover your Couchbase Prometheus endpoint and apply appropriate labels, followed by a prometheus.scrape component to scrape it.
Configure the following properties within each discovery.relabel component:
  • __address__: The address to your Couchbase Prometheus metrics endpoint.
  • instance label: constants.hostname sets the instance label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Couchbase instance. Make sure this label value is the same for all telemetry data collected for this instance.
  • couchbase_cluster: The couchbase_cluster label to group your Couchbase instances within a cluster. Set the same value for all nodes within your cluster.
If you have multiple Couchbase servers to scrape, configure one discovery.relabel for each and scrape them by including each under targets within the prometheus.scrape component.
Advanced logs snippets
darwin
Alloy
local.file_match "logs_integrations_integrations_couchbase" {
	path_targets = [{
		__address__       = "localhost",
		__path__          = "/opt/couchbase/var/lib/couchbase/*.log",
		couchbase_cluster = "<your-cluster-name>",
		instance          = constants.hostname,
		job               = "integrations/couchbase",
loki.process "logs_integrations_integrations_couchbase" {
	forward_to = [loki.write.grafana_cloud_loki.receiver]
	stage.drop {
		expression = "---"
	stage.multiline {
		firstline     = "\\[(ns_server|couchdb):(error|info),.*\\]"
		max_lines     = 0
		max_wait_time = "3s"
loki.source.file "logs_integrations_integrations_couchbase" {
	targets    = local.file_match.logs_integrations_integrations_couchbase.targets
	forward_to = [loki.process.logs_integrations_integrations_couchbase.receiver]
To monitor your Couchbase instance logs, you will use a combination of the following components:
  • local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
    • __address__: The Couchbase instance address
    • __path__: The path to the log file.
  • loki.process defines how to process logs before sending it to Loki.
  • loki.source.file sends logs to Loki.
linux
Alloy
	path_targets = [{
	stage.drop {
		expression = "---"
	stage.multiline {
		max_lines     = 0
windows
Alloy
	path_targets = [{
	stage.drop {
		expression = "---"
	stage.multiline {
		max_lines     = 0
Kubernetes instructions
Dashboards
The Couchbase integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
  • Couchbase bucket overview
  • Couchbase cluster overview
  • Couchbase node overview
Couchbase cluster overview (top nodes)
Couchbase node overview (memory)
Couchbase bucket overview (storage)
Alerts
The Couchbase integration includes the following useful alerts:
AlertDescription
CouchbaseHighCPUUsageCritical: The node CPU usage has exceeded the critical threshold.
CouchbaseHighMemoryUsageCritical: There is a limited amount of memory available for a node.
CouchbaseMemoryEvictionRateWarning: There is a spike in evictions in a bucket, which indicates high memory pressure.
CouchbaseInvalidRequestVolumeWarning: There is a high volume of incoming invalid requests, which may indicate a DOS or injection attack.
Metrics
The most important metrics provided by the Couchbase integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
  • backup_data_size
  • cbas_direct_memory_used_bytes
  • cm_http_requests_total
  • couch_docs_actual_disk_size
  • index_avg_scan_latency
  • index_cache_hits
  • index_cache_misses
  • index_memory_used_total
  • index_num_requests
  • kv_curr_connections
  • kv_curr_items
  • kv_ep_num_value_ejects
  • kv_mem_used_bytes
  • kv_num_high_pri_requests
  • kv_num_vbuckets
  • kv_ops
  • kv_ops_failed
  • kv_vb_queue_memory_bytes
  • n1ql_errors
  • n1ql_invalid_requests
  • n1ql_requests
  • n1ql_requests_1000ms
  • n1ql_requests_250ms
  • n1ql_requests_5000ms
  • n1ql_requests_500ms
  • sys_cpu_utilization_rate
  • sys_mem_actual_free
  • sys_mem_actual_used
  • up
  • xdcr_data_replicated_bytes
  • xdcr_docs_received_from_dcp_total
Changelog
md
# 1.0.0 - March 2024
- Added cluster selector to dashboards for kubernetes support
- Added default cluster label to agent config
- Bump version to 1.0.0
# 0.0.3 - September 2023
# 0.0.2 - August 2023
# 0.0.1 - July 2023
- Initial release
Cost
By connecting your Couchbase instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
