title: "Breadcrumb panel plugin for Grafana"
description: "Breadcrumb Panel for Grafana. Breadcrumb panel plugin for Grafana by timomyl. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/timomyl-breadcrumb-panel/
# Breadcrumb
- Developer: timomyl
- Version: 1.2.0
- [Installation](https://grafana.com/grafana/plugins/timomyl-breadcrumb-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/timomyl-breadcrumb-panel/changelog.md)
![Showcase](https://grafana.com/api/plugins/timomyl-breadcrumb-panel/versions/1.2.0/images/img/breadcrumb-screenshot.png)
# Breadcrumb Panel Plugin for Grafana
This is a panel plugin for [Grafana](http://grafana.org/). It keeps track of dashboards you have visited within one session and displays them as a breadcrumb. Each dashboard is added only once to the breadcrumb. You can navigate back to some dashboard in breadcrumb by clicking the dashboard name link text. When navigation back all items coming after the selected dashboard will be removed from the breadcrumb. Note that breadcrumb can track only dashboards that have breadcrumb panel on them.
To understand what is a plugin, read the [Grafana's documentation about plugins](http://docs.grafana.org/plugins/development/).
## Options
Is root dashboard - Panel has an option for setting it as the root. If set, this will clear breadcrumb in root dashboard. Hide text in root dashboard - Don't show anything if breadcrumb has only one item Limit the amount of breadcrumb items to - The amount of breadcrumb items is limited by default. The oldest item is removed when exceeded.
