title: "Business Variable panel plugin for Grafana"
description: "Enhances dashboards with movable, standalone filter panels for dynamic control. Business Variable panel plugin for Grafana by Grafana Labs."
> This is the Markdown version of https://grafana.com/grafana/plugins/volkovlabs-variable-panel/
# Business Variable
- Developer: Grafana Labs
- Version: 5.2.0
- [Installation](https://grafana.com/grafana/plugins/volkovlabs-variable-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/volkovlabs-variable-panel/changelog.md)
![Panel](https://grafana.com/api/plugins/volkovlabs-variable-panel/versions/5.2.0/images/img/dashboard.png)
# Business Variable for Grafana
[![Marketplace](https://img.shields.io/badge/dynamic/json?url=https%3A%2F%2Fgrafana.com%2Fapi%2Fplugins%2Fvolkovlabs-variable-panel\&label=Marketplace\&query=%24.version\&prefix=v\&color=orange)](https://grafana.com/grafana/plugins/volkovlabs-variable-panel/) [![Downloads](https://img.shields.io/badge/dynamic/json?url=https%3A%2F%2Fgrafana.com%2Fapi%2Fplugins%2Fvolkovlabs-variable-panel\&label=Downloads\&query=%24.downloads\&color=blue)](https://grafana.com/grafana/plugins/volkovlabs-variable-panel/) [![CI](https://github.com/grafana/business-variable/actions/workflows/push.yml/badge.svg)](https://github.com/grafana/business-variable/actions/workflows/push.yml) [![CD](https://github.com/grafana/business-variable/actions/workflows/publish.yml/badge.svg)](https://github.com/grafana/business-variable/actions/workflows/publish.yml) [![License](https://img.shields.io/github/license/grafana/business-variable)](https://github.com/grafana/business-variable/blob/main/LICENSE)
> This project was originally contributed by [Volkov Labs](https://github.com/volkovlabs/business-variable) — thanks for all your great work!
> We have republished under the same plugin ID, keeping the community signature. This means you can simply update your plugin version. A new ID would have required manual updates to your dashboards. For additional information on the changes, see the [Notices](https://github.com/grafana/business-variable/blob/main/NOTICES.md).
This project is currently maintained by Grafana Labs. We welcome pull requests and will review them on a best-effort basis. If you're interested in taking on this project long-term, contact <integrations@grafana.com>. We're eager to work with new maintainers and eventually hand over the project.
**Business Variable** transforms how you interact with Grafana dashboard variables. Place it anywhere on your dashboard and choose from multiple layouts, including an advanced **TreeView** option, to simplify filtering and boost usability.
## 🚀 Key Features
- **Display Modes**: Choose from Table, Minimize, Button, or Slider layouts.
- **TreeView**: Hierarchical data visualization within Table mode for complex nested variables.
- **Thresholds**: Highlight statuses using data source thresholds for visual clarity.
- **Variable Support**: Handle single or multi-value variables with an "All" option.
- **Filtering**: Apply pattern-based or favorite-based value filtering to quickly find options.
- **Sticky Positioning**: Panel follows scrolling for easy access across long dashboards.
- **Tabbed TreeViews**: Organize multiple TreeViews into groups or tabs for better organization.
- **Input Box**: Support for text input variables with custom validation.
- **Responsive Design**: Adapts seamlessly to different screen sizes and panel dimensions.
- **Theming**: Fully compatible with Grafana's light and dark themes.
## 📋 Requirements
| Plugin Version                | Compatible Grafana Versions |
| **Business Variable 5.2+**    | Grafana 12.3 or later       |
| **Business Variable 5.0–5.1** | Grafana 11.5 or 12          |
| **Business Variable 4.x**     | Grafana 11 or 12            |
| **Business Variable 3.x**     | Grafana 10.3 or 11          |
| **Business Variable 1.x/2.x** | Grafana 9.2 or 10           |
## 🛠️ Installation
Install the Business Variable panel through the [Grafana Plugins Catalog](https://grafana.com/grafana/plugins/volkovlabs-variable-panel/) or using the Grafana CLI:
```bash
grafana-cli plugins install volkovlabs-variable-panel
After installation, restart Grafana and add the **Business Variable** panel to your dashboard.
## 📚 Documentation
Dive into detailed guides to make the most of Business Variable:
| Section        | Description                          |
| [Data flow](https://grafana.com/docs/plugins/volkovlabs-variable-panel/latest/data-flow/)       | Understand the panel's data flow     |
| [Display mode](https://grafana.com/docs/plugins/volkovlabs-variable-panel/latest/display-mode/) | Explore layout customization options |
| [Features](https://grafana.com/docs/plugins/volkovlabs-variable-panel/latest/features/)         | Learn about key capabilities         |
| [Release notes](https://grafana.com/grafana/plugins/volkovlabs-variable-panel/?tab=changelog)   | Stay updated with recent changes     |
## 📜 License
This project is licensed under the [Apache License 2.0](https://github.com/grafana/business-variable/blob/main/LICENSE).
