Documentationbreadcrumb arrow Grafana Cloudbreadcrumb arrow As codebreadcrumb arrow Infrastructure as codebreadcrumb arrow Terraformbreadcrumb arrow Manage Fleet Management in Grafana Cloud using Terraform
Learn how to create Grafana Fleet Management collectors and pipelines in Grafana Cloud using Terraform. This guide shows you how to create an access policy and a token for Fleet Management and Grafana Alloy, a collector with remote attributes, and a pipeline for profiling Alloy.
Before you begin
Before you begin, you should have the following available:
  • A Grafana Cloud account, as shown in Get started
  • Terraform installed on your machine
  • Alloy installed on your machine
  • Administrator permissions in your Grafana instance
Note
All of the following Terraform configuration files should be saved in the same directory.
Configure a provider for Grafana Cloud
This Terraform configuration configures the Grafana provider to provide necessary authentication when interacting with the Cloud API. The grafana_cloud_stack (Data Source) is used to retrieve the user ID and URL details of your instance.
  1. Create a Grafana Cloud access policy and token. To create a new one, refer to Grafana Cloud Access Policies. Add your stack to the realms list. The scopes needed for the examples in this guide are:
    • accesspolicies:read
    • accesspolicies:write
    • accesspolicies:delete
    • stacks:read
  2. Create a file named cloud-provider.tf and add the following code block:
    terraform
    terraform {
      required_providers {
        grafana = {
          source  = "grafana/grafana"
          version = ">= 3.19.0"
    provider "grafana" {
      alias = "cloud"
      cloud_access_policy_token = "<CLOUD_ACCESS_POLICY_TOKEN>"
    data "grafana_cloud_stack" "stack" {
      provider = grafana.cloud
      slug = "<STACK_SLUG>"
  3. Replace the following field values:
    • <CLOUD_ACCESS_POLICY_TOKEN> with the access policy token you created in the first step
    • <STACK_SLUG> with your stack slug, which is the subdomain where your Grafana Cloud instance is available: https://<STACK_SLUG>.grafana.net
Create an access policy and token for Fleet Management
This Terraform configuration creates the following:
  1. Create a file named fm-access-policy.tf and add the following code block:
    terraform
    resource "grafana_cloud_access_policy" "fm_policy" {
      name   = "fleet-management-policy"
      region = data.grafana_cloud_stack.stack.region_slug
      scopes = [
        "fleet-management:read",
        "fleet-management:write"
      realm {
        type       = "stack"
        identifier = data.grafana_cloud_stack.stack.id
    resource "grafana_cloud_access_policy_token" "fm_token" {
      name             = "fleet-management-token"
      region           = grafana_cloud_access_policy.fm_policy.region
      access_policy_id = grafana_cloud_access_policy.fm_policy.policy_id
Configure a provider for Fleet Management
This Terraform configuration configures the Grafana provider to provide necessary authentication when interacting with the Fleet Management API.
  1. Create a file named fm-provider.tf and add the following code block:
    terraform
    locals {
      fm_id    = data.grafana_cloud_stack.stack.fleet_management_user_id
      fm_token = grafana_cloud_access_policy_token.fm_token.token
      fm_url   = data.grafana_cloud_stack.stack.fleet_management_url
      alias = "fm"
      fleet_management_auth = "${local.fm_id}:${local.fm_token}"
      fleet_management_url  = local.fm_url
Create a Fleet Management collector
This Terraform configuration creates a collector with a remote attribute, using grafana_fleet_management_collector (Resource).
This configuration only preregisters the collector. You must complete the Run Alloy step for the collector to register with Fleet Management and be assigned remote attributes.
  1. Create a file named fm-collector.tf and add the following code block:
    terraform
    resource "grafana_fleet_management_collector" "fm_collector" {
      provider = grafana.fm
      id = "prod_collector"
      remote_attributes = {
        "env" = "PROD"
      enabled = true
Create a Fleet Management pipeline
This Terraform configuration creates a pipeline for Alloy profiling with a matcher for the collector declared in the previous step, using grafana_fleet_management_pipeline (Resource). The pipeline writes the profiles to Grafana Cloud Profiles.
  1. Create a file named profiling.alloy.tftpl and add the following content:
    Alloy
    // This pipeline scrapes pprof Go profiles from Alloy and sends them to Pyroscope.
    // It requires the following environment variables to be set where Alloy is running:
    //   Required:
    //     * GCLOUD_RW_API_KEY: The Grafana Cloud API key with write access to Pyroscope.
