title: "Compact Hostmap Panel plugin for Grafana"
description: "Grafana Compact Hostmap Panel Plugin. Compact Hostmap Panel plugin for Grafana by zestairlove. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/zestairlove-compacthostmap-panel/
# Compact Hostmap Panel
- Developer: zestairlove
- Version: 0.9.2
- [Installation](https://grafana.com/grafana/plugins/zestairlove-compacthostmap-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/zestairlove-compacthostmap-panel/changelog.md)
![screenshot1](https://grafana.com/api/plugins/zestairlove-compacthostmap-panel/versions/0.9.2/images/img/screenshot1.png)
![screenshot2](https://grafana.com/api/plugins/zestairlove-compacthostmap-panel/versions/0.9.2/images/img/screenshot2.png)
![screenshot3](https://grafana.com/api/plugins/zestairlove-compacthostmap-panel/versions/0.9.2/images/img/screenshot3.png)
![screenshot4](https://grafana.com/api/plugins/zestairlove-compacthostmap-panel/versions/0.9.2/images/img/screenshot4.png)
# Compact Hostmap Panel for Grafana
Grafana Panel Plugin to easily understand the host's system metric at a glance
![Screenshot_2022-05-20_16-59-14](https://user-images.githubusercontent.com/24940457/169499252-a461fbd3-43b6-474e-ae9c-f6aa2da8a521.png)
## Supported Datasources
- promethues
- elasticsearch
tested.
Supports Grafana plugin interface data frames, groupBy each frame based on `name` || field's `config.displayName` || `config.displayNameFromDS` field's key.
![Screenshot_2022-05-20_18-24-46](https://user-images.githubusercontent.com/24940457/169500225-c5f89483-fdab-4798-8933-4df6521c7598.png) ![Screenshot_2022-05-20_18-25-13](https://user-images.githubusercontent.com/24940457/169500261-fa9db043-325b-40ba-8eeb-4f425bf9c724.png)
## ETC
HostItem is rendered in response to panel size, and Color Threshold is mapped to the largest value.
![Screenshot_2022-05-20_18-23-49](https://user-images.githubusercontent.com/24940457/169500959-910ca82b-5561-493b-9fb7-5d41fa221973.png)
