Raspberry Pi integration for Grafana Cloud
The Raspberry Pi integration uses Grafana Alloy to collect metrics related to the operating system (Linux-based), including aspects like CPU usage, load average, memory usage, and disk and networking I/O. It also supports system logs being scraped by Alloy using promtail. An accompanying dashboard is provided to visualize these metrics and logs.
The Raspberry Pi integration uses node-observ-lib.
This integration includes 15 useful alerts and 2 pre-built dashboards to help monitor and visualize Raspberry Pi metrics and logs.
Before you begin
Each Raspberry Pi node being observed must have its dedicated Grafana Alloy running.
Install Raspberry Pi integration for Grafana Cloud
- Find Raspberry Pi and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send Raspberry Pi metrics and logs to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboards and alerts to your Grafana Cloud instance, and you can start monitoring your Raspberry Pi setup.
Simple mode
These snippets are configured to scrape a single Raspberry Pi instance running locally with default ports.
Integrations snippets
prometheus.exporter.unix "integrations_node_exporter" { }
discovery.relabel "integrations_node_exporter" {
targets = prometheus.exporter.unix.integrations_node_exporter.targets
rule {
target_label = "instance"
replacement = constants.hostname
rule {
target_label = "job"
replacement = "integrations/raspberrypi-node"
prometheus.scrape "integrations_node_exporter" {
targets = discovery.relabel.integrations_node_exporter.output
job_name = "integrations/node_exporter"
Logs snippets
linux
discovery.relabel "logs_integrations_integrations_node_exporter_journal_scrape" {
targets = []
rule {
source_labels = ["__journal__systemd_unit"]
target_label = "unit"
rule {
source_labels = ["__journal__boot_id"]
target_label = "boot_id"
rule {
source_labels = ["__journal__transport"]
target_label = "transport"
rule {
source_labels = ["__journal_priority_keyword"]
target_label = "level"
loki.source.journal "logs_integrations_integrations_node_exporter_journal_scrape" {
max_age = "24h0m0s"
relabel_rules = discovery.relabel.logs_integrations_integrations_node_exporter_journal_scrape.rules
forward_to = [loki.write.grafana_cloud_loki.receiver]
labels = {
instance = constants.hostname,
job = "integrations/raspberrypi-node",
local.file_match "logs_integrations_integrations_node_exporter_direct_scrape" {
path_targets = [{
__address__ = "localhost",
__path__ = "/var/log/{syslog,messages,*.log}",
loki.source.file "logs_integrations_integrations_node_exporter_direct_scrape" {
targets = local.file_match.logs_integrations_integrations_node_exporter_direct_scrape.targets
Advanced mode
To instruct Grafana Alloy to scrape your Raspberry Pi instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
rule {
rule {
This integrations uses the prometheus.exporter.unix component to generate metrics from a Raspberry Pi instance.
For the full array of configuration options, refer to the prometheus.exporter.unix component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each Raspberry Pi instance to be monitored you must create a pair of these components.
component:
instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this Raspberry Pi instance. Make sure this label value is the same for all telemetry data collected for this instance.
You can then scrape them by including each discovery.relabel
under targets
within the prometheus.scrape component.
Advanced logs snippets
linux
targets = []
rule {
rule {
rule {
rule {
max_age = "24h0m0s"
labels = {
path_targets = [{
To monitor your Raspberry Pi instance logs, you will use a combination of the following components:
local.file_match defines where to find the log file to be scraped. Change the following properties according to your environment:
__address__
: The Raspberry Pi instance address__path__
: The path to the log file.instance
sets theinstance
loki.source.journal Reads logs from the systemd journal. Change the following properties according to your environment:
max_age
: The oldest relative time from process start that will be read.
discovery.relabel defines any relabeling needed before sending logs to Loki.
loki.source.file sends logs to Loki.
Each Raspberry Pi node being observed must have its dedicated Grafana Agent running.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send Raspberry Pi metrics and logs to your Grafana Cloud instance.
Post-install configuration for the Raspberry Pi integration
This integration is configured to work with the node_exporter
, which is embedded in Grafana Agent.
Enable the integration by adding the snippets provided to your agent configuration file.
Note: The
instance
label must uniquely identify the node being scraped. Also, ensure each deployed Grafana Agent has a configuration that matches the node it is deployed to.
This integration supports metrics and logs from Raspberry Pi. If you want to monitor your Raspberry Pi node logs, there are 3 options. You can:
- scrape the journal
- scrape your OS log files directly
- scrape both your journal and OS log files
We recommend that you enable journal scraping because it comes with a unit label that can be used to filter logs on the dashboards. Config snippets for both cases are provided.
If you want to show logs and metrics signals correlated in your dashboards, as a single pane of glass, ensure the following:
job
andinstance
label values must match fornode_exporter
integration andlogs
scrape config in your agent configuration file.job
label must be set tointegrations/raspberrypi-node
(already configured in the snippets).instance
label must be set to a value that uniquely identifies your Linux Node. Please replace the default<your-instance-name>
value according to your environment - it should be set manually. Note that if you uselocalhost
for multiple nodes, the dashboards will not be able to filter correctly by instance.
For a full description of configuration options see how to configure the node_exporter_config
block in the agent documentation.
