Build a panel plugin
Introduction​
Panels, which allow you to visualize data in different ways, are one of the fundamental building blocks of Grafana. Grafana has several types of panels already included, and many more available in the Grafana plugin catalog.
To add support for other visualizations, you can create your own panel plugin. Panels are ReactJS components and can be scaffolded with the create-plugin
tool.
For more information about panels, refer to the documentation on Panels.
Prerequisites​
- Grafana v10.0 or later
- LTS version of Node.js
Create a new plugin​
The Grafana create-plugin tool is a CLI application that simplifies Grafana plugin development, so that you can focus on code. The tool scaffolds a starter plugin, all the required configuration, and a development environment using Docker Compose for you.
In a new directory, create a plugin from a template using the create-plugin tool. When prompted for the kind of plugin, select panel:
npx @grafana/create-plugin@latest
Go to the directory of your newly created plugin:
cd <your-plugin>
Install the dependencies:
npm install
Build the plugin:
npm run dev
Start Grafana:
docker compose up
Open Grafana, by default http://localhost:3000, and then go to Administration > Plugins. Make sure that your panel plugin is there.
You can also verify that Grafana has discovered your plugin by checking the logs:
INFO[01-01|12:00:00] Plugin registered logger=plugin.loader pluginID=<your-plugin>
Anatomy of a plugin​
Every plugin you create requires at least two files: plugin.json
and src/module.ts
plugin.json
When Grafana starts, it scans the plugin directory for any subdirectory that contains a plugin.json
file. The plugin.json
file contains information about your plugin and tells Grafana about what capabilities and dependencies your plugin needs.
While certain plugin types can have specific configuration options, let's look at the mandatory ones:
type
tells Grafana what type of plugin to expect. Grafana supports three types of plugins:panel
,datasource
, andapp
.name
is what users will see in the list of plugins. If you're creating a data source, this is typically the name of the database it connects to, such as Prometheus, PostgreSQL, or Stackdriver.id
uniquely identifies your plugin and should follow this naming convention:<$organization-name>-<$plugin-name>-<$plugin-type>
. The create-plugin tool correctly configures this based on your responses to its prompts.
To see all the available configuration settings for the plugin.json
, refer to the plugin.json Schema.
module.ts
After discovering your plugin, Grafana loads the module.js
file, the entrypoint for your plugin. module.js
exposes the implementation of your plugin, which depends on the type of plugin you're building.
Specifically, src/module.ts
needs to export a class that extends GrafanaPlugin, and can be any of the following:
Panel plugins​
Panel properties​
The PanelProps interface exposes runtime information about the panel, such as panel dimensions, and the current time range.
You can access the panel properties through the props
argument, as seen in your plugin.
export const SimplePanel: React.FC<Props> = ({ options, data, width, height }) => {
Development workflow​
Next, you'll learn the basic workflow of making a change to your panel, building it, and reloading Grafana to reflect the changes you made.
First, you need to add your panel to a dashboard:
Add your panel to a dashboard​
Open Grafana in your browser. By default, Grafana is accessible at http://localhost:3000.
Create a new dashboard.
- From the menu, select Dashboards.
- On the top right, select New -> Dashboard.
- Select Add Visualization to start configuring your new panel.
Configure the
TestData
data source. In the data source configuration modal, select the TestData DB data source for this dashboard. -
Search and select your panel plugin. In the panel configuration view, go to the Visualization list on the right side, search for your panel plugin, and select it.
Save the dashboard.
Alternative: Use the provisioned sample panel dashboard​
You can also view your panel in action through a pre-configured dashboard:
- Go to Dashboards and select the Provisioned Sample Panel Dashboard.
- The TestData DB data source is already configured with sample data for this dashboard.
- To edit, find your panel in this dashboard and click the menu (that is, the three vertical dots) at the top right corner of your panel.
- From the dropdown menu, select Edit to customize or examine your panel's settings.
Now that you can view your panel, try making a change to the panel plugin:
In
SimplePanel.tsx
, change the fill color of the circle. For example, to change it to green:src/components/SimplePanel.tsx<circle style={{ fill: theme.visualization.getColorByName('green') }} r={100} />
Save the file.
In the browser, reload Grafana. The changes should appear.
Add panel options​
Sometimes you want to offer the users of your panel an option to configure the behavior of your plugin. By configuring panel options for your plugin, your panel will be able to accept user input.
In the previous step, you changed the fill color of the circle in the code. Let's change the code so that the plugin user can configure the color from the panel editor.
Add an option​
Panel options are defined in a panel options object. SimpleOptions
is an interface that describes the options object.
