title: "Matomo Tracker panel plugin for Grafana"
description: "Panel for tracking via Matomo. Matomo Tracker panel plugin for Grafana by thiagoarrais. Available in Grafana Cloud and self-managed Grafana."
> This is the Markdown version of https://grafana.com/grafana/plugins/thiagoarrais-matomotracking-panel/
# Matomo Tracker
- Developer: thiagoarrais
- Version: 0.2.3
- [Installation](https://grafana.com/grafana/plugins/thiagoarrais-matomotracking-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/thiagoarrais-matomotracking-panel/changelog.md)
![editor](https://grafana.com/api/plugins/thiagoarrais-matomotracking-panel/versions/0.2.3/images/img/screenshot.png)
# Matomo Tracking Panel
Like a tracking pixel, but it is a Grafana Panel.
This panel allows Grafana dashboard usage to be tracked using [Matomo](https://matomo.org/). It does only tracking and has minimal visible presence.
This is independently developed. It is not an official Matomo product, and is not affiliated with, or sponsored by, Matomo.
## Requirements
Compatible with Grafana 7.x
## Installation
Install by using grafana-cli
grafana-cli plugins install thiagoarrais-matomotracking-panel
## Usage
Include only one panel per dashboard that should be tracked. Use the configuration editor to set the URL for your Matomo instance and your site ID.
The panel does not have any visible UI. We suggest that it should be resized to a minimal.
## Credits
Sponsored by [Serpro](https://www.serpro.gov.br/)
