Integrate Hubot with Grafana
Introduction
Grafana 2.0 shipped with a great feature that enables it to render any graph or panel to a PNG image.
No matter what data source you are using, the PNG image of the Graph will look the same as it does in your browser.
This guide shows you how to install and configure the Hubot-Grafana plugin. This plugin allows you to tell Hubot to render any dashboard or graph right from a channel in Slack, Basecamp, or any other supported Hubot adapter. The bot will respond with an image of the graph and a link that will take you to the graph.
What is Hubot?
Hubot is an universal and extensible chat bot that can be used with many chat services and has a huge library of third party plugins that allow you to automate anything from your chat rooms.
Install Hubot
Hubot is very easy to install and host. If you do not already have a bot up and running please read the official Getting Started With Hubot guide.
Install the Hubot-Grafana script
In your Hubot project repo install the Grafana plugin using npm:
npm install hubot-grafana --saveEdit the file external-scripts.json, and add hubot-grafana to the list of plugins.
["hubot-pugme", "hubot-shipit", "hubot-grafana"]Configure
The Hubot-Grafana plugin requires two environment variables to be set in order to work properly.
export HUBOT_GRAFANA_HOST=https://play.grafana.org
export HUBOT_GRAFANA_API_KEY=abcd01234deadbeef01234There are additional environment variables that you can set to control the appearance of the graphs.
Grafana server side rendering
The hubot plugin will take advantage of the Grafana server side rendering feature that can render any panel on the server using phantomjs. Grafana ships with a phantomjs binary (Linux only).
To verify that this feature works try the Direct link to rendered image link in the panel share dialog. If you do not get an image when opening this link verify that the required font packages are installed for phantomjs to work.
Grafana API Key
You need to set the environment variable HUBOT_GRAFANA_API_KEY to a Grafana API Key. You can add these from the API Keys page which you find in the Organization dropdown.
Image uploading
There are several approaches to uploading the rendered graphs. If you are using Slack, Rocket.Chat, or Telegram, the adapter’s native uploader will take care of sending it through their respective API. If your Hubot is hosted on a platform that doesn’t support uploads (such as IRC), you can use the built-in S3 uploader. Note if you configure S3, it will not use the adapter’s upload features.
Hubot commands
hubot graf list- Lists the available dashboards
hubot graf db graphite-carbon-metrics- Graph all panels in the dashboard
hubot graf db graphite-carbon-metrics:3- Graph only panel with id 3 of a particular dashboard
hubot graf db graphite-carbon-metrics:cpu- Graph only the panels containing “cpu” (case insensitive) in the title
hubot graf db graphite-carbon-metrics now-12hr- Get a dashboard with a window of 12 hours ago to now
hubot graf db graphite-carbon-metrics now-24hr now-12hr- Get a dashboard with a window of 24 hours ago to 12 hours ago
hubot graf db graphite-carbon-metrics:3 now-8d now-1d- Get only the third panel of a particular dashboard with a window of 8 days ago to yesterday
hubot graf db graphite-carbon-metrics host=carbon-a- Get a templated dashboard with the
$hostparameter set tocarbon-a
Aliases
Some of the hubot commands above can lengthy and you might have to remember the dashboard slug (url id). If you have a few favorite graphs you want to be able check up on often (let’s say from your mobile) you can create hubot command aliases with the hubot script hubot-alias.
Install it:
npm i --save hubot-aliasNow add hubot-alias to the list of plugins in external-scripts.json and restart hubot.
Now you can add an alias like this:
hubot alias graf-lb=graf db loadbalancers:2 now-20m
Summary
Grafana is going to ship with integrated Slack and Hipchat features some day but you do not have to wait for that. Grafana 2 shipped with a very clever server side rendering feature that can render any panel to a png using phantomjs. The hubot plugin for Grafana is something you can install and use today!
