title: "Leaflet Choropleth panel plugin for Grafana"
description: "Choropleth map panel using Leaflet and chroma-js for Grafana. Leaflet Choropleth panel plugin for Grafana by teosibileau."
> This is the Markdown version of https://grafana.com/grafana/plugins/teosibileau-leafletchoropleth-panel/
# Leaflet Choropleth
- Developer: teosibileau
- Version: 1.0.0
- [Installation](https://grafana.com/grafana/plugins/teosibileau-leafletchoropleth-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/teosibileau-leafletchoropleth-panel/changelog.md)
![Choropleth map](https://grafana.com/api/plugins/teosibileau-leafletchoropleth-panel/versions/1.0.0/images/img/screenshot-choropleth.png)
# Grafana Leaflet Choropleth Panel
Cross-reference time-series metric data with GeoJSON to display colored polygons on a Leaflet map. A [choropleth map](https://en.wikipedia.org/wiki/Choropleth_map) shades regions proportionally to a statistical variable, making it easy to visualize how a measurement varies across geographic areas.
![Choropleth panel screenshot](https://raw.githubusercontent.com/teosibileau/grafana-leaflet-choropleth-panel/master/src/img/screenshot-choropleth.png)
## Requirements
- Grafana >= 10.0.0
- Node.js >= 22 (see `.nvmrc`)
- [pnpm](https://pnpm.io/) (declared in `package.json` `packageManager` field)
- Docker & Docker Compose (for the local dev environment)
## Getting started
**Terminal 1** — start the webpack dev build in watch mode:
```bash
pnpm install
pnpm run dev
**Terminal 2** — start the Docker Compose environment:
```bash
docker compose up --build
# or: pnpm run server
Then open [http://localhost:3000](http://localhost:3000/) in your browser. A provisioned dashboard is loaded automatically.
> **Note:** An [Ahoy](https://github.com/ahoy-cli/ahoy) configuration (`.ahoy.yml`) is included as an optional convenience wrapper around these commands.
## Development environment
`docker compose up` starts two services:
- **Grafana** (port 3000) — runs the plugin from the `dist/` directory. Anonymous admin access is enabled so no login is required. A livereload script is injected into the Grafana HTML (see `.docker/grafana/Dockerfile`) so webpack rebuilds trigger automatic browser refresh.
- **InfluxDB 1.8** (port 8086) — pre-seeded with one year of hourly data via init scripts in `.docker/influxdb/`.
A provisioned datasource and dashboard are auto-loaded from `.docker/grafana/provisioning/` on startup.
## Configuration
These panel options are defined in `src/module.ts`:
| Option          | Description                                    | Default   |
| GeoJSON Data    | Fetch & store GeoJSON for the choropleth layer | —         |
| Hot Color       | Color for maximum values                       | `#ff0000` |
| Cold Color      | Color for minimum values                       | `#0000ff` |
| GeoJSON Key     | Feature property used to match metric series   | —         |
| Auto Fit Bounds | Fit map to visible features on data refresh    | `true`    |
| Stroke Color    | Border color of polygons                       | `#ffffff` |
| Stroke Width    | Border width of polygons (0–10)                | `1`       |
| Fill Opacity    | Opacity of polygon fill (0–1)                  | `0.5`     |
## How it works
The plugin matches Grafana metric series to GeoJSON features using a tag-based naming convention and colors polygons with a chroma-js quantile scale on a Leaflet map with CartoDB dark tiles.
**Example:** given a series named `metric{departamento=CONESA}` and **GeoJSON Key** set to `departamento`, the plugin finds the GeoJSON feature whose `departamento` property equals `CONESA` and assigns it a color. The color is interpolated between the **Cold Color** (minimum value) and the **Hot Color** (maximum value) using a chroma-js quantile scale across all matched features.
## Available scripts
| Command              | Description                             |
| `pnpm run dev`       | Webpack watch mode (development)        |
| `pnpm run build`     | Production build                        |
| `pnpm run server`    | Start Docker Compose environment        |
| `pnpm run test`      | Jest in watch mode (changed files only) |
| `pnpm run test:ci`   | Jest single run (CI)                    |
| `pnpm run typecheck` | TypeScript type-check (`tsc --noEmit`)  |
| `pnpm run lint`      | ESLint                                  |
| `pnpm run lint:fix`  | ESLint auto-fix + Prettier              |
## Testing
Tests use [Jest](https://jestjs.io/) and [React Testing Library](https://testing-library.com/docs/react-testing-library/intro/).
```bash
pnpm run test      # watch mode — re-runs on changes
pnpm run test:ci   # single run (used in CI)
## CI
GitHub Actions (`.github/workflows/ci.yml`) runs on every push and PR to `master`:
1. **build** — lint, typecheck, and production build (uploads `dist/` as artifact)
2. **test** — runs `pnpm run test:ci`
3. **plugin-check** — loads the built plugin into a Grafana container and verifies it is registered via the Grafana API
## Project structure
src/
  module.ts              — plugin entry point & panel option definitions
  types.ts               — ChoroplethOptions interface
  components/
    ChoroplethPanel.tsx  — main React panel component + data matching
    ChoroplethMap.ts     — Leaflet map rendering + chroma-js color scale
    GeoJsonEditor.tsx    — panel editor: fetch / preview / clear GeoJSON
    GeoJsonKeyEditor.tsx — panel editor: select feature property key
