What's new from Grafana Labsbreadcrumb arrow Introducing Investigations
Grafana Cloud Available in public preview Open Source Enterprise Available in public preview
Release date
2025-05-05
Self-managed release
Grafana v12.0.0
This brand new feature, coming to Public Preview in Grafana v12, is designed to streamline how you approach problem-solving by bringing all your relevant signals together in one unified view.
Centralized Signal Analysis for Efficient Investigations
  • Add Panels from Any Signal: Investigations breaks down the silos between our Drilldown applications. You can now seamlessly add panels from Metrics, Logs, and Traces Drilldown directly into a single investigation view.
  • Side-by-Side Comparison Across Time: Gain deeper insights by comparing the behavior of your signals across two distinct timeframes, all within the same view. This allows for the rapid identification of correlations and anomalies.
  • Effortless Collaboration: Investigations make it easy to share your findings and the context of your analysis with other team members involved in the same task, fostering better collaboration and faster resolution.
Investigations provides a central hub to correlate and analyze diverse signals across the otherwise siloed Drilldown applications, leading to more efficient and effective troubleshooting.