    //   Optional:
    //     * ALLOY_ADDRESS: The address Alloy listens on. Defaults to 127.0.0.1:12345.
    pyroscope.scrape "alloy" {
        targets = [
                "__address__" = coalesce(
                    sys.env("ALLOY_ADDRESS"),
                    "127.0.0.1:12345",
                "service_name" = "alloy",
        forward_to = [pyroscope.write.grafana_cloud.receiver]
        profiling_config {
            profile.process_cpu {
                enabled = true
            profile.memory {
                enabled = true
            profile.mutex {
                enabled = true
            profile.block {
                enabled = true
            profile.goroutine {
                enabled = true
    pyroscope.write "grafana_cloud" {
        endpoint {
            url = "${profiles_url}"
            basic_auth {
                username = "${profiles_id}"
                password = sys.env("GCLOUD_RW_API_KEY")
  2. Create a file named fm-pipeline.tf and add the following code block:
    terraform
    locals {
      profiles_id  = data.grafana_cloud_stack.stack.profiles_user_id
      profiles_url = data.grafana_cloud_stack.stack.profiles_url
    resource "grafana_fleet_management_pipeline" "pipeline" {
      name = "profiling"
      contents = templatefile(
        "profiling.alloy.tftpl",
          profiles_id  = local.profiles_id,
          profiles_url = local.profiles_url,
      matchers = [
        "env=\"PROD\""
      enabled = true
Create an access policy and token for Alloy
  1. Create a file named alloy-access-policy.tf and add the following code block:
    terraform
    resource "grafana_cloud_access_policy" "alloy_policy" {
      name   = "alloy-policy"
      scopes = [
        "set:alloy-data-write"
      realm {
        type       = "stack"
    resource "grafana_cloud_access_policy_token" "alloy_token" {
      name             = "alloy-token"
      region           = grafana_cloud_access_policy.alloy_policy.region
      access_policy_id = grafana_cloud_access_policy.alloy_policy.policy_id
    output "alloy_token" {
      value     = grafana_cloud_access_policy_token.alloy_token.token
      sensitive = true
Create a configuration file for Alloy
This Terraform configuration creates an Alloy configuration file with the remotecfg block for Fleet Management, using local_file (Resource).
  1. Create a file named config.alloy.tftpl and add the following content:
    Alloy
    remotecfg {
        id             = "${collector_id}"
        url            = "${fm_url}"
        poll_frequency = "60s"
        basic_auth {
            username = "${fm_id}"
  2. Create a file named alloy-config.tf and add the following code block:
    terraform
    resource "local_file" "alloy_config" {
      filename = "<ALLOY_CONFIG_PATH>"
      content = templatefile(
        "config.alloy.tftpl",
          collector_id = "prod_collector",
          fm_id        = local.fm_id,
          fm_url       = local.fm_url,
      directory_permission = "0644"
      file_permission      = "0644"
    • <ALLOY_CONFIG_PATH> with the path the Alloy configuration file should be written to, for example config.alloy
Apply the Terraform configuration
In a terminal, run the following commands from the directory where all of the configuration files are located.
  1. Initialize a working directory containing Terraform configuration files:
    shell
    terraform init
  2. Preview the Terraform changes:
    shell
    terraform plan
  3. Apply the configuration:
    shell
    terraform apply
Run Alloy
To learn how to start or restart Alloy, refer to Run Grafana Alloy.
Note
The variable GCLOUD_RW_API_KEY must be set in the environment where Alloy is running for the remote configuration in this example to work.
  1. Run the following command to view the Alloy token:
    shell
    terraform output -raw alloy_token
  2. Set the environment variable GCLOUD_RW_API_KEY to the value from the first step.
  3. Run Alloy.
Validation
After you apply the changes in the Terraform configurations and run Alloy, you should be able to verify the following:
  • A collector is added to the Fleet Management Inventory tab:
    The Inventory screen in the Fleet Management interface in Grafana Cloud which shows that a new collector called `prod_collector` is registered with attribute `env=PROD`, has a healthy status, and was last modified a few seconds ago.
  • A pipeline is added to the Fleet Management Remote configuration tab:
    The Remote configuration screen in the Fleet Management interface in Grafana Cloud which shows that a new configuration pipeline called `profiling` is active and was last modified a few seconds ago.
  • Alloy profiles are being exported to Grafana Cloud Profiles:
    A dashboard in Grafana Cloud which shows Alloy profiling data, including graphs for CPU and memory.
Conclusion
In this guide, you created an access policy and a token for Fleet Management and Alloy, a collector with remote attributes, and a pipeline for profiling Alloy, all using Terraform.
To learn more about managing Grafana Cloud using Terraform, refer to Grafana provider’s documentation.
