Caution
Grafana Alloy is the new name for our distribution of the OTel collector. Grafana Agent has been deprecated and is in Long-Term Support (LTS) through October 31, 2025. Grafana Agent will reach an End-of-Life (EOL) on November 1, 2025. Read more about why we recommend migrating to Grafana Alloy.
Logs and relabeling basics
This tutorial assumes you have completed the First components and introducing the standard library tutorial, or are at least familiar with the concepts of components, attributes, and expressions and how to use them. You will cover some basic metric relabeling, followed by how to send logs to Loki.
Relabel metrics
Recommended reading
- Optional: prometheus.relabel
Before moving on to logs, let’s look at how we can use the prometheus.relabel
component to relabel metrics. The prometheus.relabel
component allows you to perform Prometheus relabeling on metrics and is similar to the relabel_configs
section of a Prometheus scrape config.
Let’s add a prometheus.relabel
component to a basic pipeline and see how to add labels.
prometheus.exporter.unix "localhost" { }
prometheus.scrape "default" {
scrape_interval = "10s"
targets = prometheus.exporter.unix.localhost.targets
forward_to = [
prometheus.relabel.example.receiver,
prometheus.relabel "example" {
forward_to = [
prometheus.remote_write.local_prom.receiver,
rule {
action = "replace"
target_label = "os"
replacement = constants.os
prometheus.remote_write "local_prom" {
endpoint {
url = "http://localhost:9090/api/v1/write"
We have now created the following pipeline:
This pipeline has a prometheus.relabel
component that has a single rule.
This rule has the replace
action, which will replace the value of the os
label with a special value: constants.os
This value is a special constant that is replaced with the OS of the host Grafana Agent is running on.
You can see the other available constants in the
constants documentation.
This example has one rule block, but you can have as many as you want.
Each rule block is applied in order.
If you run Grafana Agent and navigate to
localhost:3000/explore, you can see the os
label on the metrics. Try querying for node_context_switches_total
and look at the labels.
Relabeling uses the same rules as Prometheus. You can always refer to the prometheus.relabel documentation for a full list of available options.
Note
You can forward multiple components to one
prometheus.relabel
component. This allows you to apply the same relabeling rules to multiple pipelines.
Warning
There is an issue commonly faced when relabeling and using labels that start with
__
(double underscore). These labels are considered internal and are dropped before relabeling rules from aprometheus.relabel
component are applied. If you would like to keep or act on these kinds of labels, use a discovery.relabel component.
Send logs to Loki
Recommended reading
- Optional: local.file_match
- Optional: loki.source.file
- Optional: loki.write
Now that you’re comfortable creating components and chaining them together, let’s collect some logs and send them to Loki. We will use the local.file_match
component to perform file discovery, the loki.source.file
to collect the logs, and the loki.write
component to send the logs to Loki.
Before doing this, we need to ensure we have a log file to scrape. We will use the echo
command to create a file with some log content.
mkdir -p /tmp/flow-logs
echo "This is a log line" > /tmp/flow-logs/log.log
Now that we have a log file, let’s create a pipeline to scrape it.
local.file_match "tmplogs" {
path_targets = [{"__path__" = "/tmp/flow-logs/*.log"}]
loki.source.file "local_files" {
targets = local.file_match.tmplogs.targets
forward_to = [loki.write.local_loki.receiver]
loki.write "local_loki" {
endpoint {
url = "http://localhost:3100/loki/api/v1/push"
The rough flow of this pipeline is:
If you navigate to
localhost:3000/explore and switch the Datasource to Loki
, you can query for {filename="/tmp/flow-logs/log.log"}
and see the log line we created earlier. Try running the following command to add more logs to the file.
echo "This is another log line!" >> /tmp/flow-logs/log.log
If you re-execute the query, you can see the new log lines.
If you are curious how Grafana Agent keeps track of where it is in a log file, you can look at data-agent/loki.source.file.local_files/positions.yml
If you delete this file, Grafana Agent starts reading from the beginning of the file again, which is why keeping the Grafana Agent’s data directory in a persistent location is desirable.
Exercise
Recommended reading
Add a Label to Logs
This exercise will have two parts, building on the previous example. Let’s start by adding an os
label (just like the Prometheus example) to all of the logs we collect.
Modify the following snippet to add the label os
with the value of the os
constant.
endpoint {
Note
You can use the loki.relabel component to relabel and add labels, just like you can with the prometheus.relabel component.
Once you have your completed configuration, run Grafana Agent and execute the following:
echo 'level=info msg="INFO: This is an info level log!"' >> /tmp/flow-logs/log.log
echo 'level=warn msg="WARN: This is a warn level log!"' >> /tmp/flow-logs/log.log
echo 'level=debug msg="DEBUG: This is a debug level log!"' >> /tmp/flow-logs/log.log
Navigate to
. Try querying for {filename="/tmp/flow-logs/log.log"}
and see if you can find the new label!
Now that we have added new labels, we can also filter on them. Try querying for {os!=""}
. You should only see the lines you added in the previous step.
// Let's learn about relabeling and send logs to Loki!
forward_to = [loki.relabel.add_static_label.receiver]
loki.relabel "add_static_label" {
rule {
target_label = "os"
endpoint {
Extract and add a Label from Logs
Note
This exercise is more challenging than the previous one. If you are having trouble, skip it and move to the next section, which will cover some of the concepts used here. You can always come back to this exercise later.
This exercise will build on the previous one, though it’s more involved.
Let’s say we want to extract the level
from the logs and add it as a label. As a starting point, look at
loki.process.
This component allows you to perform processing on logs, including extracting values from log contents.
Try modifying your configuration from the previous section to extract the level
If needed, you can find a solution to the previous exercise at the end of the
previous section.
Note
The
stage.logfmt
andstage.labels
blocks forloki.process
may be helpful.
Once you have your completed config, run Grafana Agent and execute the following:
Navigate to
. Try querying for {level!=""}
to see the new labels in action.
Finishing up and next steps
You have learned the concepts of components, attributes, and expressions. You have also seen how to use some standard library components to collect metrics and logs. In the next tutorial, you will learn more about how to use the loki.process
component to extract values from logs and use them.