Below integrations
node_exporter:
enabled: true
metric_relabel_configs:
# drop extensive scrape statistics
- action: drop
regex: node_scrape_collector_.+
source_labels: [__name__]
relabel_configs:
- replacement: '<your-instance-name>'
target_label: instance
- replacement: integrations/raspberrypi-node
target_label: job
- job_name: integrations/node_exporter_journal_scrape
journal:
max_age: 24h
labels:
instance: '<your-instance-name>'
job: integrations/raspberrypi-node
relabel_configs:
- source_labels: ['__journal__systemd_unit']
target_label: 'unit'
- source_labels: ['__journal__boot_id']
target_label: 'boot_id'
- source_labels: ['__journal__transport']
target_label: 'transport'
- source_labels: ['__journal_priority_keyword']
target_label: 'level'
- job_name: integrations/node_exporter_direct_scrape
static_configs:
- targets:
- localhost
labels:
__path__: /var/log/{syslog,messages,*.log}
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the Raspberry Pi integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
- action: replace
target_label: job
- action: keep
source_labels:
- __name__
node_exporter:
enabled: true
- action: drop
relabel_configs:
target_label: job
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
journal:
max_age: 24h
labels:
relabel_configs:
static_configs:
- targets:
- localhost
labels:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
global:
scrape_interval: 60s
Dashboards
The Raspberry Pi integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- Raspberry Pi / logs
- Raspberry Pi / overview
Raspberry Pi overview
Raspberry Pi logs
Alerts
The Raspberry Pi integration includes the following useful alerts:
raspberrypi-node-filesystem-alerts
Alert | Description |
NodeFilesystemAlmostOutOfSpace | Warning: Filesystem has less than 5% space left. |
NodeFilesystemAlmostOutOfSpace | Critical: Filesystem has less than 3% space left. |
NodeFilesystemFilesFillingUp | Warning: Filesystem is predicted to run out of inodes within the next 24 hours. |
NodeFilesystemFilesFillingUp | Critical: Filesystem is predicted to run out of inodes within the next 4 hours. |
NodeFilesystemAlmostOutOfFiles | Warning: Filesystem has less than 5% inodes left. |
NodeFilesystemAlmostOutOfFiles | Critical: Filesystem has less than 3% inodes left. |
raspberrypi-node-alerts
NodeNetworkReceiveErrs | Warning: Network interface is reporting many receive errors. |
NodeNetworkTransmitErrs | Warning: Network interface is reporting many transmit errors. |
NodeCPUHighUsage | Info: High CPU usage. |
NodeSystemSaturation | Warning: System saturated, load per core is very high. |
NodeMemoryMajorPagesFaults | Warning: Memory major page faults are occurring at very high rate. |
NodeMemoryHighUtilization | Warning: Host is running out of memory. |
NodeDiskIOSaturation | Warning: Disk IO queue is high. |
NodeSystemdServiceFailed | Warning: Systemd service has entered failed state. |
NodeHardwareTemperatureHigh | Warning: Sensor’s temperature is high. |
Metrics
The most important metrics provided by the Raspberry Pi integration, which are used on the pre-built dashboards and Prometheus alerts, are as follows:
- node_boot_time_seconds
- node_cpu_seconds_total
- node_disk_io_time_seconds_total
- node_disk_io_time_weighted_seconds_total
- node_disk_read_bytes_total
- node_disk_written_bytes_total
- node_filesystem_avail_bytes
- node_filesystem_files
- node_filesystem_files_free
- node_filesystem_readonly
- node_filesystem_size_bytes
- node_hwmon_temp_celsius
- node_load1
- node_load15
- node_load5
- node_memory_Buffers_bytes
- node_memory_Cached_bytes
- node_memory_MemAvailable_bytes
- node_memory_MemFree_bytes
- node_memory_MemTotal_bytes
- node_memory_Slab_bytes
- node_memory_SwapTotal_bytes
- node_network_receive_bytes_total
- node_network_receive_drop_total
- node_network_receive_errs_total
- node_network_receive_packets_total
- node_network_transmit_bytes_total
- node_network_transmit_drop_total
- node_network_transmit_errs_total
- node_network_transmit_packets_total
- node_os_info
- node_systemd_unit_state
- node_uname_info
- node_vmstat_pgmajfault
- up
Changelog
# 1.0.1 - November 2024
- Update status panel check queries
# 1.0.0 - December 2023
* Use latest linux observabiltiy library
* Add separate logs dashboard
* Add inventory panels row
* Add grafana annotations for events like reboot, OOMkill and others
* Add metrics and logs status panels
* Rename dashboards' prefix to 'Raspberry Pi /'
* Add new alerts: NodeCPUHighUsage, NodeSystemSaturation, NodeMemoryMajorPagesFaults, NodeDiskIOSaturation, NodeSystemdServiceFailed, NodeHardwareTemperatureHigh.
# 0.0.4 - September 2023
* Update Grafana Agent configuration snippets to include filtered metrics used in gauge panels
# 0.0.3 - August 2023
# 0.0.2 - July 2023
# 0.0.1 - September 2022
* Initial release
Cost
By connecting your Raspberry Pi instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
