Documentationbreadcrumb arrow Grafana Cloudbreadcrumb arrow As codebreadcrumb arrow Observability as codebreadcrumb arrow Foundation SDKbreadcrumb arrow Automate dashboard provisioning with CI/CD
Introduction
Managing Grafana dashboards manually can be inefficient and error-prone. As you saw in the Getting Started guide, we can define dashboards using strongly typed code with the Grafana Foundation SDK. We can then commit them to version controls, and automatically deploy them using GitHub Actions.
This guide walks through:
  • Generating a Grafana dashboard as code
  • Formatting it for Kubernetes-style deployment
  • Using GitHub Actions to deploy the dashboard
  • Checking if the dashboard exists and updating it if needed
By the end, every change to your dashboard code will be automatically created or updated in your Grafana instance without manual intervention.
You can find the full example source code in the intro-to-foundation-sdk repository.
1. Generating the dashboard JSON
Before deploying a dashboard, we need to define it in code using the Grafana Foundation SDK. We ran through an example of this in the Getting Started guide, however, in order to comply with the Kubernetes resource compatible API that Grafana exposes, we’ll make some changes to the code to output the dashboard JSON in the appropriate format.
Go
package main
import (
	"encoding/json"
	"log"
	"os"
	"github.com/grafana/grafana-foundation-sdk/go/cog"
	"github.com/grafana/grafana-foundation-sdk/go/common"
	"github.com/grafana/grafana-foundation-sdk/go/dashboard"
type DashboardWrapper struct {
	APIVersion string              `json:"apiVersion"`
	Kind       string              `json:"kind"`
	Metadata   Metadata            `json:"metadata"`
	Spec       dashboard.Dashboard `json:"spec"`
type Metadata struct {
	Name string `json:"name"`
func main() {
	builder := dashboard.NewDashboardBuilder("My Dashboard").
		Uid("my-dashboard").
		Tags([]string{"generated", "foundation-sdk", "go"}).
		Refresh("5m").
		Time("now-1h", "now").
		Timezone(common.TimeZoneBrowser).
		WithRow(dashboard.NewRowBuilder("Overview"))
	dashboard, err := builder.Build()
	if err != nil {
		log.Fatalf("failed to build dashboard: %v", err)
	dashboardWrapper := DashboardWrapper{
		APIVersion: "dashboard.grafana.app/v1beta1",
		Kind:       "Dashboard",
		Metadata: Metadata{
		Spec: dashboard,
	dashboardJson, err := json.MarshalIndent(dashboardWrapper, "", "  ")
	if err != nil {
		log.Fatalf("failed to marshal dashboard: %v", err)
	err = os.WriteFile("dashboard.json", dashboardJson, 0644)
	if err != nil {
		log.Fatalf("failed to write dashboard to file: %v", err)
	log.Printf("Dashboard JSON:\n%s", dashboardJson)
typescript
import { DashboardBuilder, RowBuilder } from '@grafana/grafana-foundation-sdk/dashboard';
import * as fs from 'fs';
// Generate the dashboard JSON
const dashboard = new DashboardBuilder('My Dashboard')
  .uid('my-dashboard')
  .tags(['generated', 'foundation-sdk', 'typescript'])
  .refresh('5m')
  .time({ from: 'now-1h', to: 'now' })
  .timezone('browser')
  .withRow(new RowBuilder('Overview'))
  .build();
// Convert to Kubernetes-style format
const dashboardWrapper = {
  apiVersion: "dashboard.grafana.app/v1beta1",
  kind: "Dashboard",
  metadata: {
  spec: dashboard
// Save the formatted JSON to a file
const dashboardJSON = JSON.stringify(dashboardWrapper, null, 2);
fs.writeFileSync('dashboard.json', dashboardJSON, 'utf8');
console.log(`Dashboard JSON:\n${}`);
This script:
  • Generates a Grafana dashboard JSON file
  • Wraps it in a Kubernetes-style API format (apiVersion, kind, metadata, spec)
  • Saves it as dashboard.json for deployment
2. Automating deployment with GitHub Actions
Next, we’ll set up GitHub Actions to: Extract the dashboard name from dashboard.json Check if the dashboard already exists within our Grafana instance Update it if it does, create it if it doesn’t
Note
The following GitHub Action configuration assumes you are using a Go-based dashboard generator. If you are using one of the other languages that the Foundation SDK supports, please modify the Generate Dashboard JSON step accordingly.
