This page is also available in Markdown, which may be easier for automated readers and AI tools to parse than HTML. The Markdown version is available at https://grafana.com/docs/grafana-cloud/security-and-account-management/migration-guide.md, or by sending Accept: text/markdown to https://grafana.com/docs/grafana-cloud/security-and-account-management/migration-guide/. For broader documentation discovery, the curated index is available at https://grafana.com/llms.txt and the complete index is available at https://grafana.com/llms-full.txt.
Migrate from Grafana OSS/Enterprise to Grafana Cloud
When you decide to migrate from your self-managed Grafana instance to Grafana Cloud, you can benefit from the convenience of a managed observability platform, additional cloud-only features, and robust security. There are a couple of key approaches to help you transition to Grafana Cloud.
| Migration type | Tools used | Availability | Migratable resources |
| Manual |
| Generally available in all versions of Grafana OSS/Enterprise | The entire Grafana instance |
| Automated | The Grafana Cloud Migration Assistant | Generally available in Grafana v12 and available in public preview from Grafana v11.2 to v11.6 using the onPremToCloudMigrations feature toggle. This toggle is enabled by default in Grafana v11.5 and later. |
Our detailed migration guide explains the key steps and scripts to manually migrate your resources to Grafana Cloud, covering a comprehensive set of resources in your Grafana instance. Alternatively, the Grafana Cloud Migration Assistant, available in public preview in Grafana v11.2 and later, automates the migration process across a broad range of Grafana resources. You can use the migration assistant to migrate a large proportion of your Grafana resources and then, if needed, leverage the migration guide to migrate the rest.
Was this page helpful?
