Business Media for Grafana
This project was originally contributed by Volkov Labs - thanks for all your great work!
We have republished under the same plugin ID, keeping the community signature. This means you can simply update your plugin version. A new ID would have required manual updates to your dashboards. For additional information on the changes, see the Notices.
Business Media is a powerful Grafana plugin designed to display a variety of media files, including PNG, JPG, GIF, MP4, WEBM, MP3, OGG, and PDF, using base64 encoding or direct URLs. Seamlessly integrate multimedia content into your Grafana dashboards with ease and flexibility.
Features
- Versatile Media Support: Render images, videos, audio, and PDFs using base64-encoded data or URLs.
- Pagination: Display multiple media files with intuitive pagination controls.
- Flexible Data Handling: Supports base64 content with or without format definitions
(e.g.,
data:image/jpg;base64,ENCODED-CONTENT). - Field Selection: Choose specific fields from data sources returning multiple string fields.
- Customizable Display: Fit media to panel size, retain original dimensions, or set custom dimensions.
- Interactive Navigation: Add clickable URLs with titles to link to other dashboards, supporting dashboard variables.
- User-Friendly Toolbar: Download, zoom, and navigate between media files effortlessly.
Requirements
Ensure your Grafana version meets the requirements for the Business Media panel:
| Plugin Version | Compatible Grafana Versions |
| Business Media 7.X | Grafana 12 |
| Business Media 6.X | Grafana 10, Grafana 11 |
| Business Media 5.X | Grafana 10, Grafana 11 |
| Base64 Image/PDF 4.X | Grafana 9, Grafana 10 |
| Base64 Image/PDF 3.X | Grafana 8.5, Grafana 9 |
| Base64 Image/PDF 2.X | Grafana 8 |
| Base64 Image/PDF 1.X | Grafana 7.1 |
Installation
Install the Business Media panel via the Grafana Plugins Catalog or using the Grafana CLI.
Using Grafana CLI
grafana cli plugins install volkovlabs-image-panel
Documentation
Explore detailed guides and resources to make the most of the Business Media panel:
| Section | Description |
| Supported Formats | Supported media formats. |
| Options | Configuration options. |
| Features | Panel capabilities. |
| Release notes | Latest changes. |
License
This project is licensed under the Apache License Version 2.0. See the LICENSE file for details.
- ...and more
Insights
- Adoption
Running on 8,947 active Grafana instances.
- Activity
Last updated 21 May 2026.
2 releases in the past year.
- Version
- 7.3.3
- Dependencies
- Grafana >=12.0.0
- Developer
- Grafana Labs
- ...and more
