Plugins 〉yesoreyeram-infinity-panel
Grafana Cloud Free
Grafana Cloud Free
Grafana Cloud Free
.h4 . .mb-0 }
Grafana Cloud Free
Grafana Cloud Free
Installing yesoreyeram-infinity-panel on Grafana Cloud:
1. Install the Panel
Use the grafana-cli tool to install yesoreyeram-infinity-panel from the commandline:
grafana-cli plugins install
