ElasticSearch integration for Grafana Cloud
Elasticsearch is a search engine based on the Lucene library. It provides a distributed, multitenant-capable full-text search engine with an HTTP web interface and schema-free JSON documents.
This integration enables Grafana Alloy to send metrics to Grafana Cloud along with a useful pre-built dashboard for visualization.
This integration includes 1 pre-built dashboard to help monitor and visualize ElasticSearch metrics.
Before you begin
This integration relies on a dedicated Elastic Search cluster running alongside Grafana Alloy. See the following sections for details.
We strongly recommend that you configure a separate user for Alloy, and give it only the strictly mandatory security privileges necessary for monitoring your node, as per the official documentation.
Install ElasticSearch integration for Grafana Cloud
- Find ElasticSearch and click its tile to open the integration.
- Review the prerequisites in the Configuration Details tab and set up Grafana Alloy to send ElasticSearch metrics to your Grafana Cloud instance.
- Click Install to add this integration’s pre-built dashboard to your Grafana Cloud instance, and you can start monitoring your ElasticSearch setup.
Simple mode
These snippets are configured to scrape a single ElasticSearch instance running locally with default ports.
Integrations snippets
prometheus.exporter.elasticsearch "integrations_elasticsearch_exporter" { }
discovery.relabel "integrations_elasticsearch_exporter" {
targets = prometheus.exporter.elasticsearch.integrations_elasticsearch_exporter.targets
rule {
target_label = "job"
replacement = "integrations/elasticsearch_exporter"
rule {
target_label = "instance"
replacement = constants.hostname
prometheus.scrape "integrations_elasticsearch_exporter" {
targets = discovery.relabel.integrations_elasticsearch_exporter.output
job_name = "integrations/elasticsearch_exporter"
Advanced mode
To instruct Grafana Alloy to scrape your ElasticSearch instances, manually copy and append the snippets to your alloy configuration file, then follow subsequent instructions.
rule {
rule {
This integrations uses the prometheus.exporter.elasticsearch component to generate metrics from a ElasticSearch instance.
Set the address
argument to the address of your ElasticSearch instance.
For the full array of configuration options, refer to the prometheus.exporter.elasticsearch component reference documentation.
This exporter must be linked with a discovery.relabel component to apply the necessary relabelings.
For each ElasticSearch instance to be monitored you must create a pair of these components.
component:
instance
label:constants.hostname
sets theinstance
label to your Grafana Alloy server hostname. If that is not suitable, change it to a value uniquely identifies this ElasticSearch instance.
You can then scrape them by including each discovery.relabel
under targets
within the prometheus.scrape component.
This integration relies on a dedicated Elastic Search cluster running alongside Grafana Agent. See the following sections for details.
We strongly recommend that you configure a separate user for the Agent, and give it only the strictly mandatory security privileges necessary for monitoring your node, as per the official documentation.
- Review the prerequisites in the Configuration Details tab and set up Grafana Agent to send ElasticSearch metrics to your Grafana Cloud instance.
Post-install configuration for the ElasticSearch integration
This integration is configured to work with the Elasticsearch exporter
, which is embedded in Grafana Agent.
Enable the integration by adding the provided snippet to your agent configuration file.
Make sure to change the address
key to point to the Elasticsearch node appropriate to your environment.
Some exporter metrics are disabled by default. For a full description of configuration options see how to configure the elasticsearch_exporter_config
block in the agent documentation.
Below integrations
elasticsearch_exporter:
enabled: true
address: http://localhost:9200
instance: '<your-instance-name>'
relabel_configs:
- action: replace
replacement: integrations/elasticsearch_exporter
target_label: job
Refer to the following Grafana Agent configuration for a complete example that contains all the snippets used for the ElasticSearch integration. This example also includes metrics that are sent to monitor your Grafana Agent instance.
integrations:
prometheus_remote_write:
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
source_labels:
- __name__
enabled: true
relabel_configs:
- action: replace
target_label: job
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
filename: /tmp/positions.yaml
scrape_configs:
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
scrape_configs:
global:
scrape_interval: 60s
Dashboards
The ElasticSearch integration installs the following dashboards in your Grafana Cloud instance to help monitor your system.
