title: "Mapgl panel plugin for Grafana"
description: "Node Graph and Network Geomap. Mapgl panel plugin for Grafana by Vadim Pyatakov. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/vaduga-mapgl-panel/
# Mapgl
- Developer: Vadim Pyatakov
- Version: 2.11.1
- [Installation](https://grafana.com/grafana/plugins/vaduga-mapgl-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/vaduga-mapgl-panel/changelog.md)
![Service graph](https://grafana.com/api/plugins/vaduga-mapgl-panel/versions/2.11.1/images/img/screenshots/screenshot1.png)
![Node graph](https://grafana.com/api/plugins/vaduga-mapgl-panel/versions/2.11.1/images/img/screenshots/screenshot2.png)
![Geomap](https://grafana.com/api/plugins/vaduga-mapgl-panel/versions/2.11.1/images/img/screenshots/screenshot3.png)
![Namespaces](https://grafana.com/api/plugins/vaduga-mapgl-panel/versions/2.11.1/images/img/screenshots/screenshot4.png)
[![Downloads](https://img.shields.io/badge/dynamic/json?url=https%3A%2F%2Fgrafana.com%2Fapi%2Fplugins%2Fvaduga-mapgl-panel\&query=%24.downloads\&logo=grafana\&label=downloads)](https://grafana.com/grafana/plugins/vaduga-mapgl-panel) [![Project Site](https://img.shields.io/badge/Project-site-blue)](https://mapgl.org/) [![Discord](https://img.shields.io/discord/973739619118088232?logo=discord\&logoColor=%232490D7)](https://discord.gg/DZCAfzYwjC) [![Telegram Url](https://img.shields.io/badge/Telegram-blue?logo=telegram)](https://t.me/mapgrafana) [✉️](mailto:arbitr38@gmail.com)
Start a new panel with a mock node graph to test styles and modes.
### Node graph for metrics and traces
- Layered auto-layout and Geomap view
- Multistep and parallel edge routing
- Arc segments on nodes for visualizing multiple metrics
- TX/RX interface load visualization with dual-metric arcs
- Ad hoc filtering by layer and node group through the legend
- WebGL-accelerated rendering for large datasets
- Dynamic drill-down links to external panels
- Distributed tracing paths with per-span properties
- Namespace-based subgraphs
### 🕹️ Demo
[Playground](https://play.mapgl.org/) with open configuration
![Geomap](https://mapgl.org/img/drilldown.png) ![NodeGraph](https://mapgl.org/img/graph0.png)
### Data Format
![Dataframe](https://mapgl.org/img/screenshot3.png)
\*Unified dataframe model for nodes and edges. Field names are examples only; Mapgl does not require fixed field names.
See [Panel configuration](https://mapgl.org/documentation) for setup details and dataframe usage.
### Data Source
Use Grafana’s built-in transformations to prepare and merge data from:
- Postgres
- Prometheus
- Zabbix
- [Netbox](https://grafana.com/grafana/plugins/netboxlabs-netbox-datasource/) datasource ('Topology edges' query)
- Infinity (JSON API)
- Any other datasource
[Netbox + Prometheus with drill-down](https://gfn-gp4l-rare.public.nmaas.eu/d/ae996h5rebcw0d/gp4l-topology-mapgl3a-netbox)\
[Netbox to Mapgl automation](https://github.com/hamptik/netbox2mapgl)\
[Zabbix events on geomap](https://mapgl.org/zabbix)
### Field Config
Native Grafana:
- `Thresholds` – value ranges with associated colors to visually indicate status
- `Mapping` – rename displayed values
- `Units` – measurement unit conversion
- `Overrides` – custom settings for specific metrics
- `DataLinks` – links to external dashboards or graphs
Mapgl **Node Group style** rules extend control over node color, icon, size, and line width.
