title: "Timepicker Buttons Panel plugin for Grafana"
description: "Datasource-configured buttons panel plugin which set the time range of your Grafana dashboard. Timepicker Buttons Panel plugin for Grafana by williamvenner."
> This is the Markdown version of https://grafana.com/grafana/plugins/williamvenner-timepickerbuttons-panel/
# Timepicker Buttons Panel
- Developer: williamvenner
- Version: 4.1.1
- [Installation](https://grafana.com/grafana/plugins/williamvenner-timepickerbuttons-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/williamvenner-timepickerbuttons-panel/changelog.md)
![Panel](https://grafana.com/api/plugins/williamvenner-timepickerbuttons-panel/versions/4.1.1/images/img/panel.png)
![SQL Queries](https://grafana.com/api/plugins/williamvenner-timepickerbuttons-panel/versions/4.1.1/images/img/sql_queries.png)
# Timepicker Buttons Panel for Grafana
[![license](https://img.shields.io/github/license/mashape/apistatus.svg)](https://grafana.com/grafana/plugins/williamvenner-timepickerbuttons-panel/)
A Grafana panel which allows you to create a list of buttons which set specific times (retrieved from a datasource) on the dashboard's timepicker when clicked.
![Panel Screenshot Vertical Buttons](https://i.imgur.com/ft77DQM.png) ![Panel Screenshot Dropdown List](https://i.imgur.com/1XvGim1.png) ![Panel Screenshot Horizontal Buttons](https://i.imgur.com/qUAIQF9.png)
## Compatibility
This plugin works with Grafana 7.0.0 and up.
For older versions, check out the [releases](https://github.com/WilliamVenner/grafana-timepicker-buttons/releases) page.
## Installation
```bash
sudo service grafana-server stop
cd /var/lib/grafana/plugins
sudo git clone https://github.com/WilliamVenner/grafana-timepicker-buttons
sudo mv grafana-timepicker-buttons williamvenner-timepickerbuttons-panel
sudo chown grafana:grafana williamvenner-timepickerbuttons-panel -R
sudo chmod 774 williamvenner-timepickerbuttons-panel -R
sudo service grafana-server start
## Usage
### Display Style Configuration
The timepicker can be configured to display buttons (vertically or horizontally), or as a dropdown list.
![Panel Options Buttons](https://i.imgur.com/9wuLCiW.png) ![Panel Options Dropdown List](https://i.imgur.com/glaCfLy.png)
### Field Mapping
All dates and times should use UTC.
**The data returned from the datasource must be formatted as a _Table_**, not a _Time Series_.
The panel can be configured to indicate which fields are mapped to the button properties:
![Panel Options](https://i.imgur.com/IioqIhH.png)
The data fields returned from the datasource should be mapped with the following panel configuration settings:
| Column                | Default Value | Description        |
| **Time From Field**   | time_from     | **Required**<br>A UNIX Timestamp (`Number`)<br>This will set the "From" part of the time range.<br>The value can include or exclude ms. Example: 1612413008000 or 1612413008                                                     |
| **Time To Field**     | time_to       | _Optional_<br>A UNIX Timestamp (`Number`)<br>This will set the "To" part of the time range.<br>The value can include or exclude ms. Example: 1612413008000 or 1612413008<br>_If this is not supplied, it will default to `now`._ |
| **Button Text Field** | button_text   | _Optional_<br>What the text inside the button will say.<br>_If this is not supplied, it will default to a locale-formatted timestamp._        |
| **Primary Field**     | primary       | _Optional_<br>Field used to determine if the button will be marked with a `star` icon        |
| **Primary Value**     | 1             | _Optional_<br>A Regex pattern to perform on the `Primary Field`. If matched the button will be marked with a `star` icon.        |
![Example Screenshot](https://i.imgur.com/EbL6oMv.png)
**Credit**
Logo made by [DinosoftLabs](https://flaticon.com/authors/dinosoftlabs) on [www.flaticon.com](https://flaticon.com/)