In
types.ts
, add aCircleColor
type to hold the colors the users can choose from:type CircleColor = 'red' | 'green' | 'blue';
In the
SimpleOptions
interface, add a new option calledcolor
:color: CircleColor;
Here's the updated options definition:
type SeriesSize = 'sm' | 'md' | 'lg';
// interface defining panel options type
export interface SimpleOptions {
text: string;
showSeriesCount: boolean;
seriesCountSize: SeriesSize;
color: CircleColor;
Add an option control​
To change the option from the panel editor, you need to bind the color
option to an option control.
Grafana supports a range of option controls, such as text inputs, switches, and radio groups.
Let's create a radio control and bind it to the color
option.
Add the control at the end of the builder:
src/module.ts.addRadio({
path: 'color',
defaultValue: 'red',
settings: {
options: [
value: 'red',
label: 'Red',
value: 'green',
label: 'Green',
value: 'blue',
label: 'Blue',
});The
path
is used to bind the control to an option. You can bind a control to nested option by specifying the full path within a options object, for examplecolors.background
Grafana builds an options editor for you and displays it in the panel editor sidebar in the Display section.
Use the new option​
You're almost done. You've added a new option and a corresponding control to change the value. But the plugin isn't using the option yet. Let's change that.
To convert option value to the colors used by the current theme, add the following statement right before the
return
statement inSimplePanel.tsx
.src/components/SimplePanel.tsxlet color = theme.visualization.getColorByName(options.color);
Configure the circle to use the color.
src/components/SimplePanel.tsx<g>
<circle style={{ fill: color }} r={100} />
</g>
Now, when you change the color in the panel editor, the fill color of the circle changes as well.
Create dynamic panels using data frames​
Most panels visualize dynamic data from a Grafana data source. In this step, you'll create one circle per series, each with a radius equal to the last value in the series.
To use data from queries in your panel, you need to set up a data source. If you don't have one available, you can use the TestData data source while developing.
When adding your panel to a dashboard, configure it with a data source to populate it with data dynamically. Alternatively, you can use the Provisioned Sample Panel Dashboard, which is already configured with a sample data source.
Using the provisioned sample panel dashboard​
The Provisioned Sample Panel Dashboard comes preconfigured with the TestData
data source. This setup includes sample data for testing and development. The sample data is in the raw_frame
scenario of the TestData
data source and consists of two time series with the same timestamps, as shown in the following table. The table displays these two time series joined by a timestamp:
Timestamp | Label1 | Value1 | Label2 | Value2 |
2020-12-31 19:00:00 | A | 10 | A | 40 |
2020-12-31 20:00:00 | B | 20 | B | 50 |
2020-12-31 21:00:00 | C | 15 | C | 45 |
2020-12-31 22:00:00 | D | 25 | D | 55 |
2020-12-31 23:00:00 | E | 30 | E | 60 |
This setup allows you to test your panel’s dynamic elements using real sample data, structured with multiple series for more complex visualization.
The results from a data source query within your panel are available in the data
property inside your panel component.
const { data } = props;
The data.series
contains the series returned from a data source query. Each series is represented as a data structure called data frame. A data frame resembles a table, where data is stored by columns, or fields, instead of rows. Every value in a field share the same data type, such as string, number, or time.
Here's an example of a data frame with a time field, Time
, and a number field, Value
Time | Value |
1589189388597 | 32.4 |
1589189406480 | 27.2 |
1589189513721 | 15.0 |
Provisioned sample panel dashboard** sample data:
Let's see how you can retrieve data from a data frame and use it in your visualization.
Get the last value of each field of type
number
, by adding the following toSimplePanel.tsx
, before thereturn
statement:src/components/SimplePanel.tsxconst radii = data.series
.map((series) => series.fields.find((field) => field.type === 'number'))
.map((field) => field?.values.get(field.values.length - 1));radii
will contain the last values in each of the series that are returned from a data source query. You'll use these to set the radius for each circle. -
Change the
svg
element to the following:src/components/SimplePanel.tsx<svg
className={styles.svg}
width={width}
height={height}
xmlns="http://www.w3.org/2000/svg"
xmlnsXlink="http://www.w3.org/1999/xlink"
viewBox={`0 -${height / 2} ${width} ${height}`}
<g fill={color}>
{radii.map((radius, index) => {
const step = width / radii.length;
return <circle r={radius} transform={`translate(${index * step + step / 2}, 0)`} />;
</g>
</svg>Note how we're creating a
<circle>
element for each value inradii
:src/components/SimplePanel.tsx{
}We use the
transform
here to distribute the circle horizontally within the panel. -
Rebuild your plugin and try it out by adding multiple queries to the panel. Refresh the dashboard.
If you want to know more about data frames, check out our introduction to Data frames.
Summary​
In this tutorial you learned how to create a custom visualization for your dashboards.