.github/workflows/deploy-dashboard.yml
YAML
name: Deploy Grafana Dashboard
on:
  push:
    branches:
      - main
jobs:
  deploy:
    runs-on: ubuntu-latest
    steps:
      - name: Checkout code
        uses: actions/checkout@v3
      - name: Set up Go
        uses: actions/setup-go@v5
        with:
          go-version: 1.24.6
      - name: Verify Go version
        run: go version
      - name: Download and Extract grafanactl
        run: |
          curl -L -o grafanactl-x86_64.tar.gz "https://github.com/grafana/grafanactl/releases/download/${{ vars.GRAFANACTL_VERSION }}/grafanactl_Linux_x86_64.tar.gz"
          tar -xzf grafanactl-x86_64.tar.gz
          chmod +x grafanactl
          sudo mv grafanactl /usr/local/bin/grafanactl
      - name: Generate Dashboard JSON
        working-directory: ./github-actions-example
        run: go run main.go
      - name: Deploy Dashboard with grafanactl
        env:
          GRAFANA_SERVER: ${{ vars.GRAFANA_SERVER }}
          GRAFANA_STACK_ID: ${{ vars.GRAFANA_STACK_ID }}
          GRAFANA_TOKEN: ${{ secrets.GRAFANA_TOKEN }}
        run: |
          if [ -f dashboard.json ]; then
            echo "dashboard.json exists, deploying dashboard."
            grafanactl resources push dashboards --path ./dashboard.json
          else
            echo "dashboard.json does not exist."
            exit 1
          fi
3. Explaining this GitHub Action
This GitHub Action automates the deployment of a Grafana dashboard using the Foundation SDK and the grafanactl CLI tool.
1. Checkout and set up Go
The first few steps:
  • Check out the repository to access the project code.
  • Install Go 1.24.6 using the actions/setup-go action.
  • Verify Go is properly installed.
2. Download and install grafanactl
This step downloads the grafanactl CLI from GitHub using a version defined in vars.GRAFANACTL_VERSION. It unpacks the tarball, makes it executable, and moves it to a location in the system PATH.
3. Generate the dashboard JSON
Runs the dashboard generator (main.go) from the ./github-actions-example directory. This should produce a dashboard.json file that contains the Grafana dashboard definition.
4. Deploy the dashboard with grafanactl
If dashboard.json exists, it is deployed to your Grafana instance using:
Bash
This command authenticates against Grafana using the following environment variables:
  • GRAFANA_SERVER: Your Grafana instance URL
  • GRAFANA_STACK_ID: Your Grafana stack ID
  • GRAFANA_TOKEN: A Grafana service account token with sufficient permissions
GitHub variables and secrets used
These are configured in your repository under Settings → Security → Secrets and variables → Actions:
  • vars.GRAFANACTL_VERSION: Version of grafanactl to install
  • vars.GRAFANA_SERVER: The URL of your Grafana instance
  • vars.GRAFANA_STACK_ID: The stack ID in Grafana
  • secrets.GRAFANA_TOKEN: Grafana API token
This action ensures that every push to main will regenerate and deploy your latest dashboard definition to Grafana.
Why automate this?
Automating Grafana dashboard deployment eliminates the need for manual dashboard creation and updates, ensuring that dashboards remain consistent across environments. By defending dashboards as code and managing them through CI/CD such as GitHub Actions, we gain full version control, making it easy to track changes over time and roll back if needed. This also prevents duplication, as the workflow intelligently checks whether a dashboard exists before deciding to create or update it. With this fully automated CI/CD pipeline, developers can focus on improving their dashboards rather than manually uploading JSON files to Grafana.
Conclusion
By integrating the Grafana Foundation SDK with GitHub Actions, we have successfully automated the entire lifecycle of Grafana dashboards. This setup allows us to define dashboards programmatically, convert them into a Kubernetes-compatible format, and deploy them automatically. With each push to the repository, the workflow ensures that dashboards are either created or updated as needed. This not only improves the efficiency but also guarantees that all deployed dashboards are always in sync with the latest code changes, reducing manual effort and potential errors.
