title: "Boom Theme panel plugin for Grafana"
description: "Themes for Grafana. Boom Theme panel plugin for Grafana by Sriramajeyam Sugumaran. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/yesoreyeram-boomtheme-panel/
# Boom Theme
- Developer: Sriramajeyam Sugumaran
- Version: 0.2.1
- [Installation](https://grafana.com/grafana/plugins/yesoreyeram-boomtheme-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/yesoreyeram-boomtheme-panel/changelog.md)
# Boom Theme Panel
[![Build & Publish](https://github.com/yesoreyeram/yesoreyeram-boomtheme-panel/workflows/Build%20&%20Publish/badge.svg)](https://github.com/yesoreyeram/yesoreyeram-boomtheme-panel/actions?query=workflow%3A%22Build+%26+Publish%22) [![Release](https://github.com/yesoreyeram/yesoreyeram-boomtheme-panel/workflows/Release/badge.svg)](https://github.com/yesoreyeram/yesoreyeram-boomtheme-panel/actions?query=workflow%3ARelease)
Theme switcher with custom styles / themes for grafana dashboards.
![image](https://user-images.githubusercontent.com/153843/99880461-5e1aa900-2c0b-11eb-9c28-3c80381f2504.png) ![image](https://user-images.githubusercontent.com/153843/99880502-a20dae00-2c0b-11eb-8355-c7c87bcb2f5c.png)
## Features
- Theme switcher
- Multiple themes per dashboard
- Theme builder
- External stylesheets support
- Add inline styles to themes to override styles
- Add many themes as possible without rebuilding / restarting grafana
- Users can change the themes without editing the dashboard
- Dashboard specific themes
## Creating Theme
Themes can be created with multiple building blocks like background image, base theme etc.
| Property                    | Description        |
| Base theme                  | Themes can be built on top of default/dark/light theme. Default is **Default Theme**                     |
| Background image            | Optional property. Can be blank. If specified more than once, last wins. Value should be valid image URL |
| CSS url                     | External theme file. Should be valid CSS file URL                                                        |
| Custom Style / CSS Override | CSS Styles. Should be valid css        |
| Panel container BG          | Background color for the panels        |
## Supported Grafana version
This grafana plugin is tested with the following grafana versions, But other versions are also expected to work.
- Grafana version 8.x
- Grafana version 7.x
- Grafana version 6.x
## Notes
- When adding external stylesheets, make sure CORS enabled for those domains.
- To make panel invisible : Modify following theme panel settings:
  - transparent = true
  - title = ""
  - Disable Theme Picker using panel settings
  - Move this panel to the bottom of the dashboard
  - Adjust the height and width if required.
## Known issues / Limitations
- If any custom plugin is used, dark/light theme switch, base theme will not work for those custom plugins. Refer [this](https://github.com/yesoreyeram/yesoreyeram-boomtheme-panel/issues/3) github issue
- Theme panel should be within view port. Otherwise, Grafana won't render the theme. Refer [this](https://github.com/yesoreyeram/yesoreyeram-boomtheme-panel/issues/17)
## Installation Instructions
There are multiple ways to install this plugin into your grafana instance
### Download and extract zip file
Download the zip file from [github releases page](https://github.com/yesoreyeram/yesoreyeram-boomtheme-panel/releases) and extract into your grafana plugin folder. Then restart Grafana.
### Using grafana-cli
If you are using grafana-cli, execute the following command to install the plugin
```sh
grafana-cli plugins install yesoreyeram-boomtheme-panel
or for specific versions
```sh
grafana-cli --pluginUrl https://github.com/yesoreyeram/yesoreyeram-boomtheme-panel/releases/download/v0.2.1/yesoreyeram-boomtheme-panel-0.2.1.zip plugins install yesoreyeram-boomtheme-panel
### Using helm chart
If you use helm chart to provision grafana, use the following config to install the plugin
```yml
plugins:
  - yesoreyeram-boomtheme-panel
or for any specific versions
```yml
plugins:
  - https://github.com/yesoreyeram/yesoreyeram-boomtheme-panel/releases/download/v0.2.1/yesoreyeram-boomtheme-panel-0.2.1.zip;yesoreyeram-boomtheme-panel