- ElasticSearch Overview
Metrics
The most important metrics provided by the ElasticSearch integration, which are used on the pre-built dashboard, are as follows:
- elasticsearch_breakers_estimated_size_bytes
- elasticsearch_breakers_limit_size_bytes
- elasticsearch_breakers_tripped
- elasticsearch_cluster_health_active_primary_shards
- elasticsearch_cluster_health_active_shards
- elasticsearch_cluster_health_delayed_unassigned_shards
- elasticsearch_cluster_health_initializing_shards
- elasticsearch_cluster_health_number_of_data_nodes
- elasticsearch_cluster_health_number_of_nodes
- elasticsearch_cluster_health_number_of_pending_tasks
- elasticsearch_cluster_health_relocating_shards
- elasticsearch_cluster_health_status
- elasticsearch_cluster_health_unassigned_shards
- elasticsearch_filesystem_data_available_bytes
- elasticsearch_filesystem_data_size_bytes
- elasticsearch_indices_docs
- elasticsearch_indices_docs_deleted
- elasticsearch_indices_docs_primary
- elasticsearch_indices_fielddata_evictions
- elasticsearch_indices_fielddata_memory_size_bytes
- elasticsearch_indices_filter_cache_evictions
- elasticsearch_indices_flush_time_seconds
- elasticsearch_indices_flush_total
- elasticsearch_indices_get_exists_time_seconds
- elasticsearch_indices_get_exists_total
- elasticsearch_indices_get_missing_time_seconds
- elasticsearch_indices_get_missing_total
- elasticsearch_indices_get_time_seconds
- elasticsearch_indices_get_tota
- elasticsearch_indices_indexing_delete_time_seconds_total
- elasticsearch_indices_indexing_delete_total
- elasticsearch_indices_indexing_index_time_seconds_total
- elasticsearch_indices_indexing_index_total
- elasticsearch_indices_merges_docs_total
- elasticsearch_indices_merges_total
- elasticsearch_indices_merges_total_size_bytes_total
- elasticsearch_indices_merges_total_time_seconds_total
- elasticsearch_indices_query_cache_evictions
- elasticsearch_indices_query_cache_memory_size_bytes
- elasticsearch_indices_refresh_time_seconds_total
- elasticsearch_indices_refresh_total
- elasticsearch_indices_search_fetch_time_seconds
- elasticsearch_indices_search_fetch_total
- elasticsearch_indices_search_query_time_seconds
- elasticsearch_indices_search_query_total
- elasticsearch_indices_segment_doc_values_memory_bytes_primary
- elasticsearch_indices_segment_doc_values_memory_bytes_total
- elasticsearch_indices_segment_fields_memory_bytes_primary
- elasticsearch_indices_segment_fields_memory_bytes_total
- elasticsearch_indices_segments_count
- elasticsearch_indices_segments_memory_bytes
- elasticsearch_indices_store_size_bytes_primary
- elasticsearch_indices_store_size_bytes_total
- elasticsearch_indices_store_throttle_time_seconds_total
- elasticsearch_indices_translog_operations
- elasticsearch_indices_translog_size_in_bytes
- elasticsearch_jvm_gc_collection_seconds_count
- elasticsearch_jvm_gc_collection_seconds_sum
- elasticsearch_jvm_memory_committed_bytes
- elasticsearch_jvm_memory_max_bytes
- elasticsearch_jvm_memory_pool_peak_used_bytes
- elasticsearch_jvm_memory_used_bytes
- elasticsearch_os_load1
- elasticsearch_os_load15
- elasticsearch_os_load5
- elasticsearch_process_cpu_percent
- elasticsearch_process_open_files_count
- elasticsearch_thread_pool_active_count
- elasticsearch_thread_pool_completed_count
- elasticsearch_thread_pool_rejected_count
- elasticsearch_transport_rx_size_bytes_total
- elasticsearch_transport_tx_size_bytes_total
- up
Changelog
# 1.0.0 - February 2024
* Update mixin to replace all Angular panels with React based panels.
# 0.0.3 - August 2023
# 0.0.2 - September 2022
* Update mixin to latest version:
- Update the datasource template variable label to 'Data Source'
# 0.0.1 - February 2021
* Initial release
Cost
By connecting your ElasticSearch instance to Grafana Cloud, you might incur charges. To view information on the number of active series that your Grafana Cloud account uses for metrics included in each Cloud tier, see Active series and dpm usage and Cloud tier pricing.
