title: "Host Overview panel plugin for Grafana"
description: "Visualize your resources in a compact table with powerful tooltips and grouping. Host Overview panel plugin for Grafana by taminomara."
> This is the Markdown version of https://grafana.com/grafana/plugins/taminomara-hostoverview-panel/
# Host Overview
- Developer: taminomara
- Version: 1.2.0
- [Installation](https://grafana.com/grafana/plugins/taminomara-hostoverview-panel/installation.md)
- [Change log](https://grafana.com/grafana/plugins/taminomara-hostoverview-panel/changelog.md)
![Overview of nodes and containers](https://grafana.com/api/plugins/taminomara-hostoverview-panel/versions/1.2.0/images/img/screenshots/service.png)
![Overview of a large data center](https://grafana.com/api/plugins/taminomara-hostoverview-panel/versions/1.2.0/images/img/screenshots/dc.png)
![Overview of database instances](https://grafana.com/api/plugins/taminomara-hostoverview-panel/versions/1.2.0/images/img/screenshots/db.png)
# Host Overview Panel
A Grafana panel plugin for visualizing the status of fleets of resources — servers, database instances, containers, or any entity with a status field and optional metrics.
![Screenshot with preview of a service overview dashboard](https://raw.githubusercontent.com/taminomara/grafana-host-overview-panel/refs/heads/main/src/img/screenshots/service.png)
![Screenshot with preview of a data center overview dashboard](https://raw.githubusercontent.com/taminomara/grafana-host-overview-panel/refs/heads/main/src/img/screenshots/dc.png)
![Screenshot with preview of a database overview dashboard](https://raw.githubusercontent.com/taminomara/grafana-host-overview-panel/refs/heads/main/src/img/screenshots/db.png)
## Features
- **Modern design for Grafana 12** — panel uses built-in theme-ready components.
- **Flexible grouping** — nest resources by any combination of fields, with configurable sort order, coloring, and layout.
- **Multiple display modes** — simple colored cells, cells with text labels, or rich table cards showing multiple fields per resource.
- **Joins** — attach metrics from other data frames to groups or individual resources via key-based joins.
- **Field visualizations** — text, colored text, colored background, gauges, and sparklines for joined or inline fields.
- **Color overrides** — fields and joins can override cell colors based on threshold severity.
- **Data links support** — define data links for any group, resource, or metric.
- **Tooltips** — hoverable tooltips with configurable title, fields, and joined data.
## Requirements
- Grafana 12.0 or later.
## Documentation
For setup guides, tutorials, and a full options reference, see the [documentation site](https://grafana-host-overview-panel.readthedocs.io/).
