Menu
Review and apply recommendations
Create and manage recommendations using the UI, API, or Terraform. This topic focuses on how to manage your recommendations using the Grafana UI.
On the Rules tab in Adaptive Metrics, you can manage all the aggregation rules recommended by the system.
On the Overview tab, you can see the current status and when your recommendations were last updated.
To manage recommendations using the API or Terraform, refer to Adaptive Metrics HTTP API or Adaptive Metrics Terraform provider.
Manage rule recommendations using the UI
You can add, keep, remove, or update recommended rules.
  1. Navigate to Administration > Cost Management > Metrics > Adaptive Metrics.
  2. Click the Rules tab.
    A list of rule recommendations appears.
  3. (Optional) To filter the rules list for a specific metric, type part of the metric name under Filter.
  4. Under Recommendation type, select the type of rule recommendations you want to view. Available rule recommendation types include Add, Keep, Remove, and Update.
    The rules list updates based on the type you select.
  5. To review the details of a recommended rule, including the Recommended rule information and Metric usage stats, expand the rule from the rules list.
  6. Select which recommendations you want to apply or select Apply all recommendations.
    A confirmation dialog box showing your updates appears.
  7. To confirm your rule updates, click Apply.
    Note
    Applying a rule from its expanded view doesn’t display a confirmation dialog box.
